Question about Panasonic TH-50PHD8UK 50 in. Plasma Television
Panasonic TH-50PHD8UK 50 in. Plasma how to connect cable
  • 3 Answers
SOURCE: Panasonic TH-50PZ Plasma TV won't come on.
what is a UPS?? mines doing it too
Posted on Oct 05, 2008
SOURCE: Panasonic plasma TV model TH-42PD60U won't turn on
I had this problem in 2007 / 2008 here is what happened to me. Jan 09, 2008 - I also have brought the unit to the authorized Panasonic repair facility and the problem is a failure in the P-board which is the power supply board. The P-board needs to be replaced. The repair will cost $475 plus tax. $250 is for labor. The unit was nop more than two months out of warranty. This does not speak well for Panasonic. I have been researching the problem and it looks like this has happened to many of the Panasonic plasma TVs.
Jun 14, 2008 - As an update to my problem with the failed P board. Contacted Panasonic Service and talked to a customer service representative. I told them how I have purchased many Panasonic products and how unhappy I was with the failure of the product. They proposed paying the labor cost of $250 and I would pay for the part. I just hope it does not happen again.
Posted on Oct 14, 2009
  • 8457 Answers
SOURCE: Panasonic plasma viera tv will not auto tune, can
Reboot all cables,satalites,and telicoms boxes.Like unplug,replug the box an hour later.Let the boxes up grade software,go to ur tv menu setup rescan all channels again well get them back.Ur signal not there after that, than ur Tuner Signal board is dead.Need it replaced.
Posted on Mar 13, 2010
  • 31 Answers
SOURCE: Panasonic TH-50PX60U 50 in. HDTV Plasma
Hey mate, very common in all makes of plasma TV's. See this how to video on to fix it, the video is for a hyundia but it is the same for your TV. http://www.youtube.com/watch?v=9NPobj0_GSo
It's pretty easy, just get a soldering iron and take your time, best of luck. Bro
Posted on Apr 04, 2010
  • 222 Answers
SOURCE: how to connect sound bar
Does your TV have an Audio out? If it does then you can connect it from there.
Posted on Jun 12, 2010
My Panasonic plasma Tv does not have sound. How do I fixed that
Sound no picture on 50 inch samsung plasma ps51d450a2m - HDTV ...
www.tomsguide.com/.../58009-4-sound-picture-inch-samsung-plasma-ps...
Jul 1, 2015 - 4 posts - ‎3 authors
There is sound and no picture on plasma tv, remote works at times but ... My pioneer elilte has this mode, and it is pretty easy to completely turn ... When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
Problems with blu ray player and plasma tv - HDTV ...
Nov 16, 2014
I do not have audio out on my tv how do i connect so ...
Dec 18, 2013
All channels on my tv have sound except channel 3 ...
Jun 29, 2010
More results from www.tomsguide.com
No picture or sound in my Panasonic TH-P42UT30A plasma ...
Dec 07, 2015 | Panasonic Viera Th-50px60u 50" Plasma...
How do l connect to cable
Connect the cable to the coax connector on the back called Ant. Go to setup and probably tuner. Select cable. Scan for channels.
Sep 24, 2014 | Panasonic TH-50PHD8UK 50 in. Plasma...
I have @ panasonic plasma display model TH=50PHD7UY serial YH5120189 and my question is how can I connect cable tv in to because does not have the connector on back?
Hello
Your TV has no direct cable connector. You can connect it to cable via converter using SERIAL (D-Sub 9pin [RC 232] type connector wire from converter to your TV. It is designed so. High Density D-Sub 15 pin connector is used to connect this Tv with computer. OK.
Jul 21, 2011 | Panasonic TH-50PHD7UY 50 in. HD-Ready...
My plasma tv is over zooming and I cannot see any top graphics or see any words on the bottom
I'll need the model number to solve this completely, but here's the first try:
1. Check the "aspect ratio" setting. Usually there's 4 settings: Normal, Wide, Stretch, and Zoom. Flip between those to check which is best.
2. If you've got your computer hooked into it, under the options there's a "fine sync" option, that will allow you to fine-set the resolution. Use the "clock" and "h-sync" option.
Try those, and if you can give me the model number, I can be of more assistance.
Jan 04, 2009 | Panasonic TH-50PHD8UK 50 in. Plasma...
Posterized!
Try 2 different signal sources, such as cable and DVD or Dish and DVD or Cable and vcr. If the same problem exists on both sources then the TV needs a circuit board.
I would like a discription of "posterized" to help you more.
Steve
Mar 24, 2008 | Panasonic TH-50PHD8UK 50 in. Plasma...
Switching to video component 1 input
The Video input is turn off in setup menu.
Best regards
CircuitCity
Dec 08, 2007 | Panasonic TH-50PHD8UK 50 in. Plasma...
All Reds Are Gone from Display
if you are using composite video out, then it is the red cable which went bad. composite is when the audio is ver 2 wires, and the red, green and blueall have their own wires.
more than likely though, you have a rear projection tv, and the red bulb burnt out.
Aug 30, 2007 | Panasonic TH-50PHD8UK 50 in. Plasma...
Input/Output Connections
This model Panasonic is a monitor. Component video, S-Video, and audiio connection ports are on the bottom of the unit. Once the unit is wall mounted you can hardly see them, hidden behind the front leading edge of the case. Two speaker connection terminals are found
slightly above the bottom edge at extreme left and right. The main power button is also on the bottom left.
Aug 14, 2007 | Panasonic TH-50PHD8UK 50 in. Plasma...
Panasonic 50 inch plasma tv
It's hard to say without seeing a picture. Panasonic has a site with pictures of various Plasma symptoms and the board that will cause that problem. Go to: http://www.pasctraining.panasonic.com/PASS/elearn/PDP.htm Click on: Pictures of plasma symptoms It will direct you to a PDF file. It may not be your exact problem, but, it will show you which board will cause your problem. Hope this helps.
Apr 21, 2007 | Panasonic TH-50PHD8UK 50 in. Plasma...
Panasonic TH-50PHD8UK 50 in. Plasma Television Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
