Question about Robitussin Cool Moisture 1 Gal. Humidifier
I dont have the instructions need to know if you just add water or if I need to add something else to the water?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 33 Answers
Water.
Posted on Jan 06, 2013
I have a disney olaf humdifer it isnt misting what do i need to do
The instructions probably say to add some mineral content to the water. Your humidifier won't mist otherwise.
Dec 08, 2016 | Humidifiers
I dont know how to add water to a sunbeam humidifier model#scm808
Hallo
Can you not find the owner manual?
The best I can do is advice you to go online and find MANUALSONLINE.COM. There look for the brand name "sunbeam" then the product humidifier.
In the one in this house you lift and take the filter out and water in.
Good luck
Kolbrun
Apr 23, 2012 | Sunbeam Humidifiers
I need to know how to use the warm steam vaporizer i lost the instruccions..
you add vicks petroleum paste/jelly at the top where the air vent is. Add 1-2 tablespoons of salt with tap water in the tank, plug in the unit and warm steam will produce.
Feb 16, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
How to clean humidifier,steam type
Use white vinegar. Add 1 cup of white vinegar to 1 cup of water to the water reservoir to allow it to disolve any mineral (from water deposits.) and run the humidifier to allow the solution to disolve the deposits inside the unit.
This should take care of any minor issues. If you're looking to clean something else, check online for an owner's manual.
Jul 28, 2009 | Evenflo Humidifiers
I have a Aprilaire 550 Humidifier. The feed tube is cracked and leaking. How do I go about replacing it. When I use a wrench to remove the copper end, will water come pouring out?
Thanks for your question,
what you need is called an ( Ice maker kit ) any hardware store or appliance store should carry these, the copper tubing is 1/4 in, the kit comes with the service valve for turning on the water once installed, be careful, turning it on before the line is hooked will get ya soaked, it has compression fittings, make sure you dont cross thread the nuts when installing, you may have to shut the main water supply off to the house before doing this, the instructions are fairly easy to read, you can get 25ft - 100ft ice maker kits, you are going to need a tubing cutter and a cresent or box end wrench, and a big flat head screw driver, hope that help ya, lets us know, thanks again for the question,
mr.grzz
Jan 05, 2009 | Aprilaire 550 Humidifier
My vaporizer is making a spitting sound -
No salt, unless you had 0 steam - to stop water spit, throughly clean the water tank, just as clean as new. It will work like new if the tank is as clean as new! I dont know where the small particles of dirt come from, but trust me, I just went thru this with mine, it's got dirt in it!
Nov 19, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Changed filter for Aprilaire 600, but water doesnt flow now, how correct?
YOU SHOULD HAVE BETWEEN .250 TO.375 INCH WATER LINE ENTERING YOU'R HUMIDIFIER .THIS WILL TERMINATE AT A FLOAT VALVE.THIS IS MUCH LIKE THE VALVE IN YOU'R TOLIET.TRY PUSHING THE ARM DOWN,THIS SHOULD LET WATER INTO THE HUMIDIFIER,AS PULLING UP SHOULD SHUT IT OFF.IF THIS DOE'S NOT WORK THEN THERE (SHOULD BE A VALVE BETWEEN THE HUMIDIFIER & THE SOURCE)MOST LIKLY LOCATED NEAR YOU'R HOT WATER HEATER.MAKE SURE THIS VALVE IS ON!!! IF I'M RIGHT YOU MAY HAVE JAMED THE FLOAT IN THE OFF POSITION WHILE REPLACING THE FILTER HOPE THIS WAS SOME HELP>
Nov 06, 2008 | Aprilaire 600 Humidifier
Vaporizer That Works?
Have you tried adding salt to the water in the vaporizer? Sometimes the water needs to minerals for the humidifier to work...I add sea salt to mine every time I fill it.
Oct 12, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Robitussin Cool Moisture 1 Gal. Humidifier Logo
165 people viewed this question
Top Robitussin Humidifiers Experts
Paul Carew
Dennis
Are you a Robitussin Humidifier Expert? Answer questions, earn points and help others
