Question about Maytag Bravos MTW6600T Top Load Washer
Tub dislocated The entire tub is banging against the sides of the interior of the washer.
SOURCE: the tub in my washer likes to beat up against the sides of the machine during spin cycle
i beleive your problem is a worn Snubber ring it about $4.30
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1055142&PPStack=1
you should be able to get it at any appliance parts dealer
Posted on Nov 20, 2007
MalKontent68
  • 748 Answers
SOURCE: My Maytag goes out of balance and bangs loudly
This is usually due to the floor not being perfectly level, and as a consequence the washing machine not standing firmly on all 4 supports.
There should be at least 2 adjustable feet under the machine, try to make it stand as level as possible, with uniform load on all four.
If you have a bubble level it may help you establish, if there's an obvious slope on your floor and adjust the machine so that it's well levelled.
Posted on Oct 30, 2009
craig6773
  • 116 Answers
SOURCE: the inside of washer was spinning and started
Your upper supports and/or rollers have let go. This could be from a broken part or from mounting bolts working loose. You will need to remove the top to inspect the issue. If you are not mechanically inclined you should call Maytag for service repair.
U.S. 1-800-688-9900 Canada 1-800-688-2002
Posted on Nov 24, 2010
SOURCE: Maytag HAV4657EWW tub bangs during spin
This washing machine has self-leveling rear legs. Tilt the machine up on the front legs and you'll hear the back legs drop down to re-level itself. Center the basket and restart.
Posted on Jan 03, 2011
  • 6277 Answers
SOURCE: My washer drum bangs against only the front of the
(I would start with checking the balance of the whole machine- guidance notes follow!)
I mostly answer front load problems but ' out of balance' is a common problem with both!
So- I don't know your particular machine but the initial cure is the same.
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine (sorry about my UK spelling!) and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
Good luck,
John C
Posted on Mar 04, 2011
Drum is loose during Spin and Rinse cycle and banging against side of washer
If it is under warranty, call Whirlpool at 1-866-698-2538. If it is out of warranty, try running the washer with no clothes in it in spin cycle. If it runs fine empty, it may be that when you had clothes in it they were not balanced evenly in the tub. If it runs off balance when empty, then a spring may have broken or come off. Contact an appliance repairman.
Oct 31, 2013 | Whirlpool WTW4880AW 3.4 cu. ft. Top Load...
The tub moves to freely and bangs on the washer sides
The tub shouldn't bang on the inside of the washer cabinet, as you already know. That is not a "normal" way for it to fail. Rather, I suspect something else. First try this: If you have your washer right next to your dryer, the washer itself is probably banging against the dryer during specific times during the wash - but most likely during the spin cycle. If you spread them apart a little bit - or stuff a towel or two between them, you may find that it stops banging. The washer may also be hitting something other the dry, too. Check all around the washer - try to keep and inch or two between it and anything else. If it still is banging - then something else is causing it.
Jun 10, 2011 | Maytag Washing Machines
When washer goes into spin cycle it starts to tub starts to bang against side walls and shortly after error out, with an error on electronic display. Kenmore Elite Oasis
either unit is unlevel or one of the tub supports has come disconnected .... these washers have a slanted top lid so you must put level at side of washer on front and both sides and check front to back with level at side cabine seam as your leveling point
Jan 24, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore model # 20642 991 leaks water when it spins (mostly with large loads) and the barrel inside seems to be loose or something because it bangs hard against the inside - sounds like the whole...
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub. The banging noise is due to being unbalanced. You may need to replace the balance ring on the top of the drum inside the washer. Watch this Video to see if this is how your machine is acting.
Nov 26, 2010 | Kenmore Washing Machines
I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
The washer tub was not bolted down during the move could it have caused the large creases in the back sides of the washer.
More than likely what has happened is the interior drum assy has banged against the back of the washer, or something has come adrift and caused the damage, I would not advise you to use it until you check it out.
Please rate my soution.
thanks
Nov 11, 2009 | Amana Washing Machines
Performa spinning banging problem
I assume it is not balanced. Try putting sponges under the feet of the washer.
Jan 06, 2009 | Washing Machines
Whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
Dec 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machine Suspension Problem?
smirkin, the question here is if the basket is listing against the tub or the whole tub and basket is listing. If the basket is listing and banging around it could be the drive block has worn or broken. I will attach a photo of one. If the whole tub is listing it could be a spring that broke. You can remove the front panel of the washer by pressing in on the two clips on each side of the washer top, The front panel should drop and pull out. You can see if any of the suspension sprins broke. The drive block is located under the basket. The agitator and basket have to be removed to change it out. Take a look at the attachments...Catriver..post back
Sep 07, 2006 | Whirlpool LTE6234D Top Load Stacked...
Maytag Bravos MTW6600T Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
