Question about Samsung Galaxy Tab 2
My samsung tablet wont pick up wifi at my house authentication error
My tablet wont let me go on line wont pick up the wifi it keeps saying authentication error occurred
What does authentication error mean when I try to connect to my wifi?
You need to input the authentification code which was supplied with your router.
Aug 09, 2015 | Tablets & eReaders
Will not let me connect to wi-fi it is not my wi-fi servce. it just keeps saying authentication problem
It will say Authenticating problem unless you have the passkey to the other WiFi networks. So unless its your WiFi or an open network you won't be able to connect.But you can try rebooting your device.
Apr 13, 2015 | Nextbook Premium 8 Se Android
How do I get wi-fi connection. I have inputted information for the wi-fi it says saved, then when you go to connect it says authentication problem and cannot complete registration.
Hi
To connect to a WiFi system, you may need 3 pieces of information:
A username
A password
An encryption key
Once you have successfully linked to a WiFi access point then your tablet will remember the settings until told to forget them.
A lot of the time you may only need the encryption key, and if the tablet detects a WiFi access point then if you tap on that in wireless settings then it will either connect automatically or ask you for some sort of code - the encryption key. If this is not entered correctly then it will return an authentication problem/error. In order to connect you have to have this code. Also bear n mind that the code may or may not be case sensitive, and that the authentication type for both router and tablet needs to be the same. It is possible that you will only be able to change the authentication type on the Aceess Point / router and not on the tablet.
Cheers
Dec 25, 2014 | Tablets & eReaders
Authentication problem
trying dumbing down the authentication on your wifi router. Try these:
turn off 40mhz wide channels
try wpa instead of wpa2
try tkip instead of aes
if all else fails, try wep.
Feb 11, 2014 | Craig CMP741d Tablet
Authentication problem with wifi
"Authentication Error" usually means when you are clicking on the desired wi-fi network and putting in your password you are making a small error in the password. ChecK:
a - You are putting in the correct CaSe. Most are CaSe SpEcIfIc so if it asks for "F" it means "F" and not "f";
b - You are not leaving any spaces before or after the password (some tablets especially seem to leave spaces.)
c - You are possibly putting in the Router Password. This is useless! you need to out in your Wireless Network KEY.
It came with your ISP letter or on a little card or is printed on the router
in the form of:
Name (SSID) Goodwombat45837
Key: HG56TY78JK88
You would type in HG56TY78JK88
Note hg56ty78jk88 would FAIL, you have put in lower case.
Hope this helps a bit.
Jan 21, 2014 | SVP Tablet PC Android WiFi A13
I just got my kurio 7s last week and now the wifi wont work. the wifi turns on and its picking up my router even says it has perfect signal i hit connect then it keeps going through this 10 min ****...
If you can click on your wifi and pick "forget" do that and then restart the tablet and try again. If that doesn't work try going to settings and resetting it to factory then it will be like a new one, if you can do it without wifi some tablets wont let you past the wifi screen until you sign on.
Apr 03, 2017 | Techno Source Kurio Kids Tablet With...
Authentication problem connecting to wifi
Can't get unit to connect to my home wifi , keeps giving message Authentication Problem
May 12, 2012 | Polaroid Tablet Computer PMID701
Connecting tablet to internet
I have no connection on my android tablet and when I try to connect it keep say authentication problem
Dec 21, 2011 | Tablets & eReaders
Samsung Galaxy Tab 2 Logo
793 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
