Question about JVC Cybercam GR-D70 Mini DV Digital Camcorder
Jvc gr-d270u cassette mechanism won't close
  • 30 Answers
SOURCE: JVC GR-D270U- transfering pics from tape to computer
if you are using a desktop, you require a an addon card called IEEE 1394 firewire card, which you have to install it on your motherboard's PCI slot, then using the firewire cable which you get along with the card should be connected to the card and DV port of the camera, then using the MOVIE MAKER software of windows XP, you can download the video.
Posted on Aug 30, 2007
Bubbabear64
  • 2794 Answers
SOURCE: JVC Camcorder Model # GR-D270U
I think youre talking about safeguard mode.
Here is the manual if you don't have one:
http://resources.jvc.com/Resources/00/00/94/LYT1354-001A.pdf
See page 51. There should be an error indication number as well.
Posted on Jun 19, 2008
I thought this was a camera issue, but it ended up being a tape issue. So it shouldn't matter if you have the same model of the JVC mini camcorder as I did or not. Anyway, the tape has a tab that "locks" the tape to keep from recording over it accidently. I moved that tab and it started working. If your tape is stuck in the camera, you may have lost the tape already. Try to get it out of the camera without damaging the tape or the camera...more importantly the camera. You may have to take it to a professional to prevent damage. If you get it out undamaged, check to see if the tape is locked or not. Move the tab and try the tape in the camera again (unless you're afraid of it getting stuck again). In that case, try it in another camera. That's how I discovered that this was a tape issue rather than a camera issue...because I tried the same tape in a different camera and got the same error message. Don't despair if your tape comes out with part of it sticking out or crumpled, as long as it's not broken, you can salvage it. Even if it's broken, you can probably salvage the majority of the tape by taping it back together (call a professional, you may need special tape for this), just don't touch any of the undamaged tape or pull it out of the cassette too far and all you will lose is the damaged portion. I actually couldn't see the tab well enough to tell if it was in locked or unlocked mode since it's so tiny and my close-up vision is getting blurry, but I moved the tab to opposite of what it was and that seemed to do the trick. My mistake was in trying to save money with the cheaper tapes...next time I'll spend a little extra for the better tapes to avoid all this headache. Hope this helped. Have a great day!
Posted on Apr 08, 2009
  • 3 Answers
SOURCE: I have a used GR-D270U JVC camcorder, can't record w/it?
Open your view finder screen. There is a button there that says video/memory. push it down to the memory. The record button is at the back to the upper right of the battery. Hope this helps.
Posted on Apr 10, 2009
welcomejee
  • 10594 Answers
SOURCE: I put a new 4gb sandisk hc memory card into my jvc
Hardware of this camcorder supports up to 2GB memory card so 4GB is more than its capacity and causing error.
Try 1GB or 2GB memory card in camcorder.
Thanks.
Posted on Jul 25, 2010
What kind of memory card do i buy for my jvc gr-d270u
The GR-D270U uses SD cards. They should be available at just about any department, electronics, or office-supply store.
Make sure you get an SD card, not an SDHC card. While SDHC cards will fit into the slot, they are electronically incompatible and will not work.
Dec 30, 2011 | JVC GR-D270 Mini DV Digital Camcorder
Unit in safe mode,eject tape and reinsert jvc camcorder model no gr-d270u
the problem is from the mechanism,thir is one flex that has black surface beside the motor of the mechanism, you need to breg it ,then you test the camera
Sep 07, 2011 | Video Cameras
I need an manual for a JVC Digial Video Camera, Model No GR-D27OU
If you mean the GR-D270U, you can download the manual from the manufacturer's web site at
http://books.jvc.com/booklist.asp?Model=GR-D270U
Jun 26, 2011 | Cameras
Need to Import videos from the JVC GR-D270U to my PC
search jvc online or just do a yahoo search,,should find the driver and the program,,you need
Feb 07, 2009 | JVC GZ-MC500 Memory Card Camcorder
I disagree VERY much with Bubbabear64. I tried what he said and I had lots of problems. The computer wouldn't import and sometimes it wouldn't recognize the camera. I installed the 2 programs that came with the camera on the CD, and all of a sudden it worked great. So install the audio driver and the picture importer on the JVC disk that came with your camera.
Nov 18, 2008 | JVC GR-D270US Mini DV Digital Camcorder
Cassette door is not closing
Your loading motor is no longer working or your mechanism is out of alignment.
Aug 29, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Jun 19, 2008 | JVC GR-D290 Mini DV Digital Camcorder
Condensation, operation paused, JVC Video Camera model GR-D70AS
If the camera becomes damp or cold and brought into a warm atmosphere damp forms in the mechanism which would cause the tape to stick and become damaged or fouled.
leave the camera to warm up for a few hours and the fault should clear.
If not the most common reason is the dew sensor has failed and needs replacing
Apr 27, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
JVC GR-D270U
You may not need any driver.
Just get a 4 pin firewire cable and connect to PC.
then,
Switch on the Cam.
Open Windows Movie Maker and import video from device.
4 pin firewire would look like this:
http://www.pcab.co.uk/ebay/firewire%204%20to%204.jpg
Mar 24, 2008 | JVC GR-D270US Mini DV Digital Camcorder
How do I close the cassett holder? (JVC GR-D70 comcorder)?
man just try pushing that place by a small support on its lower side. ( imean below... just the opposite side where it is told to "push here". i hope if you didnt broke its locking mechanism, it will work..
Oct 11, 2007 | JVC Cybercam GR-D70 Mini DV Digital...
JVC Cybercam GR-D70 Mini DV Digital Camcorder Logo
93 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
