Question about Cfm Daikin R410a Split System Air Conditioner
Urutan kabel 123 di pcb indoor daikin type ftke35 R22
2 Suggested Answers
  • 81 Answers
SOURCE: U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
Posted on Jun 28, 2010
Is it better to by air conditioners with R - 410 GAS OR R - 22 GAS
R410 units are cheaper now but not as effecient as R22, also R22 is much more expensive and most likely you would have to use R22 a to recharge unit if it as allowed where you live .
Oct 02, 2014 | Cfm Daikin R410a Split System Air...
Error message U4
Signal transmission error. Indoor and outdoor PCB's cannot communicate. Usually a faulty controller board in the outdoor unit. If the indoor unit otherwise functions normally (can control fan speed, louvres, beeps in replay to all remote buttons) then it is probably OK so check outdoor controller PCB.
Jul 21, 2014 | Daikin Mini Split Concealed Duct Units
Daikin air conditioner flashing fault code u9
U9 System communication failed Fault with other indoor unit, ie no power, Faulty PCB
Aug 10, 2012 | Heating & Cooling
JVC 700X handycam digital video camera driver
Drivernya dah di Install belum gan ?
kabel Koneksi dari Handycam ke PC pastikan dalam kondisi bagus/ga patah didalam kabel.
biasanya kalo kondisi kabel bagus,bakalan keluar keterangan Found new Hardware > Unknow Device.
atau pastikan aja dari Computer Management > Device Manager.
(Click Kanan my Computer > pilih MANAGE).
Kalo ada Tanda Tanya Kuning berarti Kabel Kondisi bagus.
Trus kalo Driver belum di install,ente bisa download dari :
5 Driver Finder (Online) :
1. http://www.all-driver.com
- Search for all aviable Driver
2. http://devid.info
- Search Driver From Hardware ID (you can See Hardware ID from :
Computer Management > Device Manager > Propeties hardware you've Need the driver > Details
3. http://www.driverguide.com
- Search Driver by Model Name or number
4. http://www.driverstock.com
- Search Driver by type and the producer
5. http://www.nodevice.com
-Seacrh driver from Categories or Companies
Kalo manfaat ditunggu Cendolnya gan....
Jan 18, 2012 | JVC Computers & Internet
Gambar tiba-tiba hilang saat tv on
hallo bagus,
Gambar hilang seperti apa ya?
1. kalau hilang suara ada, coba cek backlight nya dengan cara mengetuk panel .
jika di panel keluar cahaya (ditempat diketuk), itu tandanya backlight masih bagus, masalah berasal dari T-con atau pcb main.
jika diketuk tdk terlihat apapun, backlight rusak. Bisa rusak neon atau pcb inverter nya. klo neon rusak harus ganti 1 panel, tapi klo inverter rusak, bisa beli di service center.
2. kalau gelap dan tidak ada suara ; kemungkinan kerusakan dari power supply.
jika punya pengalaman di elektronika, coba ukur fuse dan kabel ac cord nya.
Semoga berhasil bro.
Mar 23, 2011 | Samsung LN32A330 32 in. LCD TV
Gambar tiba-tiba hilang saat tv on?
hallo bagus,
Daikin error code H6 Outdoor Compressor motor position detection sensor error
sir
daikin inverter air conditioner we are replace the indoor pcb then next it gone out door pcb,next we are replaced outdoor pcb also then compressor not working oftre last we are replaced compressor then it will be giving H6 ERROR CODE please give me suggestion
Feb 16, 2011 | Heating & Cooling
Bagaimana cara/urutan yang mudah intalasi Dlink 1360
halo budhirs,
cara mudahnya, anda siapkan semua kebutuhannya :
- kabel jaringan (biasanya sudah ada ketika beli routernya)
- PC atau notebook untuk konfigurnya
- Router itu sendiri tentunya.
langkahnya (saya berasumsi anda ingin menggunakan router ini untuk sharing Internet melalui PC yg sudah bisa online internet) :
1. Nyalakan routernya
2. plug-in kabel jaringan ke salah satu port yg ada di belkang router (jangan pada port yg bertulisan WAN)
3. sisi lain dari kabel tersebut di plug-in ke PC/Notebook
4. Jalankan Browser pada PC atau Notebook anda, firefox atau internet explorer selain itu juga bisa.
5. pada addres bar browser anda masukkan ip addres ini : 192.168.1.1 jika tidak muncul interface D-Link yg minta password dan username coba IP ini 192.168.0.1.
6. ketika dia minta Username dan Password : username : admin dan untuk passwordnya kosongkan saja.
7. Sekarang cari settingan WLAN / Wireless
8. ganti security nya jadi WPA TKIP atau WPA2 TKIP
9. dan masukkan phrase key yg anga mau (jangan lupa karena phrase key ini yg akan ditanyakan ketika anda ingin terhubung ke WiFi). dan save settingan anda.
10. Sekarang tugas anda tinggal colokin komputer yg sudah terkoneksi dengan internet ke router dan silahkan coba untuk connect menggunakan notebook.
done.
Jika ada kesulitan, bisa hubungi saya lagi.
Jan 04, 2011 | D-Link (DI-711) Router
May 28, 2010 | Cfm Daikin R410a Split System Air...
Canon np 6035 saya tak menyala tombol start di posisikan on mati sekitar 5 detik mati sendiri
Mesin canon NP 6035 kalau dinyalakan keluar kode E 224,kenapa yaa????mohon bantuanx....thanks.....
Oct 01, 2009 | Canon NP 6035 Copier
Cfm Daikin R410a Split System Air Conditioner Logo
27 people viewed this question
Top Cfm Heating & Cooling Experts
Dan Webster
Dan Webster
David Payne
David Payne
Donni Steen
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
