Question about Hotpoint Ariston WD440G Front Load All-in-One Washer / Dryer
Hotpoint wd44d wash/dryer wont finish a wash nor wont pump out
I cleaned out the filter under the drum with the ball float in it i found a few coins and curtain hooks in it tried it again and same thing wont finish a cycle i even tried pump out the water and the on/off light flashes with the reduce creases button and extra rinse button any ideas thanks...
  • suebev2000 May 11, 2010
    where is the filter??
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
There may be something stuck in the pump itself. hairgrips and brawires are a common find.
Posted on Jan 27, 2009
Hotpoint WD 640. The machine is not fully draining after washing or drying. Any help?
The reason for this is almost certainly because the empty pump filter is partially blocked. Unfortunately, our loving friends at Hotpoint put the filter UNDER the drum and it can only be got to by drgging the machine out and attacking from the rear. The filter is the size of a large coffee mug, covered in rubber, directly below the cetre of the drum and held in place by a large jubilee clip. Remove the clip, pull off the rubber boot and inside is a white conical "pot" with a ping pong ball in it. You will probably find lint, coins and junk inside. Clean, replace the ball, reassemble. All should be ok
Jun 21, 2011 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wma11 where is the filter?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
May 21, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I have my hotpoint aqarius washing machine only 1 year and it has just started to freeze and wont drain the water out of it,will start any wash ok but that as far as i get with it,i have tryed to open the...
Mar 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Wf310 hotpoint aquarius washing machine wont spin or drain
Feb 23, 2010 | Hotpoint Aquarius WD63 Front Load...
MY Hotpoint WD 640 washing machine is not drying clothes is there a filter to clean or a reset
Feb 15, 2010 | Hotpoint Aquarius WD640 Front Load...
Grey scum marking clothes
Mar 23, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Need to clean fillter on hotpoint wf000
The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. In side is a white molded cone and a big white ball which floats in side. You will find a lot of junk here, clean out. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Would be good to check out the pump too.
Mar 21, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Door/drum seal has split causing a major leak also had probs for last few months where it gets to last 10 mins of cycle then it just counts down and doesnt complete the cycle it then gets stuck on 1 min...
Feb 18, 2009 | Hotpoint Aquarius WD640 Front Load...
It sounds like you still have a blockage either in the outlet hose itself or in he pump. If you know how to remove the outlet hose from the bottom of the machine but be aware a lot of water also might empty from the machine when you do this. If you use an object such as a pen and put it in the outlet hose no blockage it wll come out. Then gently feel around the pump opening for any objects. Finally gently spin the pump propellor to make sure it turns smoothly. Replace hose and test. Hope this helps.
Jan 19, 2009 | Hotpoint Washing Machines
Cycle is stopping at 9 mins left and not spinning on my lg drive 7 washer/dryer
A common solution for filter cleaning, might help you. You should check your pump too. (another Hotpoint model)
May 27, 2008 | Hotpoint First Edition FEW10P Front Load...
Hotpoint Ariston WD440G Front Load All-in-One Washer / Dryer Logo
288 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
