How to repair and install front bellow tub seal on Maytag front loading washing machine model # mhwe300vf00 serial # hly350 66 09 which was purchased in 2010 ?
How to install front bellow tub seal for this model washing machine ?
aborcass
  • 2651 Answers
SOURCE: How to replace the door bellows seal ?
did hte rear clamp come off or just the front spring. assuming its just front spring.carefully reinstall the boot over the front lip assy . easy enough!!here comes the fun!! the spring itself goes to the bottom of the rim.So hang the wire over the top of bellow and feed into the lip evenly as you go down both sides as soon as you get your hands to the 9oclock and 3 oclock positon I then change grip on the spring (use the tips of my fingers palms facing front assy and strech whole pushing down and in. I used to find small spring style clamps would work great for holding the wire in place till it would "pop" into place. a third hand is also very useful to hold in place .
Posted on Mar 12, 2008
mastatech
  • 478 Answers
SOURCE: How to change bellows on Kenmore front loading washer
First remove the bottom kick plate at bottom. Then tear off the front of the bellows from around the door. Inside there is a big hose clamp holding the inside if it. Remove completely.
Now,put the inside on first, Tightening the inside clamp. Easy so far, right?
My trick to the outer spring:put a little liquid detergent or soap on out bellow where spring attaches,start at top and work it down and around, use needlenose pliers to help with hard part. Good Luck.
Posted on Mar 13, 2009
VtToolMan
  • 704 Answers
SOURCE: im needing to know how to install the replacement
Candie, The tub gasket (door seal) is part number #WH08X10022 with a new substitution part #WH08X10036. However, since each model can be slightly different, depending on the serial number which denotes when it was manufactured, you might want to confirm that the above gasket is the correct one for your particular washer.
I'd suggest you call the folks at Sears Parts Direct at 1-800-252-1698 and give them your complete model number AND serial number before you start in on the repair, so you can be sure you have the correct substitution bellows gasket.
It's a relatively easy repair, all you need to do is remove the spring retaining wire around the outer edge of the bellows gasket, just peel it back at the edge to see it. Now locate the locking loop by going around the rim. Once you find the locking loop, you can remove it using a couple pairs of small needle nose pliers as they make it easier to get off.
Once you've done that, you'll see the locking plate that holds the back side of the bellows gasket onto the outer washer tub. Remove those fasteners and you can get the bellows off and start in on putting the new bellows onto the washer, just reversing the order you used in the removal process.
Here's a line drawing that shows the exploded view of the tub section, with the gasket (item #306). Just take your time removing the old gasket so you remember what you're doing and when installing the new gasket so as not to rip or tear it in the process. I'd also suggest you let the gasket relax for a good 4-5 hours (to get the kinks and folds out of it from the packing box) before you do the installation.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WBVH6240F0WW&productCategoryId=0153200&brandId=0432&modelName=WASHER&diagramPageId=00004&componentDescription=TUB%20&%20MOTOR&documentId=G6090504&backToLink=Return%20to%20Sub%20Components%20list
Here's another link to one of my other solutions for installing a bellows gasket on a GE front loading washer that you can also review for more installation tips, etc.
http://www.fixya.com/support/t2730376-need_help_in_installing_door_bellow_ge
Hope you find this Very Helpful and best regards!
Posted on Sep 17, 2009
Nicesuit
  • 61 Answers
SOURCE: What causes the tears in the bellow seals on front loaded washers
overloading, worn suspention, something thats not supposed to be there sneakers? once its worn it will loose the coating on it and start to stick to items often marking clothes with grey burns
Posted on Oct 06, 2009
Testimonial: "Thank You, You would think that Whirlpool would use a better product or design !!!!!!"
jsrock516
  • 5911 Answers
SOURCE: how to change the bellow
The bellow does wear out with age and can also become mishapened from repeated pressure from the door being closed. Over time the bellow can stretch or develop rips and tears and begin to leak. If the bellow is leaking, or no longer sealing correctly, the following link explains how to replace one:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts (if required) can be purchased at any of the following websites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and have great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
If you have any questions, please post back and let me know. I hope this helps you.
NOTE: If you leave the door OPEN between washes this will help prevent constant pressure on the door seal which can stretch it out of shape over time. It is also beneficial to allow the wash tub to air out to prevent mold and mildew from forming. Also DO NOT overload the washer. This can contribute to premature wear of the door bellow and cause rips and tears.
Posted on Apr 15, 2010
Maytag 2011 maxima water not draining fully from front seal. And water is leaking down the right side. What can be wrong?
The bellows is clogged that can e cleared by opening the door and checking the area just outside the tub at the bottom for debris. Clean this area and should drain normally into outer tub.
Oct 20, 2013 | Maytag MHW6000XW - MaximaTM...
INSIDE WASHER RING BUSTED WATER LEAKING
If you are referring to the rubber door bellow (gray rubber seal), the following link explains how to access and replace one:
A replacement bellow can be purchased at any of the following web sites:
repairclinic.com
Prices differ between sites so shop and compare. The first three sites on the list, have helpful exploded view diagrams to assist you with locating and identifying any parts you may need.
