Question about Trendnet Bluetooth USB Adapter TBW101UB (Blue
BlueSoleil is running in evaluation mode
This is a old blue tooth i used to use and needed a bt for my new mic on computer now i get evaluation mode and gives me a limit for whatever this is my bt and i cant use it
I465 bt passkey
You should not need pass key.Just send to new number
it will ask if you will accept click yes, that should be it.But you
probably need to search with new phone Blue tooth while old
phone on and on Blue tooth.Once it finds it synch with it.
LUCK
May 14, 2014 | Motorola Clutch Cell Phones
I want to listen to music on my phone with my bluetooth headset
iIn order to listen to music on your blue tooth headset you first must pair them to your phone,To do this you first must turn the power to blue tooth to on in your phone menu,then you will have to put your blue tooth device into discovery mode,most bt manufactures use the power button for this feature,when turning your headset on continue holding down the power button for 6 to 10 seconds and a light should stay on ,thus putting your bt device into discovery mode thenfrom your phone you can search or add new device,it should recognize the device and ask for a pin or pairing code.Most manufactures use a factory 4 digit pin pairing code,they are as follows 0000,1234,9999,or 1111,once your code is entered they should pair,then you will be able to use your blue tooth device to listen to music.glad to be of assistance
Feb 26, 2011 | Radio Communications
Need operating instructions for Jabra BT 2080 headset
ok i hope that you are trying to connect the bt device to a phone or game system or computer,the first thing you need to do is turn the power on to what you are connecting the blue tooth device to.your phone computer or game system,next you will have to put your blue tooth device into discovery mode,now most manufactures of blue tooth devices use the power button for this feature,when you turn the power on to your device keep holding down the power button for 6 to 10 seconds this will put your device into discovery mode,usually a light will remain on,then you can search or add new device from what it is you are connecting to,it will ask you for a pin or pairing code,now most manufactures of blue tooth devices use a factory 4 digit pin pairing code,they are as follows,0000,1234,9999,or 1111 enter the code and your device should pair and work with what it is you are pairring it to .i hope this helps
Feb 26, 2011 | Jabra BT2080 Bluetooth Headset
How you play music on jabara bt 2050 0n phone
first you have to pair your blue tooth device to your phone,first you turn the bt power to on on your phone menu,next you have to put your blue tooth device headphones into discovery mode,now most bt manufactures use the power button for this feature,by holding the power button down for 6 to 10 seconds when you turn the bt device on it usually puts the bt intodiscovery mode.a solid light usually remains on on your blue tooth device,then you can search or add new device from your phone menu.once they have paired or recognized you will need a pin pairing code.Most manufactures of blue tooth devices use a factory 4 digit pin pairing code ,they are as follows0000,1234,9999,or1111 i hope this helps
Feb 25, 2011 | Samsung Radio Communications
Can't remember how to pair my LG HBM-710 to my new phone - Samsung Fascinate. Can you help?
to pair a blue tooth device to a phone first you must turn the bt power on the phone to on,then you have to put your blue tooth device into discovery mode,now most manufactures use the power button for thisw feature.By holding down the power button on your device when turning it on for 6 to 10 seconds it usually puts the device into discovery mode.there should be a light that stays on on your blue tooth device.once you have the bt device into discovery mode you will be able to pair the device to your phone by search or add new device,once it pairs it will ask for a pin or pairing code.most manufactures of blue tooth devices use a 4 digit factory pin pairing code they aare as follows 0000,1234,9999,or 1111 once youve put tjhe pin code on they will pair ,i hope this helps
Feb 25, 2011 | LG HBM-710 Wireless Headset
How to get blue tooth
first turn your bt power to on in your phone menu then turn your bt device to discovery mode most devices you just hold the power button on for 6 to 10 seconds and a solid light appears once you have it in discovery mode you will have to search or add new devise from your phone,if you have everything right they will find each other but you will be asked for a pairing or pin pass code most blue tooth device manufactures use a 4 digit code they are as follows 0000,1234,9999 or 1111 i hope this helps
Feb 21, 2011 | Plantronics Explorer 232 Bluetooth Headset
Hi, My WEP460 samsung Bluetooth head set will not connect to my PS3. What do I do?
You have to make sure your blue tooth device is in discovery mode .most blue tooth manufactures use the power button by holding it down for 6 to 10 seconds while turning your bt device on ,once in discovery mode they should pair but you will need a pin or pairing code.Most blue tooth device manufactures use a factory 4 digit pin they are as follows 0000,1234,1111, or 9999 i hope this helps
Feb 19, 2011 | Samsung WEP460 Bluetooth Headset
I want to know where i can download free driver for isscbta blue tooth dongle?
isscbta blue tooth dongle originally comes with blueSoleil
which can be downloaded at http://www.bluesoleil.com/download/Detail.aspx?PID=1
Works with windows XP, Vista and windows 7
Jun 22, 2010 | Computers & Internet
Bluetooth capable, but need license??? from toshiba
BlueSoleil is a freeware Bluetooth Stack you can use instead of paying for Toshiba's version.
http://download.cnet.com/BlueSoleil/3000-18511_4-10972014.html?tag=mncol
Did this resolve your issue? If so, please rate this. Positive comments always appreciated too! ty.
Feb 26, 2010 | Computers & Internet
I cant get my blue tooth to connect to my blackberry
MAKE SURE THE BLUE TOOTH HANDS FREE OR ANY OTHER DEVICE IS IN PAIRING MODE. ( THE PIN TO PAIR A BT HANDSFREE LL BE 0000 )
ALSO FOR INCOMING BT BEEP RECEVING
FROM MEDIA. CLICK MENU AND SELECT. RECEIVE VIA BLUE TOOTH.
Feb 24, 2010 | Cell Phones
Trendnet Bluetooth USB Adapter TBW101UB (Blue Logo
85 people viewed this question
Top Trendnet Computers & Internet Experts
David Payne
David Payne
Lynne
Are you a Trendnet Computer and Internet Expert? Answer questions, earn points and help others
