Question about Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony FD Trinitron WEGA KV-32HS500 will not turn on.
It started about three weeks ago. I wasn't able to turn on the TV with the remote or the power button on front of TV. No sound or picture, just 7 blinks (sometimes 6) of the standby light, pause then 7 blinks again, etc... . After a day the TV would turn on again. Then it wouldn't come on for a couple of days, but would then work for a couple days. I'm now on the TV doesn't turn on cycle and it's been a week. Please help.
  • 15,935 Answers
7 flashes is horizantal deflection stopped.
There is apparently a service bulletin, Service bulletin E28041743, that the general public is not privy to which further explains the common D board faults. The D board is what I replaced two power transistors (1RF1B7N50A) and 1 18 pin chip (SHINDENGEN MCZ3001D 03525) on.
Posted on Jan 20, 2009
  • 3 more comments
  • blueextc3221
    blueextc3221 Jan 20, 2009
    Personally, I've read of so many successful repairs that involved just the replacement of one or more of the MCZ3001D ICs that I would be hesitant to replace the capacitors and resistors. So I would first replace the ICs and see if that corrected the problem.
    FWIW, I replaced the two D-Board MCZ3001D ICs on my KV-36XBR400 over two years ago and the TV has worked perfectly ever since.
  • blueextc3221
    6 or 7 flashes means that either IC8002 or IC6501 is faulty. You can buy them at sony.com/parts
  • blueextc3221
  • blueextc3221
    the easiest way I found to access the MDZ IC`s was to slide the plastic chassis out a bit so I could access the screws holding the D-board down, unscrewed them and unplugged all the clips and connectors. I couldn`t go wrong as all the connectors on my set had different pin counts and it was impossible for me to plug a connector into the wrong place.
    I unscrewed the small triangular audio board on the side and moved it so it wasn`t in the way then gently picked the D-board up, slid it out the side and stood it on it`s end with the FBT leads still attached. You can then access the underside of the board easily.
    If I could fix the TV without having to unplug the FBT connector on the back of the tube then all the better. I`ve heard you can damage things if it isn`t done properly plus I haven`t done it in years and didn`t want to risk anything
  • blueextc3221
    Before replacing, just do a cursory inspection of the board and check for cracked solder joints.
2 Suggested Answers
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
Won't turn on. relay clicks & standby light blinks.
Hello
Blinking of standby light on Sony TVs are fault symptoms. You just count the number of blinks exactly and keely, for switiching the tv with its FRONT PANEL POWER ON-OFF SWITCH; and not by the remote control hanset. Do it for atleast three times, and confirm the number of blinks, and inform me through Fixya. OK.
Dec 01, 2010 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony trinitron KV-32HS500 won't turn on, stand by lights flash 7 times. If we leave it off for a day or 2 then it will start again. What is wrong and how do I fix it?
I have this Sony KV-32HS500 DA-4 chassis complete service manual,i can email you the power supply circuit or any other parts you may need.Its about 18 megs in size.
Sep 06, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony FD Trinitron WEGA KV-32HS500 32" just stays on standby & blinks 7 times give no indication there were any probems.- wont turn on when you push the power button it acts like it is going to come on...
we have the same porblem. We just unplug ours and wait a couple of weeks while watching another tv plug and un plug it will eventually come on then we dont turn it off again it only goes off if the power goes off.
Jun 07, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony tv will not turn on
the power supply is a switched mode. you need to take your tv to a w/shop, and let them check the following.
powersupply rectifier diodes, power trasistor lekage,
diodes, zener diodes,
if a 90-110 volts to the line trasistor,
a line transistor be checked.
the tv simple problem
Mar 29, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
My sony TV wont turn on.
Un plug and let stand for one minute. If it still does blink then use the reset on the remote and press it while pressing the power button on the TV.
Jan 19, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony FD Trinitron WEGA KV-36HS500 blinking red light 6 times
smack it on top a couple of times, it works for me :)
if ya cant duct it, smack it...
seriously...
Jun 29, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony Trinitron kv-32hs500
plug out the tv and let it stand for about 2hrs so that it can reset itself if that does not work take the set to a tech for repairs the problem is in the power supply and related circuits good luck.
Apr 02, 2007 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony FD Trinitron WEGA KV-32HS500 32" TV Logo
324 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
