Question about Hunter 52" Ceiling Fan With Light And Remote Control
My control won't activate the light on my Hunter fan. The light comes on via pull chain fine, and the control works the 3 speeds on the fan, but the light won't respond.
    Genius:
  • Hunter Master
  • 1,617 Answers
Check the wiring on your receiver to make sure the light wire is connected.You have to have the light on with the pull chain and then use the remote to turn it on/off.
Posted on Jan 24, 2013
SOURCE: 3-speed switch replaced with hampton bay switch. Only low speed works.
The cause to the problem was replacing a HUNTER fan switch with a Hampton Bay switch. Before removing the old switch, I noted and marked the color and position of the 4 wires. I then duplicated the connections to the new switch.
But the wire positions of Hampton Bay vs Hunter are not identical, therefore 2 wires
were crossed.
The correct way is to note the color of the wires with the corresponding NUMBER
marked on the switches, then duplicate this on the new one.
Du-uh!
Posted on Jul 24, 2008
  • 582 Answers
SOURCE: I have a Hunter ceiling fan with light kit. The
with out seeing the switch and how it's wired . i'll try
do you have power to the light switch it self. you have power to the fan but does the switch for the lights have power, you may have to run a jumper or sepperate wire fir the lights
Posted on Aug 23, 2009
  • 2976 Answers
SOURCE: I have a hunter ceiling fan that lost two lower speeds
The fan motor is burning out. It must be replaced.
Posted on Sep 16, 2009
SOURCE: Hunter Fan Pull Chain Hard to Operate.
same problem with the fan pull. I don't have any problem with the light pull as it comes straight out the bottom. However, the fan pull goes at an impossible angle within the light globe. Have you come up with a solution yet? I was going to call Hunter when open during week.
Posted on May 31, 2010
  • 78 Answers
SOURCE: I have older Hunter 3
if you know how you can open the switch and fix it
Posted on Jan 20, 2011
Fan only runs on slow speed
The receiver in the fan housing may have failed.
Apr 20, 2017 | Hunter Dryers
Two years ago we redid our kitchen and installed a Hunter fan. About a month ago I pulled the chain to change the fan speed. It must have stripped or something because now that chain won't work at all....
Contact hunter and they will send you a replacement switch.. Its very easy to change. You do not have to remove the entire fan to do so.
Hunter Customer service is. 1-888-830-1326
Hunter does in fact make some of the best ceiling fans there are.
P.S. You might be sure that the chain simply hasn't bound up a bit.. Check to make sure its not hung on something.
Sep 14, 2011 | Hunter Heating & Cooling
Hunter 52, fan works but light no longer works with remote or chain pull
mcdevito75 here, Don"t the fan lights work off the wall switch, The chain pull should be for fan speed. Check make sure electricity is going to the fan.
Jul 19, 2010 | Hunter 52" Ceiling Fan With Light And...
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
May 16, 2010 | Hunter 52" Ceiling Fan With Light And...
I have a Hunter ceiling fan with light kit. The controls for the fan and light are on the wall. It is a Hunter dimmer and 3 speed control switch. The fan works fine and the lights do not come on. I have...
Usually you have to press the light switch 3 times and hold to get dim effect adjustments, it is often radio transmitted in some newer models, if the pull switch is bad replace it anyways it could be dangerous if let alone!
Aug 23, 2009 | Hunter (25417) Ceiling Fan
Dryers Logo
416 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
