Question about Garden
How do i get the pulley and the blade holder of the crank shaft
Dose it screw off or pulloff
  • 433 Answers
What brand/
What Model?
Most have a key held on the shaft by a bolt down the senter of the shaft or a set screw.
After bolt or set screw is removed you will need a puller to remove.
Posted on Jan 06, 2013
  • renard_r_s
    renard_r_s Jan 08, 2013
    Thanks That Worked
Need diagram for belt instalation for murray 46" cut
Select Index Numbers here:
2 Asm, Jshaft Housing Head W
3 Q2 Pulley , 46"
4 Shaft, Splined Jacks
6 Nut, Pulley
7 Hub, Blade Adaptor
8 Q4 Blade 46" Mulcher
9 Washer, Bellevile(ard
10 Washer Hardened (ard
11 Nut Hex (ards)
12 Screw, 3/8, 16X1.25
24 Rod Belt Guide
25 Belt Cross Drive Ja
26 Belt Primary 46" J
34 Bracket Cover
35 Bracket, Pulley Cover
36 Qx Lburg# 094605E700 -INACTIVE-
37 Use Lburg# 093349 Zi -INACTIVE-
38 5/16, 18 Hexwdfllk Wh
39 Screw, 5/16, 18X.75HH
40 Cover, Pulley Right
41 Screw, 10, 16 .190X.62
72 711327
72-1 Wheel, Gauge
72-2 Bolt, .500X3.275HHSH3
72-3 Spacer, Slev .515X1.
72-4 Nut, 3/8, 16 Hxctrlkj
72-5 Qxcolor Code Require -INACTIVE-
79 Pin Detent Ring (DP5
80 Asm, Mulcher Plug 46
81 Bolt Carriage (ards
82 Nut, Wing (ards)
89 Zerk, Grease Fitting
Apr 21, 2014 | Murray 46 Primary Lawn Mower Blade Belt...
Blade walks off the drive wheels
If the blade is walking off the wheels, the wheels are out of alignment with each other. This can be caused by loose screws that hold wheels on their pulley shaft, a worn or lose pulley shaft, worn or broken bearings, ect. Anything that holds or supports the wheels can be lose or worn to the point the wheels are out of alignment which affects the tracking of the blade.
Jan 24, 2013 | Dewalt D28770 Hd Deep Cut Variable Speed...
What holds pully on shaft for lawn keeper blade
I have an old model Lawn Keeper gas edger with a 2HP Briggs and Stratton engine. It uses a 30" fan belt to drive the cutting blade and both pulleys have an alllen head set screw holding the pulleys to the shafts. The pulleys are cast aluminum and the set screw and shafts are steel so I find need penetrating oil and heat to loosen the set screw in order to push the drive pulley further on the shaft to make room to replace the drive belt.
May 17, 2012 | Mtd 25B-520D200 CA Gas Lawn Edger
How do you remove crank shaft pulley from 99 ford explorer.
You need a puller called a harmonic balancer pulley . You can get one for 25 dollars at the auto parts store . Or some stores will if you leave a doposit let you use it they figure your going to by parts from them Im not suppose to mention names xuto zone dose this And don't loose the key on the crank shaft into the oil pan
Jun 11, 2011 | Ford Explorer Cars & Trucks
I need a manual or step by step instructions to change the belt on my Toro Personal Pace mower
The mower should be drained of gas and drain the motor oil before starting procedure.
Disconnect spark plug wire from spark plug.
Motor side of the belt:
Remove two bolts under the lawn mower body which holds the top cover over the drive belt.
Remove the belt guard that is around the pulley on the crank shaft.
Then work the belt around the blade and off the the drive pulley.
While blade is removed, sharpen or replace as necessary.
Transmission side of the belt:
Remove the "S" clip on handle for speed / traction cable
Remove the plastic "Rear Baffle" two screws on each side on frame in front of rear wheels one screw in the rear
With the baffle removed, rotate the drive shaft and transmission to gain access
to the pulley drive belt guard, it is held in place with three screws.
Once belt guard is removed, you can easily remove the drive belt
Reverse procedure to replace the belt.
Lubricate drive Axel bearings, wheel bearings, control cables, as necessary.
Replace all fluids as necessary.
Read more: http://wiki.answers.com/Q/How_do_you_change_drive_belt_on_toro_lawn_mower#ixzz1MMJlZFMZ
May 14, 2011 | Toro Personal Pace CARB Walk Power Mower
We own a Dewalt DW735 13" planer. Have lost or misplaced the owner's manual. We need to reverse the knives for the first time, and do not know how to do it.
Unplug the machine then crank open the head up as far as it will go. Underneath, in the middle of the head you'll find two feed rollers and a cutter head with the blades on it. Even dull the blades are very sharp so work carefully. Each blade is held in place by a blade holder and eight allen screws. Remove all eight allen screws and the holder and blade will fall out. If they have excessive sawdust or tree goo on them they may need a bump from the plastic end of a screw driver to knock them loose. Keep track of how they come off so you can put them back on the same way only with the blade turned around. The top of the blade holder will fit into a channel in the blade so they'll all go back in lined up correctly. Turn the cutter head carefully to get at the other blade(s) to change them.
Nov 15, 2010 | Garden
How to replace front cup holder - V40. I have the new cupholder to replace the broken one. But I Need instructions on how to take the broken one out and replace with the new one . Looks like radio module...
hy!You can pull off the panel what is over the bezel,and there is two screws.Pull off the radio and there is 3 screws.And now you can pulloff the bezel. (bezel-radio holder...
http://cgi.ebay.com/ebaymotors/2000-volvo-s40-v40-radio-bezel-cup-holder-_W0QQcmdZViewItemQQhashZitem19bc67491cQQitemZ110535067932QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Aug 13, 2009 | 2000 Volvo V40
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
