Question about Refrigerators
Replacing Water Dispenser Lever of a Samsung RL41 Fridge-Freezer?
I need to know how to remove the cover to get access to the broken Water Dispenser Lever and the assocdiated Return Spring?
SOURCE: ice dispenser spring in door
There should be two slots in the bottom of the panel. Use a screwfriver to pop this out. You will have to unscrew the electrical panel to expose the dispenser area. Be wure to unplug the unit first and be careful not to break any wires.
Posted on Sep 23, 2008
larryyb
  • 291 Answers
SOURCE: BROKEN WATER SUPPLY LINE IN FREEZER DOOR
it should just snap off and on ,,,, something they are tuff to get loose
Posted on Nov 29, 2008
  • 56 Answers
SOURCE: ed25rfxfw01 whirlpool fridge water dispenser ...I have a slow drip from the dispenser hose. I assume I need a new water inlet valve. How do I access the inlet valve for replacing?
It should be on the right hand side in the back take off the compressor cover on the back should be 8 or so 1/4 screws nutdriver type and then two more hold on the water valve. If you have a RO system hooked up to refrig you may need to change the filters on the ro or just change the filter on the refrig. those two will also cause the water to drip thru the valve allowing it to drip on the front
Posted on May 30, 2009
SOURCE: Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Posted on Sep 20, 2009
  • 396 Answers
SOURCE: Samsung RS21DCNS Water dispenser freezing up
Sounds like you have the freezer temperature set too low.
Posted on Oct 10, 2009
Hi i have a Westinghouse side by side fridge freezer WSE6970SA there is no water at the dispenser . how do you remove the front panel from the water dispenser to remove it ?
https://www.bing.com/videos/search?q=replacing+water+switch+on+westinghouse+fridge+door&qpvt=replacing+water+switch+on+estinghouse+fridge+door&FORM=VDRE
Apr 19, 2017 | Westinghouse Refrigerators
How do you remove the, RL40 SBSW model Samsung fridge cover to replace the bulb?Thank youAdele
There are 2 plastic extrusions that clip in place. Pull sharply forward, or lever the sides gently up and down with a flat screwdriver above the bits that clip in. The bulb unscrews.
Apr 21, 2014 | KitchenAid KSF26C4XYY 26.0 cu. ft. Side by...
I have a samsung cool n cool american style fridge freezer with two tabs on the front. One for cool water and one for ice. The water works perfectly but no ice is being made to fill the bucket, why is
If the refrigerator water dispenser (or ice) is not working correctly the water supply tube(s) may be blocked. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined (this is most likely the culprit) , third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch (try this first), when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on or may just dispense one item. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
Mar 30, 2014 | Samsung Refrigerators
Fridge is not cooling down. Freezer is fine only the fridge. Plus the water dispenser - water is not that cold
These units like most fridge/freezers, actually cool the freezer first, then a damper opens that flows freezer air into the fridge side cooling it. The thermostat/switch controls the freezer, the refrigerator is controlled with a damper. The cold water storage tank is usually hidden in the bottom rear of the fridge, behind the vegetable bins, so if the fridge is not cold the H20 is also warm. I suggest you unplug the fridge, empty the freezer and remove the covers. Your issue could be a simple ice blockage of the air passage, or a stuck or broken damper control. Use Sears parts to look up a exploded view of your fridge. At minimum, you will learn a bit, and if you end up calling a service guy, he will know he cannot fool you and overcharge you.
Jan 08, 2011 | Cuisinart Private Reserve CWC-600 Wine...
Ice Dispenser lever broken
There are tiny clips but you wont see them you need a small screwdriver to lever under the bottom of the cover. Once you get one clip off you will see how the rest come off.
Mar 31, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Have a samsung American style fridge/freezer with water and ice dispenser. Water gets to the water dispenser but not to the ice cube maker. can not see anyway of getting to the pipe inside the...
verify on the back side of fridge sometimes you will see the water lines if not there's like a a cover that goes vertically if removed, probably you'll have access to water line its probably plugged up...
or sometimes air gets trapped in the supply line to purge just simply loosen the nut or fitting it should spit some water do this just enough to let air out about after 30 sec. if there was some air in the water line i should start to spit water...
hope i could be of help
Apr 13, 2008 | Refrigerators
Kenmore refrigerator
1. Remove the switch cap and unsnap the two (2) tabs at the bottom of the front cover from the
housing first. Pull the bottom out and lift and the front cover from the housing. (Fig. 27)
2. Remove the two (2) hex-head screws securing the metal control panel cover to the dispenser
housing. This will also free the control bracket from the housing although it will remain tethered
to the freezer door by the wiring harness. (Fig. 28)
3. Disconnect the wiring harness connectors from the terminals
on the switches and light fixture in the control bracket.
Removing the Dispenser Assembly
1. Do the previous three procedures.
2. Remove the eight (8) hex-head screws securing
the dispenser housing to the freezer door. (Fig. 29)
3. Carefully pull the housing from the door.
4. Pull the water supply tube from the top of the dispenser housing.
5. Pull the wiring harness leads from the dispenser housing.
6. Disconnect the wiring harness connectors to the electric
foil heater that should get you in there
Feb 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
