Question about Hayward 12v LED Color Logic Pool Light -100ft Cord - SS Face
Have an intermatic remote for pool light, the light comes on inside the pool but does not change colors, any ideas what to do???
I used to own one of these. Water got in the seal on mine and damaged the board and I saw a similar effect. If it is under pool warranty from the installation, call the pool company to see if they will replace the computer board in the light or the whole light.
Posted on Feb 28, 2014
My rc939 wont work unless right next to receiver.
Your description sounds similar to the problem ceiling fan owners have with their RF remotes. Try disconnecting the power to the pool light (at the breaker), pausing, and reconnecting power. Try remote operation. If nothing changes, reprogram the transmitter to the original setting and repeat the previous test. If nothing changes, the transmitter may have sharply reduced power output or the receiver may be defective.
Jun 21, 2014 | Intermatic RC939 3 Channel Radio...
I have an intermatic RC939 3 channel radio transmitter to turn on/off pool light. Light indicator is on so battery works but pool light won't come on. How do I fix it?
1) Review both manuals for advisories that might apply to your installation.
http://waterheatertimer.org/pdf/RC613-RC613L-RC615.pdf
http://waterheatertimer.org/pdf/Intermatic-remote-RC939-manual.pdf
Reset receiver and then 'reprogram' to transmitter
Contact Intermatic 815-675-7000
Each transmitter and receiver have 1 year limited warranty.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 30, 2013 | Hardware & Accessories
How do i hook up entermatic pa 600
Install switch on wire coming from breaker box, between breaker box and Load (pool timer, pool pump, light, fan, motor.
http://waterheatertimer.org/pdf/PA600-shut-off.pdf
Mar 20, 2013 | INTERMATIC PART - EMERGENCY SHUT OFF...
How can i set up the time of the pool light in the a box model T10004R?
Typical T1000R series pool control center has space for 2 timers, and comes with one T104M 240Volt timer. Additional timer mechanism can be added to control lights, etc.
Copy following link for setting T104 series Intermatic clock, with link to wiring diagrams.
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
Intermatic pool timers are extremely durable and versatile, and modular so they can be repaired almost indefinitely using ez-to-locate parts
Additional link for replacement parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool
Oct 28, 2012 | Intermatic T10004R - Pool-Spa Mechanical...
Pool ligth stop working
10-16-2012
Question posted under T10004RT3 pool panel with transformer.
If the pool light inside the swimming pool is out, but bulbs are new, then those lights receive power from the transformer. Check if transformer is humming and putting out 12Volts ac.
Check that bulbs are rated for transformer output voltage.
Replace transformer with 119T340 or 119T267.
If the 120Volt lights are not working, then these usually turn on-off with a switch. Check the switch
Oct 15, 2012 | Intermatic T10004RT3 - Pool Panel with...
I NEEDAND CAN'T FIND DIAGRAM FOR THE INTERMATIC T101P201 FIREMAN SWICH
1) T101P201 timer does not have a separate manual yet
http://www.poolandspacontrols.com/products/mechanical%20time%20switches/pool%20and%20spa%20time%20switches.aspx
2) However typical T101P201 timer is ordinary T101 timing mechanism inside Nema 3R beige-colored outdoor plastic enclosure, with additional fireman's switch.
Wiring for T101 shows on following link, and shows on door of timer enclosure:
Check that your timer terminals match illustrations because many timers can fit inside Intermatic enclosures.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
3) Fireman switch wiring:
T101P201 has a fireman's switch that wires directly to the pool heater thermostat.
http://waterheatertimer.org/pdf/Intermatic-Firemans-switch-156T4042A.pdf
If you are not using the timer for pool heater, or if heater does not have connection for fireman's switch, then do not connect fireman switch wires, and just tape them out of the way.
Add a comment for more information
Jun 16, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Have a intermatic t10004r pool controller box. pool light not working. box is only 1.5 yrs. old only used light 4 times all brand new 1.5 yrs ago
T10004R comes supplied with one 240Volt T104M timer mechanism.
T104 mechanism can be tested to see where problem is located.
Open following link for troubleshoot checklist to see where problem is located.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Recommend standing on dry surface and using same precautions when working inside circuit breaker box.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 03, 2011 | Intermatic T10004R - Pool-Spa Mechanical...
I have an intermatic RC3621RT 5 circuit timer with remote controls for the spa. I'd like to upgrade, but I cant find a cross reference for a new box that would be the same. Can you help?
Following pdf file shows Intermatic pool and spa controls
http://waterheatertimer.org/pdf/Pool and Spa.ashx.pdf
PE40000 series has remote control and 5 SPST circuits (3 timed with timer and 2 on-demand with remote control). Can be wired for both 120V and 240V circuits, so pump can be 240 and lights 120, or both 120.
The new timers are electronic
Intermatic pool and spa website with contact-us information & manuals:
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 11, 2011 | Intermatic Hardware & Accessories
Brand new Intermatic timer for pool, but it will not trip the pool ON...It does trip the pool OFF only??????
So you can turn the pool timer off using manual override.
The center dial is also turning.
These 2 things mean the timer is working fine, but you forgot to put the OFF tripper pins on the dial.
5def96a.jpg Picture shows Off tripper coming in contact with lever that clicks lights on and off. The lever is connected the manual override. So if manual override is working, then the lever is working.
1ba8aca.jpgThe ON and Off trippers are different color
Oct 10, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
I have two color logic lights, twice now water has got inside the light fixture I have had to replace them both time, any idea how this happens
Defective units, bad seal, or when soemone changes the bulbs, you must always replace the seal. It cannot be reused. Also possible the seal was not installed correctly. If these are new lights, they have a 1 year warranty. HTH
May 22, 2010 | Hayward 12v LED Color Logic Pool Light...
Hayward 12v LED Color Logic Pool Light -100ft Cord - SS Face Logo
325 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
