Question about LG RU-27FB30C TV
LG RU-27FB30C. It's blocked.
My dad got an LG RU-27FB30C (from a Hotel). Everything works ok, until I found that the menu button from the TV is blocked. Everytime that I press it, says "Key Locked". I bought a universal remote control, and when I press the Menu button, it doesn't show me anything.
I guess it's blocked because it was from Hotel. Is there anyway I can unblock it?
Http://www.newtvremotes.com/Mfrs/Zenith/ZenithTV/LP702.htm
VISIT THE ABOVE LINK AND ALSO SEARCH
RU-27FB30C on internet and you will get the manual
Posted on Mar 12, 2009
No color. i think it needs to be reset to factory spec
MAKE SURE TV SYSTEM IS CORRECT THEN GO FOR UOC CHECK UOC VOLTAGES ARE CORRECT
Feb 09, 2011 | LG RU-27FB30C TV
How do I reset the lamp hour meter after replacing the bulb on my LG LG RU-52SZ51D 52 in. Rear Projection HDTV-Ready Television?
Hi,press the menu button on the front panel
while holding button on panel press and hold the menu button on the remote control
service menu will appear and then keep pressing the menu button until you come to lamp hour resetting
press ok on remote
and now lamp hour is reset
good luck with it and God bless!
Nov 03, 2009 | Televison & Video
Key lock on my lg tv
Sounds like its been put into Hotel Mode. This is a mode normally found on Tv sets that are installed into Hotels Hense the Name this Greys out a lot of the tuning option on the Tv.
Give this ago and see if this will sort you out. Before I go any further be very Carefull in this menu as this is the hidden LG installer menu and I do not want you to brick you telly.
Hold down the menu button on the remote for Approx 5 seconds then type in 1105 This should bring up the hidden installer menu so that you can check that the Hotel mode is not set to on. Make sure this is set to off as This may be the cause of your problem.
Hope this helps you sort out your Telly. If so then please leave a thumbs up.
Cheers Little Dish Fitter
Oct 03, 2009 | Televison & Video
Lg hotel tv. t.v. button are locked out, only hotel remote works
Hold down the MENU button on the remote for approx 5 seconds. Then enter 1105 this will access the hidden hotel option on the LG tv so you can change whatever you like..
Cheers LITTLE DISH FITTER
Jun 08, 2009 | Televison & Video
MAGNAVOX TV BURNING SMELL TV WENT POP AND WENT OFF
Well that pop had something to do with the power components inside the TV frying. I would have to say there is nothing you can do to repair it as its dangerous to work on such things.
I wouln't waste my time bringing it to a repair shop they will probably tell you to just buy a new one.
Jan 05, 2009 | LG RU-27FB30C TV
Tv
check the output voltage on the emmiter of the line output transistor. it should be 95 volts.if not adjust voltage to 95 v and replace trnsistor with a new one-BUT11A and test.
Aug 22, 2007 | LG RU-27FB30C TV
Black and White !!!!!!!!!! aaaahhhhhh
As ther is no color & every thing normal. you have checked most of the things from outside. solution please check loose contact near chroma ic. check connector for loose. parts related to chroma section. finally chroma ic. good luck
Nov 24, 2006 | LG RU-27FB30C TV
LG RU-27FB30
what do you mean "knocked" Yes sir it sure does sound like the power supply specificly the stand by supply? Only real way to tell if you know anything about troubleshooting solid state electronics is to get a schematic and start at the beginni9ng of the supply and work your way over to the sweep supplys. On alot of sets the horizontal has to be good for the ,main switching supply to start up but in this case if it dosent click or make any sound I supect the main supply. Good luck
May 26, 2006 | LG RU-27FB30C TV
LG RU-27FB30C TV Logo
941 people viewed this question
Computer Repairing
Computer Repairing
