Question about Saws
Protech 4008 table saw parts
I need a new motor
4 Suggested Answers
  • 187 Answers
SOURCE: New or used motor for a Craftsman 10" table saw
You can try Sears but they can be a bit pricey. I use to send out motors for a factory I worked in to a rebuilder who would even do new windings. Check in your area for a rebuilder, As for the replacement being a Sears unit they may have a similar motor in stock. Good luck.
Posted on May 08, 2009
  • 11 Answers
SOURCE: where can i find a
If you still have the old motor, use the info off of the motor label that describes the mounting configuration (this is the frame type). Do a google search for "Electric Motor NEMA Frame Sizes" for a good list of them. If your label is unreadable (or missing) search for the owners manual for your tablesaw - they usually have the specific motor model number.
The motor frame type is all you really need for making sure it will fit your saw - however, if the old motor was a 1 hp, and you install a 5 hp - you may have problems with the size of the motor hitting the table saw.
Also, decide if you want 110 or 220 volts. In general 220 is more effecient (3 phase is much more effecient). But I bet you'll want to stick with the original horsepower and voltage.
Then, do a google search for your motor. The frame for my motor is J56HC, it's a 3 hp and I use 220 volts - so my search is usually just "electric motor frame J56HC", but if I find too much garbage, then I search "electric motor frame J56HC 220 volts 3 hp". Once you find a motor model number (the motor I liked was a leeson 115048) then search for that. I found a great deal on ebay searching for this.
Posted on Dec 17, 2010
wentlanv
  • 710 Answers
SOURCE: need to know how to change the agle on the blade
Hi Ron,
You didn't give your model.
Protech is out of business so I could not find a user's guide for you.
The knob on the front that you use to raise and lower the blade also adjusts the angle. Depending on your saw, normally the knob releases from raise/lower mode to angle adjustment by either pulling the knob out and moving it or by pushing a lever to release it and then moving the knob.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 09, 2011
How do i change motor on pro-tech table saw model 4008
Check the brushes first they might be worn out or might be easier and cheaper to buy a new saw.
Mar 29, 2016 | Saws
I have a Pro-Tech table saw Model 4008 and neet a miter gauge assembly. The bar is 5/8ths. Any comparable replacements out there?
I tried all of my sources.
all I can suggest is try running an ad on Craigslist ... or search Pro-Tech there and see what pops up.I've seen them without rip fences , with bad motors etc. but otherwise complete for $30 ...
good luck.
Apr 08, 2013 | Saws
Bosh 4000 table saw runs backward and at low speed
I've worked on some table saws with problems like you describe, a couple needed a new speed control unit (Bosch PN 2610997306) in the motor. If all the wiring to and inside the motor is OK and not shorting out anywhere, that's the next part you should look at.
Jul 10, 2012 | Bosch 4000 10IN Table Saw
On a Craftsman 10" table saw Model 137.221960,
I have this saw. Motor just went on me (siezing up and smoking/burning) so if anyone can use parts then you're welcome to them. jmbombadil@yahoo.com in Conshohocken, PA.
Sep 20, 2011 | Craftsman 10" Table Saw
Need to know how to change the agle on the blade for a protech 10 in table saw
Hi Ron,
Handie Andie
May 09, 2011 | Skil 10" Table Saw
Where can i find a new motor for a protech 4106 table saw
Dec 17, 2010 | Saws
Looking for cost of replacement motor for skilsaw model 3400 13amp for 10" table saw and where to buy from? Also, is there a 15amp replacement motor that would bolt right in to replace?
i looked online at places I get parts from. Neither listed the motor as a part the had the aramature for about $70 and the field for about $35. Have you tried the reset button? also it may just need new brushes.(if you see lots of sparks at the end of the motor opposite the blade, look through the air vent slots it is likely the brushes, unplug the saw, and take them out and replace them HERE is a blow up ) the I would think that if the saw is well used and the motor has burnt out. It may be a lost cause. I am not sure what the price of this was new but you can get a reconditioned saw from Amazon for 135 bucks. And it is a 15 amp saw.
Dec 07, 2010 | Skil 10" Table Saw 3400
Need a new lower guard assembly part, for an 81/4" compound Protech miter saw.model #7203
Sorry the only place you can get parts for the saw is sears parts direct
Dec 03, 2010 | Garden
Need a new motor part # 63870 for a 10-inch sears radial saw
There may be a recall on this model.
http://www.radialarmsawrecall.com./
If not, take the motor out and take it to a shop that does repairs on electric motors, probably be fixed for much less than the cost of a new motor from Sears ($200-$300).
Apr 09, 2010 | Craftsman 10" Table Saw
Saws Logo
310 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
