The 2009 Apple MacBook does not recognize the Canon PowerShot A95 digital camera during their connection via USB. No camera or any icon appears on the computer's window.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
SOURCE: I have a canon powershot
hello my friend joust put the camera,s cd to recognize and set configuration on your pc that set saludos
SOURCE: Camera is no longer uploading photos to the computer
I had this same problem and it is a problem with the actual camera where the usb cord plugs in. Luckily there is a cheap solution - you can go to radio shack and get a memory card reader for about $15 (or some newer advanced all-in one printers and computers already come with them) and take the memory card out and insert it into the reader. You can transfer the pics from the reader to your computer. All you need for the reader is an available USB port. It is very simple and I have found it to be a better way since it doesn't eat up batteries either.
SOURCE: Canon PowerShot A620 Camera wont upload to Computer
Use a cardreader to download your pictures.
SOURCE: MacBook Pro won't recognize canon powershot SD400
Hello. You need to probably reinstall the drivers. but first you have to remove the drivers that are all ready installed. first unplug your usb cord. then to remove the drivers allready installed,, on your computer, press start, then when the box open's up, then right click on computer. another box will open up. then left click at the bottom of that box on properties. another box will open up, then click on device manager. after you click on device manager another box will open up with all your devices. look for the previous camera you had installed. it might be under imaging devices. once you locate that, then right click on it. then choose uninstall. Make sure you have your new software loaded in your cd/dvd rom drive. after it is done uninstalling, just restart your computer. at the bottom right of your screen, it should say, found new device, it will ask you from where do you want to load the new drivers for it. click on the drive that contains the software. it then will load your new drivers up. It then should communicate with your camera. Hope this helps. Ron
SOURCE: Canon Powershot S2 IS is not recognized on my iMac
Simple fix...use a separate card reader to download to a folder you create on your desktop. Once there, you can move them to iphoto.
