Question about HP Officejet Pro L7680 All-In-One Printer
My yellow cartridge reads low on my hp L7680 all in one. can I override this? I just need to make copies in black and white.
  • HP Master
  • 419 Answers
Because the inkjet printer assumes you will always want to be able to print in colour (after all, why else would you buy a colour printer) it will want to keep the jets clean and available for printing.
As a result the printer will always run cleaning routines that use up some of that precious ink otherwise the printhead would clog and then you wouldn't be able to use it properly.
Bottom line is that you need to get a new cartridge. Frustrating but in the context above it hopefully makes a bit more sense..
If you are really only ever doing mono (Black and White) printing then I'd seriously consider a mono laser type unit as the consumables are cheaper and you'd avoid all this waste too.
Hope that helps and sorry it's not quite the answer you were hoping for.
Posted on Jan 24, 2009
I have a HP Officejet Pro L7680 and have enjoyed a year of problem free use. Now the printer says "Ink Cartridge Problem" :The following ink cartridge appears to be missing or damaged" ...
hi,
the yellow cartridge is '' Y" and not K , you have a problem with the black carteidge "K" replace the black and tell me what is the new message, i will help you. i'm online
Nov 05, 2010 | HP Officejet Pro L7680 All-In-One Printer
My out of warranty l7680 will not print or photocopy in colour. Printhead status says Refilled supply Detected in printhead Black No/Yellow Yes Magenta Yes/Cyan Yes Detected in Printer Black No/Yellow Yes...
The error states that you are using non-HP cartridges for all colours. If black prints fine then you should replace the colour cartridges with genuine HP colour carts. You should be able to get a refund on the refills since they clearly do not work as intended.
May 25, 2010 | HP Officejet Pro L7680 All-In-One Printer
Printhead Problem:
Have you tried to replace the black/yellow printhead? This is not the same as the ink cartridges, but it is located in the compartment under and to the right of the scanner lid.
Here is HP's link.
Mar 19, 2010 | HP Officejet Pro L7680 All-In-One Printer
HP L7680 won't print black, cartridge is new, says it is full, Self diagnostic page says printhead is good
Try printing a Diagnostic page or clean cartridge. Looks like the printheads might be clogged due to low usage or general wear and tear, they may not be working as desired.
Oct 26, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP will not recognise new cartridge
The problem you are describing with the yellow cartridge sounds like ink starvation possibly due to a clogged print head or an air bubble in the print head. Since the machine is so new I would contact HP to get the print head replaced. As for the magenta cartridge, exchanging it for a new one at the store you bought it from should fix the problem. It sounds like the chip on the one you have is either damaged or wasn't set to read full ink levels.
May 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP officejet pro l7680 all in one
Most likely the print head has failed and the black is not printing which is causing the printer to have issues. Talk to HP as I guess printheads have warranty or simply change the yellow/black printhead. Or if all of these fail give the machine to HP to get you a new one as this is not right. I hope this helps.
Nov 18, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One Printer Logo
147 people viewed this question
Ben Johnson
