Question about Kenmore Refrigerators
Ice maker slow down...for bottom freezer 795.78279.901
SOURCE: water pooling and freezing inside bottom freezer
I had the same problem with my LRFC25750 and have finally figured out what's happening! The water that is pooling and freezing on the bottom of the freezer is definitely coming from the defrost cycle. It is pooling inside the freezer compartment because the drain inside the back of the freezer intended to carry the defrost water down to the external evaporator tray underneath is blocked with ice. As a result, the defrost water from the coils overflows the collector under the coils and runs down the inside back of the freezer, pools on the bottom, and re-freezes when the cycle is over. this continues until there's so much ice on the bottom that the water from next defrost cycle runs out on the floor. The "easy" solution is to unplug the unit and let it completely melt out (this could take 24-36 hours). I couldn't wait, so I removed the freezer drawers and their tracks and pulled out the back panel inside the freezer -- saw the ice in the collector and blocking the drain and I melted it away with hot water and verified that water could now flow down to the external evaporator tray. Unless you want to do this, I'd say give it a good 24-36 hours for all the ice to melt away. I think it all started when we left the freezer door ajar for a whole day and probably had a lot of frost build-up on the coils. The next defrost cycle was not enough to clear all the frost and things began to build up from there. Once the drain is frozen, though, you're finished -- the defrost heater doesn;t reach down that far and you have to melt it down completely or it will continue to leak forever. I've heard that you can get a drain heater to ensure that the drain never freezes over or at least so that it is sure to clear with each defrost cycle. I'll post an update if I locate one.
Posted on Sep 03, 2007
  • 1073 Answers
SOURCE: Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Posted on Apr 12, 2008
rickzilla
  • 706 Answers
SOURCE: Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Posted on Sep 15, 2008
SOURCE: ice buildup on bottom of freezer
yes, the drain is clogged, remove all food from frige and freezer and defrost with a hair dryer,go the the freezer section this is where the issue is, you need to poor hot water into the drain trough located just below the evaporator, chase the drain with a coat hanger with the hair dryer on the coat hanger this with heat up the coat hanger enough to melt and free the clog.
nbcrca:)
Posted on Apr 11, 2009
lsteward68
  • 331 Answers
SOURCE: my ice maker is really
it could be 3 things.
1. The icemaker has a water filter. Has that ever been changed?
2. The water inlet solenoid maybe going bad.
3. The freezer is not freezing the ice. if this is the case clean the back and bottom of the unit as to allow airflow.
Posted on Apr 15, 2009
Bottom freezer ice maker overflows with ice cubes
make sure your contol arm moves up and down freely, arm is down to make ice whe ful arm must be up to shut down ice maker
Oct 18, 2013 | GE Energy Star PDS22SIS Stainless Steel...
MAKING ICE TOO SLOW
A lot of times, the reason ice production slows down is because the freezer isn't cold enough, usually because the freon level of the machine is low. Sounds weird, but even though the freezer is below 32 degrees F, which is freezing, the ice maker requires the temperature be below 10 to function properly. Another cause for the temperature not being cold enough is if the coils are dirty and ther machine is passing the heat to the machine itself
May 30, 2012 | Maytag MBF2556HEW / MBF2556HEB /...
Ice maker working very slow
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects then you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 26, 2011 | LG 25.2 Cu. Ft. Side By Side Refrigerator...
Having problems with ice maker. Was slowing down it seemed in making ice... and now it does not seem to be making ice. I tried the fast freeze ... still no ice. Obviously must be a water problem... the...
I had the same problem and the Samsung customer service person told me to set freezer to -2 degrees, remove the ice bucket, press and hold test/reset button (look for arrow on top right of ice maker inside the fridge), replace the ice bucket and wait 24hrs.
Dec 02, 2010 | Samsung RFG297AARS (285 cu ft) Bottom...
My ice maker quit making ice on my amana bottom freezer
Hi, If your ice maker has stopped making ice then you need to check these things.
The lever that controls the ice maker has been pushed up which turns it off. If you have a red lever, pull it down to the wire and if you just have a wire then just pull down the wire to start your ice maker up.
Make sure the freezer temperature is below 10 degrees F If the freezer is too warm ice production will be poor because the ice maker will not cycle properly.
The ice maker fill tube may have ice formed in it, blocking it. Use a hair dryer to melt the ice. Watch out for the plastic parts, so that you do not melt the plastic. Also check the water inlet valve and the shut off valve, to make sure it is not plugged with debris. The openings in those valves are very small.
Check the gears in the ice makers to see if they are broken or stripped. Also look to see if the ice rake is broken. All parts in the ice maker are replaceable individually, If you find broken parts replace them.
Take care
Jul 23, 2010 | Amana ABB1927DE Bottom Freezer...
Ice maker has slowed down almost to a stop We get about 3 sets of ice a day used to fill up the tray a
ck the freezer tempt / if around 15 deg It's not cold enough and ice producton will be slow .clean the cond coil this will help and make sure the cond fan is working . it may also need the charge adjusted ( loss of refergerant ) . or possible cold control . and look for ice build up in back of freezer .. this would slow the air flow . .. **** hope some of these help . ****
Jan 16, 2010 | Amana ABB1927DE Bottom Freezer...
We have a GE Profile refrig, circa 1995. The ice
If you are sure it is caused by the ice maker or if it is not it can be fixed. The only way an ice maker would leak like that is if ice is blocking the inlet tube and when the water comes on the water is spewed in a different direction than the ice maker. Most times this is caused by a slow leak in the water control valve for the ice maker side at the rear of the refrigerator. You can stop the problem by melting the ice in the fill tube with a hair dryer and keeping an eye on it until you see ice beginning to build up there again. That would indicate a slow leak in the water control valve that is not closing all the way when off. The other reason for large pools of ice in the freezer is a frozen over defrost condensate drain behind the cover in the rear of the freezer and would require you to unplug power and remove the rear panel. I will try to get some photos and a link shortly that covers that problem a lot more in just a few minutes. Sea Breeze
Aug 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Elite, Ice maker will not produce.
Try taking the ice despenser out and carefully melt any ice in the freezing tray. Sometimes the ice doesn't fully eject, leaving behind residue that will eventually become too full to produce ice. You can melt it by slow running hot water or hair dryer low speed.
Aug 07, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Water/freezing to ice at the bottom of the freezer MZD2766ge
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all that ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youll melt everything) or by pouring hot water down the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 17, 2008 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
123 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
