Question about Mattel Barbie 2008 Glamour Jet Plane Airplane
Replace batteries on Barbie plane - Mattel Barbie 2008 Glamour Jet Plane Airplane
How do I change a broken needle in a Barbie sewing machine
call or email the sites below about the needle
sewvacdoctor.com
a1sewingmachines.com
Oct 10, 2012 | Barbie Sewing Machines
I have a Barbie Girls mp3 player that is not charging. Can the battery be replaced?
tried to replace the charger and cleaned the usb port of the mp3, then check weather the battery is worn out which in need for replacement.
Jul 11, 2012 | Audio Players & Recorders
I have a Barbie Mattel O Phone and recently got the records that go inside however I have no instructions. I inserted batteries but it didn't work. Do these old 1960 s toys no longer work, or can they...
Yes they should work if uou inserted everything correctly. I would suggest using different ebay links, one specifically..
  • Vintage Lot of 6 1965 Mattel Mattel-O-Phone Records Toy Collectibles Vintage Set of 6 Mattel-O-Phone Records by Mattel. 5 records are dated 1965 & 1 is dated 1967. Records include...Barbie, Talky Toys, Familiar Friend
    mybookbarn.ecrater.com/p/6503772/vintage-lot-of-6-1965-mattel-o-phone-records · Cached page
  • Vintage BARBIE Mattel O Phone RECORD GC telephone ' eBay
    • Seller 100.0% positive ·
    • Free shipping ·
    • Shelbyville, Tennessee
    Dolls & Bears > Dolls > Barbie Vintage (Pre-1973) > Vintage (Pre-1967) ... Vintage BARBIE Mattel O Phone RECORD GC telephone
    cgi.ebay.com/Vintage-BARBIE-Mattel-O-Phone-RECORD-GC-telephone-/150549739745?pt=LH... · Cached page
  • Sep 18, 2011 | Mattel O Phone Record Discs Talking Toy...
    How do you replace the battery - the compartment seems to be sealed
    The compartment is glued shut. If you do force it open, you'll find that it is empty. No batteries have been wired into the battery compartment. It must have been used in another model - but not this one.
    Feb 21, 2010 | Mattel Barbie 2008 Glamour Jet Plane...
    I got a barbie watch gift for my daugter, but i couldnot find the battery? where is it and how it work?
    Of course the battery is inside and you would need to remove the case back on the watch to find it. You should have someone do it for you that has the proper tool to remove the case back and to properly remove and install the new one. Believe me, even stores can "screw it up". So you should not attempt this. Pay $5 to $10 and get an experienced person to do this for you. If you bought this new, then it should be working and you should not have to replace the battery. In that case, return it to the store or have them exchange it for another one. Hope this helps, Good Luck
    Nov 17, 2009 | Barbie Lorus Analog Nostalgia BC0236TIN...
    Barbie mp3 quit working
    You have to change the battery. To do that you have to take that thing off on the back of the MP3 player and unscrew it to change the battery.
    Mar 05, 2009 | Mattel Barbie Girls MP3 Player
    Need a wiring diagram for a barbie 12 volt two battery jeep !!!!!
    When you mean wired in series you mean you tied the positive from one battery to the negative of the other. That will put 12 volts into the system. Is it supposed to run on 12 volts or 6 volts? If it is only supposed to be 6 volts you should wire the batteries in series. Negative to negative to negative wire to load. Positive to positive to positive wire to Load. Hope this helps
    Nov 25, 2008 | 3d Rose Londons Times Funny Society...
    Barbie girl mp3 player isn't recognized in Windows
    remove the backplate, get a pin and push the reset button at the back of the barbiegirl
    Sep 10, 2008 | Mattel Barbie Girls MP3 Player
    Mattel Barbie 2008 Glamour Jet Plane Airplane Logo
    51 people viewed this question
    Top Mattel Toys Experts
    thegtw
    Tracy E
    Level 1 Expert
    Tom Chichester
    Are you a Mattel Toy Expert? Answer questions, earn points and help others
