Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Inconsistent print quality - from black to blurred gray
This inconsistency alternates every other line. I have replaced both the black and colored ink cartridges. I have selected "clean" and "deep clean" on the menu as well as calibrating the print head through the menu. Nothing has fixed this problem.
  • glenandlucre Jan 21, 2009
    An "apprentice" responded to my problem saying that a new printhead is needed. I agree with this opinion. However, no one from your technical department has offered a way to obtain a new printhead. I hope that someone can respond. This is very frustrating.
  • glenandlucre Jan 22, 2009
    It seems that no one at Kodak's tech support cares about customer service since there are no responses that give a solution to my problem. If I have to replace this entire printer, I will never buy another Kodak product again! I'm sure that no one at Kodak cares about that either.
    Sergeant:
  • Kodak Expert
  • 285 Answers
Please don't say that
kodak is very good and your problem is VERY COMMON
If you call 1.800.421.6699 and select option 01 for prints missing black or color in, Kodak will send you a replacement printhead kit for free.
by the way, I don't work for kodak
Posted on Jan 28, 2009
CP2025 Inconsistent Color
make sure you are using Genuine HP toner or QUALITY COMPATIBLE toner cartridges. Try doing a color recalibration at least 3 times.
Dec 23, 2012 | HP laserjet Cp2025dn color Card Printer
Colors are blurred and printing offline. colors arent showing up. all toners are new. reset the default setting, and aligned but still doing same thing
hello , I may try doing a printer reconfiguration page or page alignment again.
working properly. Press ✔. Press 􀀙 until INFORMATION is highlighted.
Press ✔. Press 􀀙 until PRINT CONFIGURATION is highlighted. Press ✔ to
print the page. If the configuration page does not print, consult the CD User Guide for more info on task.
hope this solves it. if not,
you may try this :
Incorrect shade
The sealing tape has not been removed from
the print cartridge.
Remove the sealing tape from the print
cartridge for the color that is missing. See
Changing print cartridges.
Inconsistent colors after installing a print cartridge
Another print cartridge may be low. Check the supplies gauge on the control panel
or print a supplies status page. See Printer
information pages.
Print cartridges may be improperly installed. Verify that each print cartridge is installed properly
please give use more info to the problem if it still persists and we can try and pinpoint further
Mar 27, 2010 | HP LaserJet 4600dn Color Printer
Print, particularly black, is inconsistent. Keep
Follow www.kodak.com/go/itg and try the step by step solution.If issue persists,Call Kodak @1800 421 6699 and get a new printhead free of cost.....Printhead has gone bad and it is the part in which we install the ink cartridges.It takes the ink out of the cartridges and spit the ink on the papers,...Cheers and Enjoy.
Dec 24, 2009 | Kodak ESP 5 Printer
I have a Xerox 6250DP. it was working fine until I replace the black toner. Now, the quality of impression is poor and the black color appears and dissapears
I bet you used a Generic toner (Mediaq Science?)
this will contaminate the developer and cause poor prints. Vacuum, Replace developer, replace toner (Xerox Brand). Good to go.
Jul 03, 2009 | Xerox Phaser 6250DP Laser Printer
Verical lines of inconsistent or un-even printing,
In almost every case, the problem you describe can be traced back to 2 things. Dirty corona wire or dirty drum (or both). Pull out the toner cartridge, slide the wire cleaner back and forth a few times, clean the drum. The gently shake the toner cartridge from side to side to evenly distribute the toner and replace. This should solve your problem. Best of luck.
Greg
Jun 21, 2009 | Panasonic KX-FL501 Plain Paper Laser Fax
HP 1600 color laser printer--colors are out of sync
Check the following information please.
General print quality issues
Solving issues with color documents This section describes issues that can occur when you print in color. Color document issues Problem Cause Solution Only black is printing when the document should be printing in color.
c00659983.gif Color mode is not selected in your program or printer driver. Select color mode instead of grayscale mode. The correct printer driver might not be selected in the program. Select the correct printer driver. The device might not be correctly configured. Print a Configuration page.
One or more colors are not printing, or are inaccurate.
c00659984.gif Sealing tape might be on the print cartridges. Verify that the sealing tape has been completely removed from the print cartridges. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The device might be operating in excessively humid conditions. Verify that the device environment is within humidity specifications. One or more print cartridges might be low. If you are using non-HP print cartridges, no messages appear on the device control panel or in the HP Toolbox. Replace any low print cartridges. The control panel is set for override. Replace low or empty print cartridges. A color is printing inconsistently after you load a new print cartridge.
c00659985.gif Another print cartridge might be low. If you are using a non-HP print cartridge, it might be low or empty but you will receive no indication. Remove the print cartridge for the color that is printing inconsistently and reinstall it. The control panel is set for override. Replace low or empty print cartridges. The colors on the printed page do not match the colors as they appear on the screen.
c00659986.gif The colors on your computer monitor might differ from the device output. Select Screen Match in the Color tab of the printer driver. If extremely light colors or extremely dark colors on screen are not printing, your software program might interpret extremely light colors as white or extremely dark colors as black. If possible, avoid using extremely light or extremely dark colors. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The finish on the printed color page is inconsistent.
c00659987.gif The media might be too rough. Use a smooth paper or print media, such as a high-quality paper that is made for color laser printers. Generally, smoother media produces better results. Repetitive image defect ruler Use a repetitive image defect ruler to measure occurrences of repetitive image defects to help solve image quality problems. Place the ruler next to the first occurrence of the defect on the page. Find the distance between identical defects and see the Repetitive image defects table to identify the component that is causing the defect. Repetitive image defects Measurement Component 24.7 mm0.97 inch Developer sleeve 26.7 mm1.05 inches Charge roller 32.9 mm1.3 inches RS roller 37.7 mm1.48 inches Transfer roller 54.5 mm2.15 inches ETB rollers 56.6 mm2.22 inches Fuser sleeve 62.8 mm2.47 inches Pressure roller 75.4 mm2.97 inches OPC
Have a good evening
Jun 18, 2009 | HP LaserJet 1600 Printer
#5 black ink cartridge skips through the middle occasionally
Replacing the print head
The print head may need replacing if, after all print head and ink tank troubleshooting has been performed:
  • The nozzle test appears broken or to have horizontal white streaks.
  • One or more of the colors is missing from the Nozzle Test.
  • The colors are incorrect on the Nozzle Test.
  • A print head error is indicated on the unit.
  • The printer powers off when the print head is installed.
I hope it helps!!!
Nov 29, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
102 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
