Question about SanDisk Sansa e250 MP3 Player
Sansa e260 4 gb mp3 player
My sansa e260 4 gb mp3 player always restarts itself when i shut it off then when i turn it back on it says all the languages i should select but all of my music is there and i need to fix this problem so i can download the sansa update for the base station what should i do cuz i need help please
  • 32 Answers
You could reinstall the firmware (what makes the sansa work). Its pretty easy to do, no need of downloading/installig, its already all in the sansa. You just need a computer How do I restore the firmware Firstly, place the e260 in restore mode. To do this, follow these steps 1. Push the Hold button on top of the e260 to the right. 2. Hold in the record button 3. Press and release the Menu button 4. The device will now go into Restore Mode. If you have not already connected the USB cable to your PC, it will direct you to do so. 5. The root directory of the device will open up on the PC screen. Now drag and drop the two files Firmware into into the e260 root directory. You will find a copy of the two firmware files zipped up elsewhere on these forums 6. Push the Hold button on the e260 back to the left 7. Unplug the USB cable from the PC. The e260 will now reboot, writing the new firmware images to the correct location. 8. This process will have wiped all your music files. You will now need to re-synch.
Posted on Jun 29, 2007
  • Ben oit
    Ben oit Jun 29, 2007
    ACTUALLY CLICK HERE, YOU HAVE ALL THE FILES, AND INSTRUCTIONS YOU NEED. (don't forget to rank me)
    http://www.anythingbutipod.com/forum/sho...
Some how or another I got my MP3 t read out a foreign language and I can't get back to english
Try to shut down your system. Restart and go into either settings, or language, it should be simple enough. However it may take some looking to find depending on which MP3 you have. It ususally however is in the language setting.
Mar 19, 2010 | SanDisk Sansa MP3 Player
My sansa clip plus 4 GB is not in english how can I change it so it is?
From main menu, select Settings (picture with 4 bars), find FM......, then go up ONE and select it (this is language), you can go up or down to find English language.
Good luck
Dec 28, 2009 | SanDisk Sansa Clip MP3 Player
Freezes, then Shuts Off
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
May 24, 2008 | SanDisk Sansa e250 MP3 Player
Stuck in language mode
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
May 13, 2008 | SanDisk Sansa e260 MP3 Player
Changing language
You should turn on the mp3 player (duh!) and go to settings. On the menu, go to "language". Then select "English" or whatever language you want. I hope that helps and works!
Apr 12, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Please Help
I think there is a language option in the Settings setup. Scroll down from Menu (music,radio,voive,photos,settings). Scroll down to Language. Select English or whatever.
Apr 08, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
My son's c250 shuts itself off after a minute.
-Tha Mp3 Doctor
Apr 02, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Mp3
Have you tried holding the power button down for about 30-60 seconds? It should power off itself off. You should be able to then power it back on and it work normally.
You might try a firmware update on your daughter's. Look at solution 4 here: http://www.fixya.com/support/t131894-format_sansa_e250
I works for any Sansa e series.
Feb 26, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e250 keeps shutting down
try and see if it is in MY COMPUTER if it is there download the newest firmware and update it if that doesn't work uninstall the mp3 player from your computer and then installit again.
May 20, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
337 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
