Question about Vacuums
Can i remove the hose from the base on hoover turbopower 4500
reddevil6
  • 1673 Answers
SOURCE: hoover belt replacement
Turn vac. over, remove the buttom plate over the brush roll, then at the bottom edge of the top cover, using a flat blade screwdriver, insert into the slots and pry up to unlock the tabs, then the top cover will come off. Put the belt on the brush roll and feed the belt thru the opening and put stretch it over the motor shaft. Put the top cover back on and push to lock the tabs.
Posted on Jan 29, 2008
  • 1214 Answers
SOURCE: I can't seem to find
It's on the Hoover website, I just looked it up.
www.hoover.com F6213900
Let me know if you need anything else.
Posted on Feb 01, 2009
  • 190 Answers
SOURCE: How to change the belt in the Hoover TurboPower
Please see pages 11 thru 13 on the User Manual.
You may use this link to access:
http://www.hoover.com/pdfs/manuals/U5046930.pdf
Posted on Oct 03, 2009
Vac Belts
  • 701 Answers
SOURCE: how to change a belt on a hoover turbopower 1700
You can get the replacement belt you need and view the manual with instructions here:
Hoover U5046-930 Belt and Manual
Posted on Dec 06, 2009
SOURCE: Hoover Turbopower Wind Tunnel V2 - clogged -
i took off the bottom black piece...removed the brushes ..took a coathanger and went down in silver dollar sized hole and got a big clog out...i also removed the black hose on the back at the very bottom...and used a coathanger up in there as well. mine is picking up some..but ive still gotta clog myself...i was hoping to find an answer here...-_-
Posted on Feb 10, 2010
Help - vacuum cleaner heating up and stopped working
Check for clogs in the hose and suction path. Replace bag and filters. The vac is designed to turn off when over heated.
Sep 10, 2014 | Hoover U59 WindTunnel TurboPOWER Bagged...
I have a Hoover Turbopower 5100 . I have power, and my spinner turns. But I have no suckson power. I look for and blockage. couldn't find a thing. what's wrong?
Same problem here, after 1 month of use, it just wont suck on the bottom side, the hose works correctly with the accessories, but the bottom wont suck, the brush works fine by the way. I removed the hood checked the inside, looked for clogs and nothing.
Oct 01, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
When I switch it on the plastic compartment which holds the bag starts to be sucked in towards the bag and there is no suction at the end of the hose
Your Hoover U5076 has a clog. Fist unplug the vacuum from the wall socket. Remove the attachement hose from the door on the head, close the door. Remove the screw just below the main bag compartment, with a phillips or flat head screw driver. Be sure not to loose the nut in back. Hold the base down with your foot and pull up on the handle to sperate the two pieces. The lower portion revieled is the exhaust for the dirt from the motor and that is where your clog should be. Use a flat head screw drive to remove what is there so you have a clean path. If there is no clog there check the up portion that you pulled off for a clog, you may need a coat hanger to dislodge the clog. Once the path way is clear you can reassemble the vacuum and it will work fine.
Apr 20, 2010 | Hoover Turbopower Dual U5076 Vacuum
The Hoover Steamvac Widepath will NOT pick up water. The dispenser with cleaner DOES have water. The TANK that would receive the dirty water is NOT full. All tanks are on properly and the machine will...
Sounds like a clogged air path (no vacuum action) from the floor pick-up to the collection tank. Take the tanks off and deal with the vacuum problem alone. The collection tank should have a air exit vent--is it clear? Check the interior hose that you repaired--is it clogged? Remove the bottom plate and inspect the air path from it. Because this machine deals with water, clogs can become like concrete! Hope this helps!
Apr 12, 2010 | Hoover F6213-900 SteamVac Agility...
My Hoover Steamvac Widepath will NOT pickup the water after dispensing. I checked the hose inside the cleaner, there was a cut in the hose so I put electrical tape and completely sealed the cut. Still...
Hi, empty the recovery tank of the Hoover SteamVac if the cleaner fails to pick up dirt. Once the tank is full, many Hoover models have an automatic shutoff that stops the cleaner. If the does not resolve the pickup issue, check the hose of the machine and remove any blockage.
Examine the water tank if water does not dispense from the SteamVac. It could be empty and need of a refill, or you may not have locked the dispenser firmly in place. The detergent tank should also be looked at and filled if empty.
Take care
Not picking dirt and small items, doesnt to be working well.
make sure bag is empty and there isnt any cloggs in the hose or nozzle. If that is good, change the belt. these should be replaced every 6-12 months and when something gets caught in the brushroll
Apr 08, 2010 | Hoover U5264-930 TurboPower Bagged Upright...
Hoover Turbopower Wind Tunnel V2 - clogged - cannot find a way to get at the clog - HELP!
Jan 13, 2010 | Hoover U5753-900 WindTunnel Bagless...
I can't seem to find the direction guide for my Hoover F6213-900 Steam Vac PowerMax TurboPOWER
Feb 01, 2009 | Hoover F6213-900 SteamVac Agility...
Won't work cleaning tools
There is a clog somewhere.
Most likely at any bends or where the hose enters the main body of the vac.
Make sure it's unplugged.
Romove the hose, stretch it out straight and see if you can see through it.
If there arer any hard piped bends try running a pipe cleaner through it to see where the blockage is.
Again, it's likely where the hose base meets the vac housing.
Needle nose pliers com in handy for pulling out string, hair, rig fibers pet fur etc.
Dec 06, 2008 | Hoover U5264-930 TurboPower Bagged Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
