Question about ASUSTeK COMPUTER A8n-sli Deluxe Socket 939 Amd Motherboard
CD drive is not working correctly
After flashing the BIOS I noticed that my CD and DVD drive would not work. I have tried installing a CD drive that I know is good, but that did not work. I looks like a CD is playing in Microsoft Media Player, but no sound. Also, there are no song titles and the times for each song does not match what the CD said.
  • Bill LaFever Jan 11, 2013
    I tried setting the BIOS setting "Plug and Play OS" to yes and that did not work. The other suggestion about setting AC97 instead of HD audio is not an option on this BIOS. I am going to re-flash the BIOS to a prior state next week when I have someone to help me with that..
  • ASUSTeK COMP... Master
  • 3,606 Answers
Hello try to download the manual from here:
http://www.asus.com/Motherboards/AMD_Socket_939/A8NSLI_Deluxe/#download
Please select your windows system.
Open the manual folder, and click on global for download.
You will need adobe reader, to read the content.
Check the bios settings for the audio, try to change the setting to
ac 97, instead of hd audio.
Try also to select the setting plug and play os. to yes.
Remember to save your work when leaving the bios.
Why are you useing both a cd and dvd drive ???
A dvd drive does also plays cd`s.
Are you useing sata or ide connection ??
If so the ide cable could be failing.
Update any drivers, if some missing.
Good luck
Posted on Jan 09, 2013
  • Bill LaFever Jan 09, 2013
    Hans: Thanks for your reply. I checked the Audio seting int BIOS and there is only one option. AC97 on or off. No option for HD audio. I tried changing the "plug and Play" to OS, but that did not help. The only reason I have both a CD and DVD player is that I added the DVD player and left the old CD player in the system. I know, I can get rid of the CD player, but just did't. And because both these units are not working correctly, I assume it must be either the controller to the IDE on the motherboard or the BIOS that I updated some 6 months ago. I am going to try to re-flash the BIOS to a prior state sometime next week when I have some to help me. By the way, I am using Windows7 Home Premium if that makes any difference. Thanks for you help.
Bios does not see cd-rom but dos does, can't boot cd
Sounds like a hardware issue. Try downloading UBUNTU as an alternative to Windows. If you still need windows Install virtual box for UBUNTU and run it that way.
Virtual Box: https://www.virtualbox.org/wiki/Linux_Downloads
You probably have tried holding "F12" during bootup. This will give you the option to start from the CD.
If you suspect it's a BIOS issue try flashing the BIOS. You can do this by going to the PC manufacturer website and searching for support- Drivers and downloads.
If your BIOS supports USB boot you can try to update the BIOS that way. Then going back and configuring it for CD boot.
You can also try to create an ISO image of Windows and install it via USB.
Mar 10, 2012 | Computers & Internet
Can,t boot up from cd/dvd player to format hard drive and install new operating system seems like their is a lock on the hard drive because i tried to reformat it on my other laptop and was also...
that would be in Device Manager not BIOS. there is no BIOS that i am away of that will show a ! on a drive nor lock out a CD Rom drive.
if you tried to format a computer with a disk and it didn't work in 2 different computers, it has nothing to do with the drive and all to do with the disk. Is this disc authentic pressed or is it burned?
Get a new disc and try again.
If this is an external CDROM that you are hookign up, then you need to make sure the drive is working correctly or the cable is not damaged.
Jun 03, 2010 | IBM Computers & Internet
Bios does not recognize cd/dvd drive, nor external cd or dvd drives (optical drives). Updated to version 2.0 Bios from Toshiba website, but no success with that either. Is there a fix for this? How can I...
well, only way is to flash your bios.
it should be bootable flash bios tool that will assist you to remove all the current settings to the original settings. but if you can get the memory flash for toshiba then try running the system in safe mode the see if your usb devices can function then you try booting the system with cd/dvd drive. it should work
May 21, 2010 | Toshiba Satellite A215-S5822 Laptop
Dell Dimension XPS GEN 5 IDE Philips CD DVD drive failed. So I tried a Liteon SATA CD DVD drive, but that wouldn't work. So I tried a Samsung IDE CD DVD drive and that won't work. I'm guessing mobo driver...
first try installing one and go to your bios and set your bios to default . save you changes and exit.
also in my computer look and see if it appears there
if so you know its being reconized.
rite click it go to properties and then hardware
select the drive if you have gotten this far meaning you saw the drive. . go to properties and see if it says its working properly. it could also be that none of the drives your trying to install are compatible.
Nov 12, 2009 | Dell Dimension XPS 400 PC Desktop
I'm trying to install Microsoft Server2003 on a Dell PowerEdge 2600 Server. I belive that the CD ROM is faulty since it doesn't boot off it even though I have the right settings in BIOS. I try to connect a...
Another common way around installation is to copy the whole contents of the CD / DVD to a hard drive.
There are a few methods.
My proffered is to make a bootable flash drive on another machine with known working capabilities that will bot into either an XP-pre installation scenario or a Dos based one.
From there it is often possible to start the installation or even copy the required files to a drive on a machine.
Advantage of copying the files is that the CD / DVD would never be needed to add additional component as they are stored on the machine itself.
That also speeds up installation dramatically.
Bios consideration mus be taken into account when booting from flash drives.
Proper external Hard drives are another viable option
Sep 08, 2009 | Dell PowerEdge 2600 Server
I can't install any OS because by DVD drive doesn't detect it!
have you tried using fdisk and delete partion then make new partion and set active partion then boot from CD which will then format drive then install OS
Jun 24, 2009 | Computers & Internet
System configuration data read error
If the flash bios installation was stopped, you might have to do it from dos, otherwise, go ahead and press f2 and correct any obvious errors (ie floppy drive listed and not present)
Mar 19, 2009 | Computers & Internet
Cd/dvd drive installed and it was working but suddenly the drive is not shown in my computer/control panel and not working if cd is inserted.How to find the drive/ make show the drive in my...
Try to find it in BIOS. Press F2 or F10 or Del when power your pc on. These keys depends on your bios brand. After entering try to find cdrom drives menu maybe it is disabled. Or there are disabled IDE or sata controller
Mar 19, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
CD/DVD player not working
You have done all the things to try and get the CD drive to work, but it looks like your CD/DVD drive has died.
Best thing is to get another CD/DVD drive, make sure the connector on the drive is the same as your old one.
You need an operating CD/DVD drive to install Windows, unless you can get the BIOS or F12 to boot up from the USB port. The USB stick needs to hold all the Windows files.
But then sometime you need a working CD/DVD drive.
Mar 15, 2009 | Toshiba A75-S125 Satellite Notebook
ASUSTeK COMPUTER A8n-sli Deluxe Socket 939 Amd Motherboard Logo
29 people viewed this question
Top ASUSTeK COMPUTER Computers & Internet Experts
Steve Kozy
Steve Kozy
Level 1 Expert
Ron TheFlash Smith
Ron TheFlash Smith
Level 1 Expert
andrewcahoon
Are you an ASUSTeK COMPUTER Computer and Internet Expert? Answer questions, earn points and help others
