Question about RCA Audio Players & Recorders
RCA Model STAV-3870 Receiver
I was playing loudly and after about an hour, it shut off. It will not come back on, only the standby light turns on, the relay clicks but nothing comes on, no display or sound. I checked the internal fuses and the 2 main rectifiers and they are good. I tested and it seems as if the main transformer may be the problem. Not getting any dc current output to the boards. Any ideas what can be done? Repair costs etc?
  • 336 Answers
Very likely that the internal thermal fuse opened on the main power transformer. With the power cord unplugged, Check the resistance on the ac input of the transformer should read less than 10 ohms. Contact me when you know. I might be able to find one.
Posted on Jan 20, 2009
Se apaga el rca stav-3970 audio video receiver automaticamente al encenderlo
If you wish to get some details; check the site linked here. Pull up older posts.
Jun 29, 2016 | Televison & Video
Why is my RCA STAV-3860 not coming on?
It sounds like the unit is getting power but is going into standby mode due to an internal fault. Sadly, newer receivers these days are not designed to be repaired but replaced!
Jun 13, 2014 | RCA Radioshack 31-5003 Stav-3860 60-watt...
I've got a rcs STAV 3880 surround receiver wit ful volumn al the time
Sounds like a shorted audio IC or bad connection in the limiter circuit.
Mar 01, 2014 | RCA Optimus/Stav-3880 Rcvr Parts - Board -...
Rca receiver overload message
Power the unit off , Disconnect all the speakers ,power the unit back on and check to see if you get the same message, if so one or all of your speakers could be bad. This message appears when there is too much load on the output IC's,generally causes shutdown. Also try blowing the system out with canned air, And removing anything that prevents the unit from getting enough ventilation.
Feb 21, 2014 | RCA Stav-3870 Audio Video Stereo Receiver
No sound
look to see if muted or speakers switched off?
Oct 15, 2012 | RCA Radioshack 31-5003 Stav-3860 60-watt...
Were to buy remote control stav4090
RCA RECEIVER STAV-4090 REMOTE CONTROL TESTED - eBayhttp://cgi.ebay.com/RCA-RECEIVER-STAV-4090-REMOTE-CONTROL-TESTED_W0QQitemZ350325382341QQcmdZViewItemQQimsxZ20100309?IMSfp=TL100309199008r7940
also Amazon carries this as well,
Stina665
Mar 15, 2010 | Audio Players & Recorders
Receiver turns on and sound, when playing xbox a grenade goes off and the receiver shuts off..
If it is like a big POP and it goes out, then the amp is blown, or wires in the back are crossed. The amp might be going into protection. Most amps say PROTECT when that happens, but some just have standard breakers that shut it off when it is too loud, or wires are crossing. Check for that, and if it continues, then the amp is probably blown
Jun 17, 2009 | RCA Audio Players & Recorders
RCA PROFESSIONAL SERIES STAV 3880 Digital Optic input
Read the owners manual for setting up opt 1 and opt 2.
Feb 12, 2008 | Audio Players & Recorders
RCA RT2250 consistant shutting off in Satalite mode.
Mine will always just turn off every minute or so after a hard shut down(ex: power outtage). I have to turn it back on and then hold the set button for a few seconds, then it stays on, until i turn it off manually, since the remote won't turn it off.
May 15, 2007 | RCA RT2250 System
733 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
