Question about Kohler K-692-VS Clairette kitchen sink faucet K-692-VS. Kitchen Faucets vibrant stainless. In polished chrome K-692-CP, brushed nickel K-692-BN, white K-692-0, black K-692-7, brushed chrome K-692-G. Clairette kitchen sink faucet K-692-VS. Swing spout: 9-1/2
The kitchen sink faucet is clogged
The water pressure is very low and I can't figure out how to get it to spray or go better than low stream.
    New Friend:
  • 51 Answers
If it just the hot or just the cold then it will be the shutoff valve not the faucet. replace the valve/s under the sink Try checking the screen in the head of the faucet for sand. If it does not have a screen(some dont) then it will have a restrictor usually green in color that may have debris inside of it.
Posted on Jan 06, 2013
I have a brand new moen muirfield high arc faucet with low pressure at spout but good pressure at side spray what can i do to get better pressure at spout
clevine336-
The design of a hand sprayer is meant to provide a higher pressure spray (the smaller outlet size means greater velocity in the water coming out of the sprayer head). That said, there could be something constricting the water flow in your faucet. If you unscrew the aerator on the end of the faucet do you get better pressure? Is the screen in the aerator clogged with sediment or mineral deposits? If this is the case you may have water requiring periodic cleaning of the aerator.
Hope this helps.
Regards,
DIYpro
May 01, 2011 | Moen Muirfield Kitchen Faucet with Side...
My kitchen faucet has low water pressure both hot & cold. My faucet is a Bixby 538. I removed the spray head and the pressure is still very low. The pressure is good up to the shut off valves under...
If you have pressure to the shut off valves then most likely your shut off valves are not fully opening, I would recommend you replace both valves, they build up water deposits in them a lot of the times. The other possibility is the faucet itself has a water saver filter built into it. A lot of the new faucets have water savers built into them now.
Mar 15, 2011 | Price Pfister Plumbing
Low water pressure
Remove the spray head and point the hose into the sink drain. Turn the faucet on. If you have good pressure, cal American Standard for a free replacement spray head.
If you still have low water pressure without the spray head, ask them for a new faucet cartridge.
After replacing the faucet cartridge, if you still have low water pressure you will need to ask for a new faucet, possibly free if yours is still under warranty.
Sep 07, 2010 | American Standard Kitchen Faucet 6310 020...
Low stream
these faucets have a single handel, and have a cartage that can be taken out and cleaned. Low water pressure is caused by minerals in the water to build up in the cartage and slow down water flow.
Mar 28, 2010 | Kohler K-10416-BN Fort½ Single Control...
Kohler K-12177 low water pressure output. Removed
check valves under sink make shure tey are all the way on but spray them into a bucket if you can to see if they are ok.
Oct 25, 2009 | Kohler Model 10433: Fort® Single-control...
Small streams of water spray come out at an angle to the main stream causing water to spray over the sink and wet the operator. In checking the filter I find it to be clean with no obstructions. The errant...
You need to reduce the pressure to the tap, if you look at the isolator valves beneath the tap, using a screwdriver turn the isolator valve screw until it stops spraying.
Ihope this helps
Jul 07, 2009 | American Standard Kitchen Faucet 6310 020...
Low water flow and pressure
remove aerator and cart. and soak in limeaway over night
May 21, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Water pressure very low
Sounds like the cartridge needs to be cleaned or replaced. May be clogged or faulty. This requires turning off water under the sink and pretty much taking the faucet apart.
May 03, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Kohler K-692-VS Clairette kitchen sink faucet K-692-VS. Kitchen Faucets vibrant stainless. In polished chrome K-692-CP, brushed nickel K-692-BN, white K-692-0, black K-692-7, brushed chrome K-692-G. Clairette kitchen sink faucet K-692-VS. Swing spout: 9-1/2 Logo
197 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
