I am assuming that you did not set your camera for closeup work, which is why it was out of focus. Try setting for closeup (tulip icon usually) and see if that does not solve the problem. If you did set for closeup it is possible that the lens is dirty or smudged which will cause focus problems when doing close in work. Hope this helps.
Harmony remotes use IR commands, so you will always have to have line of sight for it to work.
However, if you are using the RF extender, ensure that the device you are using to change channels is assigned to the extender, and that the extender is properly paired.
I have had the same problem I have two bell receivers one in the bedroom and one in the living room, in low light the remote in the living room would work much like yours, but if I took the same remote into the bedroom it worked fine in low light, the second remote responded exactly the same, the problem in my situation was the TV had a light sensor that adjusts the picture depending on the light in the room, with this option turned off. The remote works just fine in low light situation.
push the reset button and start from scratch
also you could be going through a metat wall or a metal faced wall they made great fariday cages in the 40's with wire mesh and plaster i cant get a signal 10 inches from my router in the next room and i mean 10 inches strait through the wall
you need to return it.
one of the IR led only works.
I had that, had to return (RMA) the unit.
you can check with some camcorders to see how bright the LED is (the camcorders often can 'see' the IR led like a white light).
i.e. either the power circuit for the IR LEDs is failing or the IR LED themselves are dead.
there is nothign you can fix on your own. CAll the support and get a replacement unit.
or return the remote to a store if you just bought it.
Dawn,
If you want a remote that works via IR to control the satellite receiver you will need a IR only. The IR/UHF type only transmits signals to the receiver by UHF and the IR portion only operates the peripherals in the room such as the TV and VCR. There are some remotes that come with a kit that can change the remote to work as an IR only. I believe you have a TV2 remote and want it to work further away from the receiver particularly the room the TV is in. If this is the case you may have have to change the remote address of the new remote to match that of the old. You can do this by taking the number one remote and pressing menu-menu. Now take the new remote and press and hold the SAT button in the upper left of the remote until all lights across the top light up. Now key in the two digit number on the tv screen at remote address for tv2. Then press the pound sign and the SAT button will flash three times then press the record button and the TV2 icon should flash. Now you can cancell out of the screen on tv one and try the remote at the TV2 location. I believe this will fix your issue if not let me know. Thanks for using Fix Ya.
This is indeed a faulty IR sensor. If it's just the sensor, swap with your good one to check. From memory they are plug in - a little device behing d the smoked translucent facia (display panel). I have come across this several times with Panasonic VCRs. Check whether the remote works at night time with all fluorescent lights in the room switched off. If so, the IR filter circuitry is faulty. Same solution - replace IR sensor on VCR.
