Question about Whirlpool Duet GHW9150P Front Load Washer
Whilepool front loader washer won't spin dry comes with code f02
    New Friend:
    Problem Solver:
  • 6 Answers
Just had the same problem with my 9250 Duet and fixed it this morning. The F02 code is a "long drain" code. It could be because something is blocking the external drain line, the internal drain line, the pump filter, or the wash basin. I fussed with mine intermittently for about a year, resetting it so it would run thru the cycle, until one day (yesterday) that wouldn\'t work. Opted to give a shot at fixing it, since repairman couldn\'t be here until at least Monday, and THEN wanted $90 just for the service call. Anyway, using a Torx bit, unscrewed the 3 screws on the front cover. Directly in front of you, at the center front of the machine, is a plastic apparatus with a motor attached to it. SLOWLY untwist the (apx 2.5") plastic cap. However, BE PREPARED. The water that remains in your washer will ALL come out. If it comes out all at once, there is a problem from the filter cap (which may have junk in it which caused the problem in the first place)to the outside line (i.e. bad pump, clogged drain line from pump to exterior drain line). If it all drains out slowly (like mine), or not at all, the obstruction is from the wash basin TO the pump filter. Using Robo-Grip pliers, I removed the hose clamp at the bottom of the wash basin (easily located by following the black rubber drain line to its origin), and quickly found the problem: a giant mound of YUCK (easily 5 cups worth, no kidding) which had accumulated around the float (situate inside the rubber drain line) and the washer drain basin itself. Pulled it all out, put it all back together, and it works GREAT! And the hardest part (no kidding) was getting the hose clamp back on the drain line/float apparatus. Hope this helps you, and that this post is not too late. BTW, I am in no way a mechanical genius, so I HIGHLY recommend that anyone attempt fixing it before calling the repair man.
Posted on Mar 03, 2013
jsrock516
  • 5911 Answers
SOURCE: My washer won't drain (code F2)?
"F02" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608545-f02_error_code
Included is a follow-on link that explains how to access and check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Posted on Jan 04, 2010
caroldon
  • 17130 Answers
SOURCE: The washer fills agitate but won't spin & drain
Possible fault with the program controller unit. You need to check the program cycle outputs using a multimeter connected to measure the output voltage. On start the inlet should open and then close as the water level sensors works and then proceed to wash. So this much seems OK. Now in the next step the drain valve must open to drain off, then fill once again with the inlet working and water level being sensed. If there is no output in this section cycle then the prrogram controller has errors within the memory . You can remove the panel and reset all connectors and connections.
Posted on Oct 30, 2011
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Posted on Jul 23, 2011
onthejob5130
  • 640 Answers
SOURCE: Whirpool Duet front loader ghw9100lw error code F02
if your hearing clackling try and clean the pump and the hose leading into the pump for a coin ,,small ,,(dime),,,hair clip,,also its a must that you use he detergent,,or you sude up,,if you do use he your using to much,,now bleach the unit out on a normal cycle hot wash cold rinse with about a pint of bleach...and no you can purchase part of a pump..it comes as you see it in unit..onthejob
Posted on Jan 12, 2009
SOURCE: whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Posted on Jan 22, 2010
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hello My Maytag black front loader washer is displaying an error code of F02. Do you know a fix for this error code? Thank you
Hello & Welcome to FixYa
F02 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 07, 2011 | Maytag Washing Machines
My Maytag Front Loader Washer was reading sud on the digital screen and also reading F02. After a few days past by, it stopped reading that because i looked online and thought i solved the problem. Just...
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 01, 2011 | Maytag EPIC MFW9700S Front Load Washer
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
My washer is a whirlpool front loader. It keeps
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Jan 01, 2010 | Frigidaire Affinity ATF7000E Front Load...
My whirpool front loader say f02
If I am not mistaken f02 code means that long drain. put into spin and see if the pump turns on if it does check if water is coming out... if not need to check if there is something stuck in the pump blocking the flow for the water
Nov 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whrilpool duet front loader washer flashes f2
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump..
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,907 people viewed this question
Dan Webster
Dan Webster
Sal De
