Virtual memory how to increase virtual memory on Windows xp
    President:
  • 623 Answers
  1. Right-click "My Computer" and choose "Properties"
  2. On the Advanced tab, under Performance, click "Settings".
  3. On the Advanced tab, under Virtual memory, click "Change".
  4. Under Drive [Volume Label], click the drive that contains the paging file you want to change.
  5. Under Paging file size for selected drive, click "Custom size", and type a new paging file size in megabytes in the Initial size (MB) or Maximum size (MB) box, and then click "Set".
Virtual Memory should be roughly 1.5 x the size of your installed RAM in case all data stored in Memory has to be written to the hard drive.
Don't forget to click "Set" after you entered the values, just clicking "OK" is not enough!
Just a tip: You can set the VM to "0", reboot your computer and then defragment the hard drive. When that is complete and you allocate the new VM space, it will reserve a continuous space on your drive, which results in better access times.
Let me know if you have any questions!
Posted on Jan 06, 2013
  • 27,725 Answers
If you find yourself running out of virtual memory, or keep getting messages telling you so, you might want to increase this to a more acceptable level using your computer's control settings
Click on Start and right-click on My Computer. Choose Properties. Click on the "Advanced" tab. Under "Performance," click on the "Settings" button. Under "Virtual Memory," click on the "Change" button. Here is where you decide the amount of virtual memory that you need to increase. Try a few hundred megabytes above the assigned amount.
also you might use a flash drive for more ram
If your computer seems slow, and you have already gone through making sure there are no viruses, spyware or adware on the system, it may be because your system needs more RAM. RAM is the short-term memory of the computer. It works with the processor to multi-task. RAM can easily be added to your system if you are not already at maximum capacity for your motherboard, and you have available slots. However, RAM can get expensive, and even after you max out your motherboard you may need more. Using a flash drive as RAM is a quick, easy and cheaper way to increase system memory.
Insert your flash drive into a USB port. If you have auto-play enabled, there should be an option in the menu that appears that says, "Speed Up My System" that will allow you to enable ReadyBoost. Click the "ReadyBoost" tab. To use the entire flash drive to increase RAM, click "Dedicate this device to ReadyBoost." To use less than the entire flash drive for ReadyBoost, click "Use this device" and move the slider to the amount of space you would like to use. Click "OK." Right click the drive letter, and choose properties. Look for the ReadyBoost Tab, and select it. Look for the option to enable the flash drive as RAM, and allocate the amount of space on the drive you wish to use as RAM. Remember, most systems max out at 4GB RAM. So if you have a drive larger than that, or 2GB RAM already, you need to remember this limitation so as to prevent damage to your system. Hope this helps.
Pc gets hang despite updated virus and daily cleaning thru various software and self cleaning too
follow this guide to increase virtual memory: http://www.ehow.com/how_2282429_increase-virtual-memory-windows-xpincrease-virtual-memory-windows-xp.html
the rule of thumb is 1.5 times the amount of ram so if you have 512mb set it to 768, 1 gb of ram = 1.5 gb virtual memory.
May 08, 2012 | Computers & Internet
How to increase virtual memory in my windows xp pro desktop
Hi ,
Go to the link
http://www.delete-computer-history.com/increase-virtual-memory.html
and you will know how to increase virtual memory.
Thanks for using FixYa.
Jun 03, 2011 | Computers & Internet
How to increase virtual memory in windows xp pro desktop
Hi ,
Go to the link
Jun 03, 2011 | Acer Aspire 5315 Notebook
How can i free space for my virtual memory ?i don't need a solution for increasing the size of virtual memory instead i want to free space that has been occupied in the virtual memory.
Hey, You got to free space on your hard drive. The virtual memory resides on your hard drive. but if the hard drive is getting full, this will reduce the virtual memory. So make home for virtual memory by free space on your hard drive.
Apr 27, 2011 | Microsoft Windows XP Professional SP2 for...
CAN YOU PLEASE TELL ME HOW MUCH VIRTUAL MEMORY DOES A PATRIOT 2006 LAPTOP HAVE
Virtual memory?
Virtual memory is created and used by windows operating system.
This value can be changed and solely depends on the hard drive space available.
Simply put There isnt any limit, nor a minimum. The amount of virtual memory depends on how much was set up and can be increased or decreased at any time.
The purpose of virtual memory is to allow windows to use part of your hard drive as rams.
virtual memory and rams (conventional memory are different things)
you can have as much or as little as u need. increasing it improves performance.
So No one can actually answer that question. Simply put any amount you want is the correct answer!.
Mar 01, 2010 | Computers & Internet
The instruction at "0x012cf496" referenced memory at "0x012cf496"
you should increase the virtual memory of system,to increase the virtual memory :-
->right click on my computer goto to properties tab
->then goto advanced tab
->performance setting
->advanced tab
->virtual memory
now increase the virtual memory with current
OR
:>type chkdsk command in dos
Jan 15, 2010 | Microsoft Windows XP Professional SP2 for...
Windows XP Sp2. Publisher98.
HI,
ITS A PROBLEM OF WINDOWS VIRTUAL MEMORY,INCREASE VIRTUAL MEMORY. MANAGE PROPERTIES..
TNKS
RABBANEES
Nov 05, 2009 | Microsoft Computers & Internet
I want to increase virtual memory of my computer
Hi
From Start Menu --> Open Control Panel
From the various icons listed, open --> System.
System Properties window will open.
Select "Advanced" tab from this.
From the Advanced tab Click the Performance--Settings button
Again from the Performance Options window that just opened select the advanced tab
From this Click the Change Button for Virtual Memory.
A new window for Virtual Memory opens
Select the partition on which your OS is installed [windows]
Then click the Custom Size --> radio button
The text box infront of Cutom Size will be active.
Enter the size as you wish but usually virtual memory is double the amount of RAM on your system.
eg.. If you have 1gb RAM then virtual memory can be less than or equal to 2gb.
But make sure your HDD has enough space to accomodate the virtual memory.
May 28, 2009 | Microsoft Windows XP Professional
I need to increase virtual memory
I don't wish to sound rude but if you don't know how to do this, you prolly should just let windows continue managing it. A few wrong keystrokes can have major repurcussions
Jul 15, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
