Question about Philips FWC577 CD Shelf System
Philips fwd573/98 I plug it to power it shows on but noting happens and ECO light is not on. I have change the transistor on the side broad( A952) but same.
I have philips system fw v787 when i plug in i goes to eco power mode and a word NEW displayes on screen
please help me out
Posted on Mar 25, 2011
No lights when plugged in fuse appears to be ok when touched with a volt meter on either side of fuse terminals shows no power
Some times I find an open capacitor where the power transistor is "heat sink mounted" also check to see if the transistor itself is shorted, failing that it is probably one of the smaller parts on the power supply board that is gone.
Jan 13, 2011 | Memorex MVD2042 DVD Player
Hi, I own a Philips MCM 11. It is stuck in the eco power standby option and it is stuck in this eco power mode. The manual says to press the on-off button until the clock appears on the displaz. Nothing...
Hi, I also had this problem, the service manual has a couple of suggestions for this problem. plug headphones in for a few seconds to reset the safety on the amplifier, or leave it unplugged from the mains for half an hour or so to let any static build up discharge.
This unfortunately didn't help me and the guys at the call centre weren't too helpful.
Dec 20, 2010 | Audio Players & Recorders
I plug my Polti in and absolutely nothing happens, no lights come on nothing, I've changed the fuse but still noting
There maybe a broken switch or the motor may be burnt out. Take it to a used vacuum store and they will give you sound advice.
Oct 07, 2010 | Polti Eco Pro 3000 Canister Steam Vacuum
I have 37MF321 we replaced the capcitors and everything. However when we put the power into it. We have a Chirping Noise.
Ur high voltage it dead.The FBT is dead,it the Flyback Transformer.The big black block of plastic with a red wire with a cap plug to ur CRT(Tv tube).The "H" Transistor might be dead also.The "H" transistor is to left side steel side wall cage that surounded the FBT.
Mar 15, 2010 | Philips Magnavox 27MS343S 27" TV
No power when turned on. led light does not show, changed fuse in plug, is there anouther fuse inside the system?
N450AD transistor is busted,no available!!! does anyone have any idea for "replacement/subtitutions" for this Transistor?
Please help!!!!!
Feb 02, 2010 | JBL Encounter 2.1 Computer Speakers
Philips 37pf9975/12 wont switch on
i have a Philips 37pf9975/12 and after about 1hr it switches itself off the green light stops on the side but you loose picture and sound. if you push the stand by button it clicks for about 1 min and then turns itself back on???????
Jan 09, 2009 | Philips 37PF9975 37 in. HD-Ready Plasma...
Philips LCD Won't Power On
Download driver upgrade from www.philips.com/usasupport
Save file onto usb drive
Insert usb drive into TV, left side near back
Power on TV
See website for release notes. The patch fixes a bunch of issues
Dec 16, 2008 | Philips 32PFL5332D 32 in. LCD Television
My Philips mini hi-fi unit was on eco-power, and when i went to switch it on, the red light went out but the unit didn't come on. The unit now doesn't work and it's nothing to do with the plug or the...
if it has been in standby for years the power supply has died .dont bother to much to fix £150 plus ditch it commo fault with all units left in standby they die in the end regards kirk
Dec 09, 2008 | Philips Audio Players & Recorders
Hitachi 51F510 screen wont turn on
lighting can effect anything and everything, call insurance and get replacement value for set.
Nov 16, 2007 | Hitachi 51F500 51" Rear Projection...
Philips FWC577 CD Shelf System Logo
347 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
