Question about Optoma ML500 Multimedia Projector
Optoma ML 500 searching signal interupts veiwing tv
I'm watching football thru my Optoma ML 500. I get this annoying search that interrupts my viewing of the game. It lasts about 5-10 sec and signal returns. Is this instrument-related or Dish-related? Thanks, Len S
  • 89 Answers
SOURCE: in the middle of the
Change the signal cable.
Posted on Aug 10, 2010
Basti
  • 1447 Answers
SOURCE: My optoma projector does not find my HP laptop
Hi
What type of cable are you using to connect the projector to your laptop? if VGA you have ti press "FN" and F5 or the F key that has a monitor symbol on it. Try using a different cable as well and if it has an auto search button on the projector try pressing it.
Hope this helps
Posted on May 10, 2009
  • 57 Answers
SOURCE: I Have an optoma projector ep721 I plugged all the
Source input not geting signal,check with other input
Posted on Jul 05, 2009
projdoc
  • 2237 Answers
SOURCE: The Optoma EP749 Projector--display says
go into the settings in the menu. there should be a setting for resolution.
Posted on Nov 16, 2009
  • 75 Answers
SOURCE: How do you feed TV thru an Optoma DLP projector?
You need a tuner to tune in the tv channels. use a vcr that way you can change your channels
Posted on Jun 07, 2010
Watch TV (Vizio smart Tv)with my projector (Optoma ML 500)
you cant connect a projector to the hdmi on a tv,you have to connect the cable box to the projector
Jul 03, 2015 | Vizio Razor Led M650vse - 65 Class 64.53...
Just purchased a refurbished optima ep716 projector won't synch-keeps rolling through search mode - I have it connected using the SCART setting.
Reduce the screen resolution of your computer monitor to 800 x 600 and check. Let us know the result.
Optoma is a SVGA projector. i.e. the maximum resolution supported by your projector is 800 x 600.
Sep 26, 2011 | Optoma EP716 Multimedia Projector
How to connect optoma pk100 projector to a computer (15 pin). I got an adapter (15 pin to AV) but it doesn't work.
Let me start off by saying that the adapter that you picked up only works on select video cards. If your computer has an s-video connection, plug your video into that (use an s-video to composite adapter if you need to). If your computer does not have an s-video connection, your best bet is to pick up a VGA converter box. Search " PC to AV TV Signal " to find one.
Mar 06, 2011 | Optoma PK100 Projector
I just got a new Optoma HD20 and only after 1day of use it is not showing HDMI signal, although it is showing VGA signal. Why is this?
Hi miracles4all: I solved HDMI signal issue in my Optoma HD20. In my case it was the lack of contact between the HDMI cable plug male ending and the Optoma HD20 HDMI female port. My 35ft cable plug male HDMI ending was not completely "seating" in the Optoma HD20 HDMI female port. I solved the problem by purchasing a HDMI female to female coupler and adding a 3ft HDMI cable that had a slim male ending. This 3ft HDMI extension cable made better contact to the Optoma HDMI port and the projector was immediately able to detect HDMI signal. Hope this helps you... kaufmanekpr
Nov 05, 2010 | Optoma HD20 DLP Projector
Jun 06, 2010 | Optoma EP739 Multimedia Projector
Program Optoma EP-739 remote to Bell Express Vue 3100 remote
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
Feb 23, 2009 | Optoma EP739 Multimedia Projector
I don't have a remote
Search with google for optoma rd65 (no hyphen) once you get the first set of results, scroll to the bottom of the page, click search within results and search replacement remote. this is just one site I found.
http://www.remotes.com/store/optoma/rd65.html
Jan 28, 2009 | Optoma RD65 65" Rear Projection HDTV
Optoma ML500 Multimedia Projector Logo
35 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
