Question about Kenmore Dryers
Repair manual kenmore dryer model 96283110
Need where wires connect to heating element
  • 641 Answers
SOURCE: Kemore Dryer / Model # 63742
I'm not familiar with this specific Dryer, but in most of them you can find their wiring diagram glued under the upper panel or the rear panel. Good luck !
Posted on May 16, 2006
SOURCE: I NEED OWNERS MANUAL TO KENMORE DRYER
goto sears.com and under parts type the model# hit enter. Then type manual and it will cost you $2.30.
Posted on Oct 16, 2007
watugot
  • 290 Answers
SOURCE: Kenmore Electric Dryer Model # 110.62622101
I think on your machine the lower thermostat connected to one terminal of the element, you have a wire coming from the thermal cut off down to the top terminal of the lower thermostat, a wire from the lower thermostat to the timer, and a wire going to the other terminal of the element.
You probably have the wire from the cut-off correct as it won't reach the other terminals. You have crossed the other 2 wires. This caused 240V to short across the lower thermostat and burned it out.
You will need a new Hi-limit thermostat, which will include the upper cut-off as well. They come as a set part# 279816. This will be a little different because the new hi-limit will not connect directly to the element. There will be all the wire ends and instructions with it that you need to get it hooked up correctly.
There should be a wiring diagram inside the console of the dryer that shows which wires go where, but I am sure you have crossed the 2 wires below the hi-limit switch.
Post back if you need any help.
Thanks/Mike
Posted on Dec 02, 2007
aborcass
  • 2651 Answers
thiknin you need a service guide , not owners manual( only tell how to operate} ther is a schematic/ wiring diagram locate with inthe console itself usually taped to the back wall behind the timer
Posted on Apr 03, 2008
  • 1028 Answers
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Posted on Jun 19, 2008
Kenmore dryer will not heat up to dry clothes. serial# MD0748533 mod# 97281100 72811
Your issue is as follows:
"the dryer works but there is no heat to dry the clothes.
Based on the information provided above, I am unable to provide a positive solution to your issue.
Following this LINK, provides valuable D.I.Y. safety information on the make and model number of your appliance. In order to access your product information, you will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User's Manual.
Note: A volt-ohm meter is beneficial in performing electrical tests.
This information is for an electric, generic model dryer only!
My Solution is:
If your dryer doesn't heat, check these:
Temperature Switch; make sure a positive heat selection has been made, if still no heat, then check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house: Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element: Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse: On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring: A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Nov 26, 2010 | Kenmore Dryers
Kenmore series 80 Gas dryer doesn't heat
Look for extreme fluff buildup inside and outside causing air restrictions. check your fusea5500f3.jpg
Mar 17, 2010 | Kenmore 64742 Electric Dryer
No heat gas kenmore gas dryer
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 31, 2009 | Kenmore Dryers
Whirlpool/Kenmore # 279838 instruction manual
Before replacing the element, have you checked the thermo switch to see it is working ? If you have this is what you need to do.
To replace the element you will need to remove the rear cover and then remove the element box ( a oddly shaped metal box ) that contains the element, then replace the element inside it by bending tabs that hold it in or ceramic parts that hold the wires off of the metal depending on the model you have. there are only 2 wires that are connected to the element.
Nov 18, 2009 | Kenmore 63942 Dryer
I have a Kenmore model 96283110 runs, but no heat
Sounds like your problem may be with the heating coil.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Oct 14, 2009 | Kenmore Dryers
Kenmore Dryer, Model # 11063102100, does not dry.
Does the drum still turn. If so probably just needs a new heating element. VERY easy to replace. Usually instructions to replace on or in new element box or just google instructions.
New heating element would be my first move to repair dryer.
Also, if you use softeners or dryer sheets, Wash lint screen with dawn and soft scrub brush to remove oils and residue (even if it dont look like there is none there there is) to extend your heating element use.
Sep 26, 2009 | Dryers
How do you open my dryer so I can look inside so I can see why my dryer is not getting hot air
visit youtube.com and type "do it yourself" and dryer repair in the search window.. there are some awesome kenmore repair videos online there....they'll take you step by step... have a blast!
Jun 11, 2009 | Kenmore 62872 Electric Dryer
My Kenmore electric dryer runs but no heat ....
Before I wish you luck i want you to review all of the possible reasons for your problem
Heating element
Thermal fuse
Wiring
May 29, 2009 | Kenmore 62602 Electric Dryer
Dryer won't heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Aug 11, 2008 | Kenmore 74832 Gas Dryer
Dryer won't heat
Your issue is;
"I have an older model Kenmore dryer that won't heat up. Need to know what could be the problem."
Based on the information provided above, I am unable to access my database to provide you with exacting information. A valid model number was not provided. However, I have provided some common solutions to help guide you in your search.
My Solution is:
Following this link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides valuable D.I.Y. safety information on the make and model number of your appliance. In order to access your product information, you will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual.
This link provides diassembly procedures for a similar model.
http://www.repairclinic.com/0100_15.asp
Temperature Switch; make sure a positive heat selection has been made, still no heat, then check these:
Heating element
Thermal fuse
Wiring
Please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 24, 2008 | Dryers
Dryers Logo
65 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
