Question about Vacuums
Roller will not turn - Vacuums
    Sergeant:
  • 391 Answers
Conmaur102:
I don't know what type of vacuum you have, but you should check the drive belt to see if it is damaged. Remove the sole plate (at the bottom of the head) and remove the belt and roller (called the beater bar). check the bearings at each end of the beater bar (they must roll easily and smoothly). If they are bound up, pull them off of the ends of the beater bar and remove the hair, strings, and fibers wound around the end of the beater bar. Lubricate the bearings with light machine oil, and spin them by hand until they spin freely. Reinstall the belt and beater bar, and reinstall the sole plate. While you are at it... check the hose and head to make sure they are not clogged.
Posted on Jan 06, 2013
The brush roller will not turn.The roller is about a year old and was working fine. The ends turn
If the roller ends turn (are not jammed by hair etc.), then there are tthree things to look at:
1. Is the belt that drives the roller in good shape?
2. Is the belt engaged on the motor shaft
3. Is the motor turning?
Dec 16, 2015 | Kirby G3, G4, G5, G6, Ultimate, Diamond,...
Why the Dyson dc 41 roller brush will not turn?
Try these steps:
  • Check the button that turns off the roller brush to make sure you didn't press it by accident.
  • Unplug the vacuum and clear pet hair and other debris off the roller brush. It may stop as a safety feature if the roller brush is too restricted.
  • Make sure the belt to the roller brush is placed correctly and not broken.
  • Press the roller brush reset button. It may be located on the side of the vacuum's head, or inside the handle. The switch may need to be replaced if it's defective.
  • The roller brush is disabled while the handle is in the upright position, so tilt the handle backwards while testing the roller brush.
I hope that helps you!
Jun 21, 2014 | Dyson Dc 41 Ball
Problem with Electrolux Vacuum Cleaner, MDL EL8501A. Brush Roller will not turn
try pushing the reset button..its a little red usually located on the right side of the nozzle cover..
May 27, 2014 | Electrolux Versatility Bagless Upright...
Roller not turning when vaccuming
just had the same exact issue with mine - took everything apart - found that the swivel roller brush wasnt turning. it was not any belt issues or motor issues. took out brush roller - held in my hand by holding just the hand cap still - and tried turning the roller with my other hand. roller would not turn at all but is supposed to with no effort. on some models the end caps pop off but most are one piece and are just discarded and a new roller bought - seems to be $10-$20 for one for most dirt devils and under $10 shipping in north america. you can try something down the side of the roller and end cap like a razor - i did cut lose some crud and it works - but roller still stops on 2 of 4 settings on the rug because of this. i've already ordered a new one.
Mar 11, 2013 | Dirt Devil Vacuums
After turning on power , brush roller freezes and indicator light turns red
try turning the roller by hand UNPLUG VACUUM FIRST
it should turn very easy, otherwise it is binding
all uprights have this problem eventually
hair and fibers get in roller bushing and seize
luckily disassembling is relatively easy, same procedure as replacing the small belt that drives the roller. Take the extra step and take out the roller slip off bushings and clean everything
have fun
alex
Feb 06, 2012 | Euro-Pro NV22 Shark Navigator Bagless...
Beater bar not turning
The number one cause of the "beater bar" (or brush roller) not rotating is a broken belt.
The number two cause of brushes not rotating is that something is jammed & wound around the roller, preventing it from rotating.
For the belt: If you remove the screws holding the bottom plate, you should see one (or maybe two) short, wide rubber belt(s) that goes around the roller.
If this is broken, it's easy to replace. They do break because of age and wear. One of the leading causes of breakage is when the roller gets something - a curtain cord, for example - wrapped around it. If you don't immediately shut off the vacuum & remove the cord, the belt will continue to try to turn the roller (which can't turn), and this generates a lot of heat in just a few seconds.
You can find belts at places like Sears, Home Depot, or your local vacuum shop.
For just the roller: Turn the vacuum over on its side and inspect the roller. Will it turn? Can you see something wound around it that's jamming it? While you here, take a minute and clean the roller... including using scissors or a knife to snip & remove wound hairs & threads. A clean and healthy roller will help to keep your belt happy!
Mar 03, 2011 | Cirrus CR99 Bagged Upright Vacuum
The roller brush will not turn. The belt is not
Sometimes the belt can stretch cause the roller to not turn. Also make sure the roller brush is free of any debris.
Use this link to access your vacuum to change belt or clean the roller brush.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps.
Jan 27, 2010 | Hoover U5068-900 Sprint Upright Vacuum
Roller quit working - but belt still attached
try turning the rollers by hand,,, if they turn,,, can you hold the rollers and still turn the belt,,(dont turn on the motor) ,,, if so,, its the belt sliping on the rollers
and the fix is,,,change the belt for a new one,,,
i hope this has helped you
Oct 26, 2009 | Hoover Vacuums
Roller brush of my dyson dc07 isn't turning...
it migh be the belt.check your belt or it is the brushroll is stuck.(from to much hair ect.)
Jun 29, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I can't get the power brush belt on tight. Am I missing something?
I don't know what brand of vacuum you have, but the belts on most vacuums should be changed approx. once a year. The belt can look fine, but is stretched and won't have the necessary tension to turn the roller. It is possible that the roller is in need of servicing. If the bearings in the roller are fouled with dirt and hair, they will not turn properly and a new belt will not solve your problem. Take the roller out of the machine and turn the end caps by hand. They should turn freely. Once you've determined that the roller is o.k., install a new belt, turn the roller by hand to make sure that nothing is jammed and then try the machine again.
Feb 01, 2008 | Vacuums
Vacuums Logo
75 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