If you are referring to the TUB SEAL that goes around the exterior perimeter of the wash tub where the front and rear halves meet, this is an inexpensive part, but requires extensive disassembly to get to. You can save a LOT in trying to attempt this repair on your own as this can take 1 to 2 hours for a qualified technician to perform. If you have a leaking tub seal and wish to attempt it on your own, please post back and clarify WHERE your leak is coming from.
Refer to the following parts illustrations:
http://pcappliancerepair.com/model-display.php
The door bellow is listed as item 5 under the "Door and Latch Parts" section (part #8182119).
The tub seal is listed as item 10 under the "Tub and Basket Parts" section (part #8181673).
Jun 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hello; I have a GE Front Load washer and seem
You can't repair the seal, but you can replace it with a new one for under $130 if you do the replacement yourself. You can order it online or from a local appliance shop, as prices vary slightly from place to place. I suggest www.searpartsdirect.com as they usually have the part in stock and you can get it shipped to you anywhere in the US without having to run all around trying to find one locally, etc.
The tub gasket (door seal) is part number #WH08X10022 with a new substitution part #WH08X10036. However, since each model can be slightly different, depending on the serial number which denotes when it was manufactured, you might want to confirm that the above gasket is the correct one for your particular washing machine.
Once you've done that, you'll see the locking plate that holds the back side of the bellows gasket onto the outer wash tub. Remove those fasteners and you can get the bellows off and start in on putting the new bellows onto the washer, just reversing the order you used in the removal process.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WBVH6240F0WW&productCategoryId=0153200&brandId=0432&modelName=WASHER&diagramPageId=00004&componentDescription=TUB%20&%20MOTOR&documentId=G6090504&backToLink=Return%20to%20subcomponent%20list
Sep 20, 2009 | GE WBVH6240F Front Load Washer
Im needing to know how to install the replacement door boot-bellow seal on my front load washing machine. i purchased the seal that i was told is a universal seal due to the original seal part no longer...
Sep 17, 2009 | GE WBVH6240F Front Load Washer
Tiny piece of rubber seal is torn off- water leaks from front end
You can't really repair the seal, but you can replace it with a new one for under $130 if you do the repair yourself. You can order it online or from a local appliance shop, as prices vary slightly from place to place.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WCVH6260F0WW&productCategoryId=0153200&brandId=0432&modelName=WASHER&diagramPageId=00004&componentDescription=TUB%20&%20MOTOR&documentId=G6090505&backToLink=Return%20to%20Sub%20Components%20list
Sep 10, 2009 | GE Energy Star WCVH6260F Front Load Washer
Leaking bellow for duet washer
Whirlpool sells a product called Silco-seal it is a high temperature adhesive for sealing tub hoses to tubs this can be purchased at an appliance store it sometimes works to seal a tear or, hole in a bellows
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE 3t Front Loading washer, rubber seal torn
fix ya..do it your self and save big,,im going to talk you through..and give you the part number...what you need is the bellows part # 8182119...ok vack unplug unit..open the door,,now you see the front lip of the bellow theres a wire with a spring stick a srew driver and pull off,,wire off ..ok now look in the unit right behind the front panel and in front of the tub in the upper right hand corner of tub font or bellows backside there a nut take screwdiver and losen pull bellows off,,easy to put back just reverse but open clamp a bit on back...onthejob
Jan 27, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore door to tub spring has come off
If you are talking about the inner spring that holds the door bellow to the tub, it's going to require two hands to get the spring to go back in the groove. You will need to carefully remove the bellow from the front opening of the door, first. On the 417 models, such as yours, the bellow is usually glued in place aorund the door frame and held in place by a spring to the tub. Use a putty knife to carefully peel the rubber form the washer facing. Once completed, you can glue it back in place with some appliance adhesive. To get the spring back in the groove on the tub facing, you will need to start at the top and have someone hold it on place as you work your way around the the tub. It's a real bear to get back in at times. Let me know if this helps you. Please post back if you have questions.
Dec 22, 2008 | Kenmore Elite 45986 Front Load Washer
Torn bellow on Maytag front load washer
there is a spring style clamp holding it to the front panel simply peel back slightly and "pop" it off, then holding it to the inner tub is a screw style clamp, depending on yr of production, either a 5/32 scrwe or a phillips, holding it in the 2 oclock position, release clamp andreinstall boot, it might take some time to get to fit backaround hte tub but itll bo, you gotta walk it on in spots ( like changing a tireon the bikes as a kid) itlll strectch over the rim and fit, just have to work it
Dec 03, 2008 | Maytag EPIC MFW9700S Front Load Washer
I need some one to tell me how to install the rubber seal on a bosch maxx Eurowasher front loader washing machine. Part of the seal ripped off so water leaks out. Its only 6 months old and its not covered by warranty.
Jan 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
