Question about Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi
Bulldog remote start
1yr ago, on my 2003 pt cruiser, the bulldog remote started by itself, 2 nights in a row. Took to dodge place, no help, told take battery outta remote, Fine til today, it started by itself again. I'm way back in the woods, 2 neighbors 1/4 mile away,, What causing this????
  • ugabulldog Jan 20, 2009
    I went their website, in the FAQ section, you can clear the memory of the remote start, cause the person replaced battery, I did replace my car battery, Do you think this might work?? That's all I can find ???
    Well, how do you disconnect it?? I see on their site, the module is located inside by the column nearest key cylinder, 5-10 wires, What do I do?? I do have remote door locks on a different fob also. Hope not to intefere with it.
  • 1,596 Answers
Its a Fault in the Moduel and The Tech support Dont know How to Repair it I Installed a Bulldog Remote start/lock/tail gate on a 02 Blazer and 1 Year later it did the same thing, I just Disarmed it and forgot about it the Owner tried to get help from them to NO Avail.
Posted on Jan 20, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Can anyone.tell me the Torqe specs for a 2004 or cruiser
Head and Cam Bolt Torque specs? - PT Cruiser Forum
www.ptcruiserlinks.com > ... > Tech & Performance Forum
Nov 5, 2012 - 2 posts - ‎2 authors
I am putting everything back on after replacing the head gasket. I was wondering what the Torque Specs and Sequences are for both the Head ... Torque Specs
Jul 28, 2012
Valve cover torque specs
Jul 4, 2011
Timing Repair Project - Bolt Torque Specs
Jun 16, 2011
torque specs?
Mar 20, 2006
More results from www.ptcruiserlinks.com
Dodge Stratus / Chrysler Pt Cruiser / Sebring Camshafts ...
? 5:07
https://www.youtube.com/watch?v=2wB2o27eWgo
Aug 20, 2015 - Uploaded by World Mechanics
Dodge Stratus / Chrysler Pt Cruiser / Sebring Camshafts Install and Torque Specs 2.4 Engine. ... 2004 Chrysler PT CruiserCamshaft Install
Dodge Stratus / Chrysler Sebring / Pt Cruiser 2.4 Head ...
? 6:08
https://www.youtube.com/watch?v=7rY7tDbye-8
Aug 16, 2015 - Uploaded by World Mechanics
... Stratus / Chrysler Sebring / Pt Cruiser 2.4 Head gasket Install and torque specs We took this video to ... 2004 Chrysler PtCruiser head gasket
Jan 18, 2016 | Cars & Trucks
Why does the air conditioning / heater blower cut in and out and sometimes doesn't work at all?
Search Results
    PT Cruiser AC air conditioning fix how to - YouTube
    ? 1:28
    www.youtube.com/watch?v=r2n3Uuvwyc0
    Jul 9, 2014 - Uploaded by invictustang
    Here is a short and simple video to fix the AC in a PT Cruiser. The first thing you ... This is the same on a dodge neon .... the pt cruiser). 3- The compressor itself: Since the clutch is not working, can be the coil or something on it.
Oct 15, 2015 | 2003 Chrysler PT Cruiser
Troubleshooting pt cruiser
DO U HAVE A REMOTE TO START YOUR CAR AT DISTANCE?
THIS SHOULD BE THE FIRST THING TO CHECK!
Apr 02, 2014 | 2003 Chrysler PT Cruiser
My pt cruiser stalls whenever i slow down but moves perfectly on high speeds.This problem started after timing belt snapped and i changed it
My pt did the same thing. took it to another mechanic, and he told me they left the timing off. took it back and told them what the mechanic told me, and they set the timing straight. Now it runs great.
Jan 12, 2013 | 2004 Chrysler PT Cruiser
Had the alternator replaced 2 days ago and during the night the alarm goes off lights flashing honking use the key fob to turn it off and takes a while for inside light to go out stays quiet for a while...
Hello, sounds like you need a new battery. As the battery goes flat the alarm senses it and sets off the warning system. Try changing the battery first and test it during the day. Also check to see if there is anything draining the power. You may also be able to adjust the alarm settings manually. Failing that, the alarm may need replacing. I hope I have helped.
Mar 24, 2011 | 2003 Chrysler PT Cruiser
2003 PT Cruiser w/manual transmission won't go in reverse.
I have a 2003 pt cruiser with the same problem.After I removed the air filter housing, I noticed the shift cable was out of place.it wasn't sitting pproperly on the pin.You might want to check yours.By the way there are 2 shift cables check both.
Jun 25, 2009 | 2003 Chrysler PT Cruiser
Crazy Electrical Problem in 2005 PT Cruiser
Either wire harness problems or you got a so called lemon
One of the first books of Ralph Nader about auto industry.
Had a Hyundai like that 27 years ago. Until I took it totally apart and re-assembled it myself. 2 years ago bought a Piaggio 45 cc motorbike, same story. Took that apart one night and put it together as should be.
Apr 15, 2009 | 2003 Chrysler PT Cruiser
2003 pt cruiser sensors
check the battery and make sure it has a fully charge,also check to make sure the start motor pinion is not jammed in the flywheel, and check the coil pack to make sure have spark.also check the crank sensor
Feb 14, 2009 | 2003 Chrysler PT Cruiser
Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi Logo
631 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
John
John
baire
DROPNDEAL
DROPNDEAL
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
