Question about Maytag Refrigerators
Maytag performa refrigerator door handle loose
SOURCE: Ge profile refrigerator door handle is loose
I had this problem on this model and just repaired it.... and I am no mechanic. The bottom of the handle was loose. You'll see there is a cap on the top and bottom of the handle. You need to pop the cover off of the end that is loose. For the bottom part of the handle, I used a flat head screwdriver under the most southern portion of the handle, lifted the handle of the screwdriver towards me. The cover popped with minimal effort. Tighten the screw and replace cover. Pretty, pretty, pretty easy!
Posted on Oct 10, 2008
  • 11 Answers
SOURCE: On my Kenmore Elite #106.56683501 the refrigerator door is loose
Depending on the model, and the color, here's your fix.
Stainless with stainless handles- you'll need a hex key. The tiny hole is on the inside of the handle, close to the center. Turn the key until it's tightened.
Stainless with black handle/white/bisque/black- push the door handle up. Careful not to scratch the finish! once the handle pops, pull it straight off. Take a phillips head screw driver, tighten the top screw A LITTLE BIT and then attach again. Insert screws on the door into the holes on the handle, slide down. (will need to be a little tough with it.)
Posted on Sep 06, 2009
SOURCE: Loose door handles.
There was a plastic card the size of a credit card that came with the refigerator that helps release the handles. If you don have this you can use any stiff plastic card ie: blockbuster card, store card etc...
Pull the handle away from you while inserting the card in the top or bottom of the handle based on your model. I believe the Admiral model LSD2615HEB required the card be inserted 11/16 of an inch. This should release the handle. Once released there are 4 hex screws located on the handle that may require tightening.
To reinstall: Match the hardware up just above the final location and then slide down, this should lock the handle back into place.
Posted on Sep 30, 2009
SOURCE: The handle on my refrigerator door (Admiral side
There is a plastic card that came with the refrigerator. Pull the handle towards you and slide the card between the door and handle on the top side of the lower handle. Slide the card until it stops, I believe its 11/16". Next slide the handle upward to release it. It may take some force to release the handle. Once its removed, you will see a bracket on the handle. In my case, the screws were loose. Tighten the screws and replace the handle and its fixed. To reinstall the handle, line up the handle with the brackets on the door. Slide down until you here a click that indicates that the handle is installed properly.
Posted on Dec 30, 2009
  • 4 Answers
SOURCE: Door Handle Loose and tightening with allen wrench does NOT work ...
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Posted on Jan 24, 2010
How do I do fix the handle of my Matag refrigerator #M1TXEMMW803. It is loose on the bottom.
Maytag Repair - YouTube
? 2:17
https://www.youtube.com/watch?v=KcPy_PWb_Iw
Aug 27, 2013 - Uploaded by hpaiz69
Maytag Side by Side Loose Door Handle Repair. ... RefrigeratorDiagnostic & Repair - Not cooling ...
LG Refrigerator Repair (Part #AED37133117) - YouTube
? 1:01
https://www.youtube.com/watch?v=BXupc6y_wgw
Jul 9, 2013 - Uploaded by RepairClinic.com
The most common reason for replacing the handle is when it . ...Fridge Freezer Door Handle Replacement ...
How to fix a loose Refrigerator Handle - YouTube
? 0:30
https://www.youtube.com/watch?v=4IO60zkMXpw
Dec 12, 2013 - Uploaded by Charles Joyner
How to fix a loose Refrigerator Handle .... Refrigerator Repair - Door & handle, Amana , Whirlpool, Maytag ...
Jan 05, 2016 | Cars & Trucks
Tighter door handle on freezer door maytag mf12568aeb?
Slide the handle up tightened the screws underneath and line up and slide the handle back on
Jan 03, 2016 | Maytag Refrigerators
The handle for the freezer door came off on the right side. It is now dangling, and there is a loose black plastic part that fits in the handle, and a loose screw. Can you tell me how to re-attach it?
Click this link http://c.searspartsdirect.com/lis_png/PLDM/M0606060-00001.png this is the diagram for the door handles on your unit. The loose black plastic part is that part number 3 in the diagram that you are trying to describe part 3 would go into the door itself although in order to turn the screw to go into part 3 and the door at the same time you may have to call maytag there is a special tool they use to attach the handle. If you have any further questions message me back Thanks Rick
Aug 23, 2011 | Maytag MFC2061KES Stainless Steel French...
My freezer door handle is coming loose. How do I
The handle should slide to the left using the handle release card
Feb 16, 2010 | Maytag MBF 2256 Bottom Freezer...
Maytag performa bottom freezer works but upper
First you should make sure your Evaperator fan is working. Open the freezer door and press the door switch in and see if you here the fan running.
If you dont here the fan you might have a fan motor problem.
Jan 07, 2010 | Refrigerators
Handle on bottom freezer drawer is loose.
Take the handle and slide to the left as far as it could go to tighten handle. This worked for me.
Jun 26, 2009 | Maytag MFI2568AE Side by Side French Door...
Can't take apart the door on a Maytag Performa Stove
Set the door in the broil position and yank it off the hinges, set the door on a good work surface, carefully take the sides off first then the handle comes off then the glass comes out.
Jan 31, 2009 | Kitchen Ranges
Loose handle
Hi Thanks For The Question There Should Be An End Cap Which Can BE Removed And Tighten Screw .THanks The Appliance Doc
Jun 03, 2008 | Maytag MSD2656G Side by Side Refrigerator
Refrigerators Logo
100 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
