Question about Whirlpool WFW94HEXW 5.0 cu. ft. White Front Load Washer
Whirlpool wfw94hexw will not spin properly - Whirlpool WFW94HEXW 5.0 cu. ft. White Front Load Washer
2 Suggested Answers
  • 662 Answers
SOURCE: whirlpool wfw94hexw front panel removal
Disconnect power off the wall socket. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. Prop up the front feet of the washer with some small blocks of wood, this will enable access to the screws.
With the screws removed, the lower panel should drop down then come off. If it is jammed just knock it off. Round big screw leads to the filter (be prepared for a lot of water and the usual smelly junk.) which you shd take out and clean. Beyond is the pump which should be examined carefully for any blocking rotation. Refit all carefully.
Pl click helped if helped.
Posted on Apr 10, 2013
Where is the access to the drain located on a whhirlpool WFW94HEXW washer
bottom front of the washer behind the panel is the common location of the drain pump and inlet screen.
Sep 27, 2016 | Whirlpool duet Washing Machines
Hi my whirlpool doesent speen
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will notturn - 11068202794. ApplianceVideo.com ...
Kenmore / Whirlpool Washer Not Spinning 1 - YouTube
? 11:33
https://www.youtube.com/watch?v=TB_W6sPdzkM
Jul 10, 2012 - Uploaded by Bill Newberry
Kenmore / Whirlpool Washer Not Spinning 1. Bill Newberry ... Washer will not spin the clothes dry ... Now ..
Dec 03, 2015 | Whirlpool Dryers
What do error codes e06 and e01 mean?
E01 and e06 codes - Fixya
www.fixya.com/support/t14040885-e01_e06_codes
Aug 19, 2012 - e01 and e06 codes washer will not do anything other than lock the door. - Whirlpool Duet: WFW94HEXW Laundry : question. ... Error message E06 onWhirlpool. Unplug the machine and wait 10 minutes before restarting it.
Aug 24, 2015 | Maytag Washing Machines
Washer not running, how can I unlock the door to get my laundry?
There is some good advice here. I had a similar problem. I pulled the plug, counted to ten and plugged it back in, and it unlocked.
Is there water in the machine? If so, remove the drain hose and lower it into a bucket and get the water level down to as empty as you can.
https://answers.yahoo.com/question/index?qid=20080914155354AAjtqMB
Aug 06, 2015 | Whirlpool WFW94HEXW-WGD94HEXW Laundry
Whirlpool wfw94hexw clean pump
You aren't going to like it but you need to disassemble the machine to get to the clean out. If you want instruction still please let me know.
Jan 27, 2015 | Whirlpool Washing Machines
Why won't my WFW94HEXW Front load Whirlpool washer, won't go into spin mode?
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Oct 04, 2014 | Whirlpool Washing Machines
WFW94HEXW will not fill with water
change your water valve or check the little filter on your valve see if clean
Apr 07, 2014 | Whirlpool duet Washing Machines
Error message : e01 f09
First try holding down the cancel button for 10 seconds and releasing (might have to do this 2~3 times). The technician manual is located under the lower front panel. I've heard that locating the CCU (brain box, in lower right) freeing it up and giving it a couple of wacks has worked. F09 is pressure switch, E01 is Thermistor. The tech manual will be a great help!!
Feb 16, 2014 | Whirlpool Duet 4.3 cu. ft. Front Load...
Whirlpool wfw94hexw front panel removal
Apr 09, 2013 | Whirlpool Washing Machines
Video for replacing billow on a wfw94hexw
Click this link if this is what you meant: door seal
Jan 21, 2013 | Whirlpool Washing Machines
Whirlpool WFW94HEXW 5.0 cu. ft. White Front Load Washer Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal De
