Question about Plumbing
Bgr050 pump doesnt pump enough pressure to water garden, take a shower etc
Pump is connected to above ground tank then to house piping. 1inch into pump 1inch line through house and garden. I have checked for air leaks and cant find any. Pump runs but only pumps approx. 8 ltrs min but tank head pressure is approx. 3 ltrs min, can you help me with this problem as it is a brand new pump to replace the previous wornout pump.
  • 10 Answers
SOURCE: pump works but is not pumping water
IT SOUNDS AS IF THE PUMP IS NOT PRIMED. MAKE SURE THE THE PUMP IS FUL OF WATER
Posted on Jan 11, 2009
Healeyman
  • 1198 Answers
SOURCE: pump 30/50lbs pumps up to 50 shuts off pressure drops to 32lbs
Look for a place in the pipe from the pump to the house where an air pocket could form. That will fool the pump.
Posted on Apr 05, 2009
  • 6 Answers
SOURCE: i have a flotec water pump that sits on top of my
if the pump is working correctly, it can either be, need more water to prime it, or something in the well, such as low water, plugged filter, etc....sometimes when you have a system that is intermittently used, it can take 20 or 30 minutes of continuous priming to get it to pull, enough water to maintain the prime.
Posted on Apr 06, 2009
  • 1114 Answers
SOURCE: Pump will not come up to pressure and turn off!
With no leaks in line and assuming the jet is not embedded in debris at bottom of well, try priming the pump again and getting all the air out.
Posted on Jul 08, 2009
  • 1114 Answers
SOURCE: have installed a 1/2 HP wayne jet pump, getting water ,
If we go down the list of possible causes, it may help;
  • All fitting on the new pump and jet are tight.
  • No break in the well line
  • FOOT valve operating OK. If the foot valve is not operating correctly, the pump can lose its prime and **** air into the system.
  • New pump has been purged of air(primed adequately)
  • holding tank has appropriate pre charge
  • bladder in holding tank not ruptured.
How does a home well water system work?
Deep well.
Pressure valve located on front of above-ground-storage-tank will turn pump on-off depending on amount of water pressure inside tank.
When water is consumed inside home, the pressure valve responds to the lower pressure and closes electrical contacts... sending electricity to water well pump located deep underground.
The pump turns on and lifts water through a pipe into the above ground storage tank.
When the tank is full of water, the pressure valve senses the higher pressure and turns off electricity going to pump
Pump shuts off.
There is a one-way check valve on the water line going down to pump, and this keeps water from flowing back down into well.
The above ground tank maintains water pressure for the house.
When pressure is reduced by taking a shower, the pressure valve turns pump on again, and cycle repeats.
Aug 20, 2014 | Water Heaters
Karcher k3.00 lack of power
Are you using the same water supply as before when you had good pressure? Some house water lines have pressure reducers to protect your pipes and appliances. This can restrict the water flow and reduce the pressure the machine develops. If the flow surges (good, then weak, then good etc) you are not getting enough water to the pump. Try a larger diameter garden hose (5/8"). If you know where your water line enters the house, try the hose bib closest to it. Often times it is at street pressure instead of (reduced) house pressure.
Aug 03, 2014 | Karcher Garden
How much pressure should you have in the pressure tank itself.
That depends. City water? Shared well? Personal well? If you have your own well, it's pretty common to maintain about 50psi at the tank. City water may go to 100psi or higher, which is why many people have a pressure regulator installed to prevent it from going above about 65psi. I don't like to see anything above 65psi in a two-story house, or 50psi in a one-story house (it takes extra pressure to lift water higher); that's plenty of pressure to do everything you need to do, and not enough to blast the skin off your cheeks when you take a shower.
Jul 03, 2014 | Plumbing
No shower pressure in rv
Make sure you have enough water in the tank or city water hooked up. A pump will run and suck air if the level is low. it could force water to the sink, etc, but not the shower.
Are your valves for the water pump set correctly? Remote possibility someone installed a shut-off valve between the pump and shower.
Could be the pump is getting weak/leaking internally and can't build enough pressure.
Make sure the shower head is not clogged. Remove it from the hose and try again.
Apr 22, 2014 | RVs
My well is kicking on every 3to4 min.I have shut the water of at the whole house water filter and still no change.I have shut the well off and try to empty the pressur tank but cannot get it to empty out.I...
The problem is not in your pressure tank. Its in the well pipe going to the well, or down in the well casing. You have a leak in that pipe. This lets the pressure go down even when you have the whole house shut off. If you have a submersible pump, you will have to have it pulled and the pipe replaced. If its in the pipe going from the house to the well casing, you will have to dig it up and find the leak. Usually you will see water coming from the ground or the ground sunken in if there is a leak in the pipe from the well to the house.
Jul 24, 2011 | Plumbing
I want my shower to have more water pressure. I am on a well with my pressure valve on 90 pounds. I am willing to change the pipes under my house to change this situation. I am to the point of trying...
If your pressure gauge is up to 90 lbs, it should be pounding the **** out of you, Something is wrong, get another pressure dial on there and see if it is still reading 90 lbs. Then make sure the california water saver is taken out of the shower head, Then make sure there are no galvanized connections between pipes, like copper to plastic or iron to copper, the galv will corrode 10 times faster because of the electrolysis, and seal itself off. then if you have a pump motor that sits up top, not submersible, whack on the connection with a hammer to dislodge any pebbles or what ever in the pipe. If that doesn't do it, check the air pressure in the tank and see if it is water logged. bleed the tank, then fill it back up, or just pump some air into the top and see if changes anything. Hope this helps.
Aug 14, 2010 | Plumbing
Our water pressure in our house is gone. we have a well. do you think the well is out of water? do we just need to wait till it rains?
If you did manage to run enough water to dry the well, it should only be temporary, until enough groundwater flows back to your well. This should only take maybe an hour and shouldn't depend on frequent rain. If your well did respond to rain, your well would be quickly contaminated. However, there could be other problems. If you have the type of well where the pump is located down in the ground, and your water pressure doesn't come back soon, then you have a problem in that the pump is not working. If you have a "shallow well" type of pump, where the pump is located above ground (in your basement, or under the house) then the pump may have lost it's prime. A shallow-well pump needs the pump to be full of water before it can pump the water from the well.
Jul 30, 2010 | Plumbing
Green in the shower, sinks, and toilets
Hi:
I don’t think the green is Electrolysis, I think it is algae.
Do you see your electric bill going up? If not, then it is algae.
Did you have the water tested for algae? There are dozen or so different type of algae.
Do you have any of the pipe running above ground ? Most likely the algae is in the Poly pipe. Not the copper.
Nov 15, 2008 | Plumbing
Plumbing Logo
56 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
