Question about Samsung PN50C450 50 in. TV
SAMSUNG PLASMA TV PN50C450B1D HAS 2EA. VERTICAL MULTI-COLOR LINES 3.0 INCHES WIDE. IS THIS TV REPAIRABLE.
CAN 2EA. VERTICAL LINES MULTI-COLOR 3 INCHES WIDE BE REMOVED FROM THE RH SIDE OF THE SCREEN?
  • 579 Answers
SOURCE: 40 inch lcd blue line vertical
The display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Hope ya fix it!
Posted on Jan 06, 2008
  • 6 Answers
SOURCE: nec plasma tv 42MP4
these plasma vertical black lines are notorious. there's a video of a fix on this plasma tv repair site. good luck!
Posted on Jan 23, 2009
  • 118 Answers
SOURCE: Black Vertical Lines in screen
All I can tell you is that you maybe have left your T.V. on a channel that didn't move for so long, or maybe someone else did and it burnt the screen. Plasma's run off of plasma gas to create the great picture and they collect on the screen and stick. What you need to do is go to your menu and look for "screen burn protection" and put it on white and let it sit for 20 minutes. All of one color such as white doesn't harm your T.V. The only way anything burns is like a bright white line in front of a black background.
Posted on Jan 30, 2009
roety
  • 585 Answers
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
Posted on Aug 19, 2009
  • 3 Answers
SOURCE: I have multi color vertical lines on my plasma
un plug 5 min
Posted on Dec 30, 2009
My Samsung Plasma TV Model #PN50C450B1D has vertical lines on the right side. They are constant and are several colors. Any idea on how I can fix this? Thank you in advance!
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 29, 2016 | Samsung Televison & Video
Fix vertical lines on plasma tv
May 28, 2016 | Samsung PN50C450B1DXZA 50-inch Class...
Fix samsung plasma vertical black bar
Line faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 27, 2016 | Samsung PN50A450 50 in. Plasma HDTV
Colored "snow" vertical line an inch thick on Samsung plasma
That is the sustain and buffer boards. Try to find a repair shop to repair on the component/board level because the cost of new boards out weighs the replacement cost.
Best Regards,
Beach TV Repair
Jul 04, 2010 | Samsung PN50A450 50 in. Plasma HDTV
Samsung 52 Inch LCD 120hz. 3 inch wide vertical line on screen
This is a problem with the LCD panel. If the tv is out of warranty, I would call Samsung and see if they will pay for the panel and you pay for the labor. The panel is not cost effective to repair. If Samsung will not do anything you will need to buy a new tv.
Nov 16, 2008 | Televison & Video
Nec plasma tv 42MP4
Jul 29, 2008 | Samsung PPM42S3 42 in. Plasma Television
Samsung PN50C450 50 in. TV Logo
1,084 people viewed this question
Henry  Thomas
Henry Thomas
