Question about Linksys Wireless-G WRT54G Router
Want to block UPD ports on router
I'd like to block certain UDP ports on my linksys router so that STEAM will not work, but I can't seem to find anything under "Blocked Services" in the Access Restrictions tab to do this. Can anyone assist?
    Novelist:
  • 173 Answers
Hi Try the below steps:
1. Log into the configuration page of your Linksys using a web browser by entering 192.168.1.1 in the URL bar. Enter "admin" as both the username and the password. These are the default settings; if any of the settings have been changed, then enter the updated information.
2. Select "Port Range Forwarding" from under the "Applications & Gaming" tab on from the configuration page. Enter the name of the application in the "Application" field, and the starting and ending port numbers in the appropriate fields, as many applications use a range of consecutive numbers for the port number. If your application uses only one port number then input the same number in both the "Start" and the "End" fields.
3.Click on the "Save" button at the bottom of the window to save any changes you have made. Make sure your changes have taken effect by testing an application.
Hope this helps.
Posted on Nov 21, 2013
  • 25 Answers
SOURCE: WAN requests
The feature you are referring to "Block Wan Requests" is either enabled or disabled In the pane to the right, where there are 4 subcategories to "Block Wan Requests", Block Anonymous, Filter Multicast, Filter NAT, and Filter IDENT. These 4 subcategories are your choices for blocking WAN requests. They can be either enabled, or disabled.
Posted on Nov 26, 2007
ohms
  • 1879 Answers
SOURCE: Port Forwarding On Linksys RV016
No change needed on the RV016 - same IP & Port
Check settings on the NEW Workstation (Remote Access grants / Ports assignment)
And your Computer as it is still looking for the old workstation (RDP is more on the computer's identity not the IP address).
Posted on Sep 08, 2008
dante777
  • 623 Answers
SOURCE: Port Fowarding for my Logitech Webcam
Do you know how to do portforwarding in general?
Have a look at the manual - page 21. You can also find it here: ftp://ftp.linksys.com/downloads/NA/userguide/WRT310N_V10_UG_B-WEB.pdf
You should give your computer a static IP address (or enable static DHCP), otherwise the forwarding will fail if DHCP assings a different address to your computer.
Important is that you have two entries, one for port 8888 /TCP and a second one for port 8081 /Both.
If this helped, please come back and leave a comment, to help others with the same problem.
Posted on Dec 28, 2008
  • 104 Answers
SOURCE: Cannot find wireless tab on Linksys router setup page
Hi...this is an unusual problem.
Is your model the BEFSR41W? Linksys describe this as a 'wireless ready router', and it seems to require a PCMCIA card to be inserted in the back of the router, to enable wireless connectivity.
I'm just wondering if the router lost communication with the card, causing your wireless options to disappear?
However, first things first. As you have (correctly) reset the router, all your settings have been cleared, including ISP information (hence the internet connection is lost). Your first priority is to set up your router again, and the Linksys website has a downloadable manual, quick install guide and tips which will help with this.
When you are up and running - and assuming I have the right model - try removing and re-inserting the PCMCIA card at the back of the router, and see if the router re-detects it. If successful, this should bring back your wireless options.
I hope this helps, but please post again on Fixya if not. It does seem odd to have lost the wired connection before the reset.
Good luck. :)
Posted on Jan 14, 2009
  • 2187 Answers
SOURCE: Linksys WRT160N V3 Firewall issues
You need to check first if it is the program that is causing this or not. If you have a computer without the program, have it connected to the router. If it connects it may be the program. Check if switching cable may help. IT may be a faulty cable. It may also be something in your PC that is causing this one.
Posted on Aug 08, 2009
Open tcp ports
http://support.linksys.com/en-us/support/routers/E3000
This should have a manual for this router that will explain how to open ports on the router for game play.
Jul 17, 2013 | Linksys E3000 Wireless Router
Router set to strict nat router is linksys wrt54gx2 how do i make it open to play xbox live?
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
Jan 15, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
Client does all the handshacking with the router
forward these ports for your VPN client ip address on your router...
TCP&UDP 50
TCP&UDP 51
TCP&UDP 500
TCP&UDP 10000
TCP 1723
UDP 1701
also disable firewall...
Jul 25, 2010 | Linksys RVS4000 Router
I have Timewarner cable and can't set up a vpn so that a client can connect into my Lynksys vpn router. Is it possible that the firewall in the TW router is blocking a client or that maybe I need a static...
No you need not buy a static address... just forward these ports in linksys router...
50 both TCP and UDP 51 both TCP and UDP 500 both TCP and UDP 10000 both TCP and UDP 1723 both TCP and UDP 1701 both TCP and UDP
also disable firewall in linksys router....
May 10, 2010 | Linksys -Cisco Wireless-G VPN Broadband...
PlayStation 3 keep getting nat type 3 when need type 2
Hi
I was having problems with my PS3 as well I did the following
updated firmwire
Also I assign static ip address on my PS3 and forward ports used by PS3 to static IP address of PS3 on routers firewall.
Ports used by PS3:
udp 3478
udp 3479
udp 3658
tcp.domain (port 53)
udp.domain (port 53)
tcp.http (port 80)
tcp.https (port 443)
udp.ssdp (port 1900)
tcp.amandaBackupInitiation (10080)
tcp.Jabber SSL/TLS (port 5223)
tcp.10075
tcp.10078
tcp.10079
If your still getting problems configure the PS3 to be in your DMZ.
DMZ will be under applications and gaming. Just look for that setting in your routers setup page and add your PS3 IP address to it.
Mar 15, 2010 | Linksys WRT160N Wireless Router
How do i setup my router to shut down the udp port at a certain time....xbox live is what i'm trying to control
Your router does not have the advanced features that would be needed to do this. However, this can be controlled using parental controls on xbox live. Here is a link: http://www.xbox.com/en-US/support/familysettings/xbox360/familysettings-intro.htm
Oct 06, 2009 | Linksys Wireless-G WRT54G Router
How to create a port on my router
please follow the steps are given below,
1.Type 192.168.1.1 on your browser's address bar. You will see a login dialog box .
2.Type your username & password and login to device.
3.A web page will appear , you can go to security section & select virtual servers.
4.From virtual servers section you can create port you want either TCP or UDP.
best regards,
Krishan
May 09, 2009 | U.S. Robotics (USR5450) 802.11g/b Wireless...
Can't connect reliance ec325 on ubuntu7.1
This can be a real challenge.
If you cannot get on, then get the D-Link box as a quick fix.
You may , just may need to open what is called a UDP port for the router, which if you can get in then set the udp port to accept your vonage.
Vonage is pretty rock solid and most boxes have all udp ports open.
You issue is that you are using a PPP and that is a real source of trouble. You have to be able to tweak the incoming router box. Some ISP 's want you to use there phones and will block ports so you cannot do much.
Complain to your internet provider. Make them fix it or replace a box that will allow open communications with the Linksys / vonage box.
e
Jan 12, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Found the check box - for Block WAN
I believe your initial problem was for PCAnywhere rgiht? just make sure ports 5631 (Data Port or TCP) and 5632(Status port or UDP) is properly opened/forwarded on your router's config page plus make sure that you instruct the router to forward those ports to the computer that you have PCAnywhere plus I have read some articles that newer versions of PCAnywhere 10.+ 11.+ will not work with older version 5.+
Now if it still doesn't work try setting up DMZ for you host computer(Note: enabling DMZ will open a wide range of ports, well common ports that is).
Jul 02, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
133 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
