How to setup vga to rca - Computers & Internet
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 34 Answers
You'll have to buy a converter like this one:
http://www.salland.eu/product/755122/microconnect-vga-to-s-video-and-rca-0-3m-30-cm-vga-male-monggsv.html?ref=45
Or
http://www.amazon.com/Premium-3-RCA-Component-Video-cable/dp/B000SJ2TJ8/ref=pd_cp_pc_1
Posted on Jan 06, 2013
CHANEL SCAN A RCA TV CONVERTER BOX
If the box has been installed correctly, you should be able to press SETUP (or some equivalent) on the remote to display a menu of choices including channel scan.
Jan 03, 2015 | RCA Analog (RCA) to Digital (VGA)...
Projector Purple Ghosting
aperently it has to do with converting the analogue signal to digital or the other way around..rca is the cable type..the signal is what you are having issues with..you may need a converter..it may also require going into the setup menu of the tv and make it recognize the signal..
Feb 08, 2014 | Office Equipment & Supplies
Rca rcrn04gr manual
http://voxrightnow.custhelp.com/app/answers/detail/a_id/10289/~/programming-the-rca-rcrn04gr-universal-remote
Jan 23, 2014 | Vizio VW22L VW22LHDTV10T 22 inch LCD HDTV...
I need the code for rca digital conv.box
Which code? For the Universal Remote? If so, it has a scanning function on it.
Dec 18, 2011 | RCA Analog (RCA) to Digital (VGA)...
Use TV as external monitor from laptop
no tube tv won't mirror monitor. needs vga connection at the back of tv.go to store have a look at lcd or plasma screen.the card is ok.
Jun 26, 2009 | HP Pavilion DV6500Z Notebook
While connected via VGA cable Viewsonic VG920 Monitor has an error stating "out of Range" . H. Frequency 157 Khz V. Frequency 59.8 Khz
It was pretty tricky without instructions but trial & error brought me to a successful resolution. This machine comes from the factory set to connect directly to a television with supplied RCA cable. Do that before you connect to a VGA monitor. Using the remote control, press setup and then go into "preferences" and look around for "video" and then to "VGA". Once you click "VGA" the TV screen goes frighteningly blank. The next obvious step is to hook it to the VGA cable and VGA monitor. If your computer is also hooked up and on to the monitor there is no karaoke picture. Shut off or disconnect computer and presto, there it is. <br>
www.texsax.com
Dec 13, 2008 | Cavs DVD-203G DVD/ SCDG/ CDG (CD+G)/...
How do i hook up a T5230 E Machine with no RCA port to A Emerson 32in Hd Tv with no vga port?
  • http://www.eforcity.com/pothvgasvrc1.html?gad=CNGV0_4CEgjzLnO-zCySDRiJp-j9AyDV7too
  • VGA to S-Video / RCA Adaptor
  • NOTE: Your VGA card must support TV out directly through VGA port function. Please consult with your VGA card's user manual for more information.
  • Cable adapter allows video output from your PC/laptop to any TV with S-Video or RCA video input.
  • Connectivity:
    • Connector HDDB15 15-pin (M x 1)
    • Connector S-Video mini din 4-pin (F x 1)
    • Connector RCA Composite (F x 1)
You can find several like this from 5 to 10 dollars , just search the phrase "VGA to RCA cable"
yell if you need any more help and thanks for using fixya. ------please rate-------
Oct 22, 2008 | Computers & Internet
I am trying to connect my PC to my TV. I have a Sharp HDTV and my PC is a Toshiba with windows XP. I have a componert video cable which is connected to the TV and PC. I have used Fn and F5 didn't work....
what model of TV was it please,
Does your computer have tv out video card installed?
For video to tv you will need a vga to tv converter,this is an external device and will work on the computers vga output straight into a vga input and give you 1 x vga out,1 x rca out, 1 x s/video out,comes supplied all prebuilt with onboard graphics solution. no extra power required runs straight of vga output.
Once the computers video output is established then set the TV up to tune into the converters output signal.
HD TV can be set up to run thru rca and components and if model is late enough shuld come equip with serial vga input for computers.Other than that HDMI seems to be the better quality of picture over rca component.Cost verses dollar really and function.
Cheap fix VGA to TV CONVERTER
Expensive Fix HDMI to HDMI
(it is posible to hdmi over cat5e)
NO COMPARISON FOR QUALITY.
Jul 10, 2008 | Acer Aspire 3680 Laptop
Ati mobility radeon 9000 agp
hi camperd55,
I believe you have the right adapter cable. According to my knowledge the Radeon 9000 supports TV output via RCA (check http://ati.amd.com/products/MobilityRadeon9000/index.html:" Mobility™ Radeon™ 9000 provides the highest quality output support for DVI-I, TV and CRTs.")
Firstly, it would be a good idea to make sure your TV has the 3 RCA jacks into which you will insert the adapter cable's 3 RCA connectors according to the colors of the connectors and jacks.
Secondly, if your laptop has a VGA port, you're set to connect your laptop to your TV, no hustles. If your laptop doesn't have a VGA port, your going to have to get a DVI-VGA converter, so you're setup will be something like: [laptop]-[DVI-VGA converter]-[VGA-3RCA adapter cable]-[TV's 3RCA jacks].
When you get your laptop's screen displaying on your TV, its merely a matter of using your recording equipment to record the TV's image as you would any program showing on the TV.
I hope this will help you solve your problem, thank you for using the FixYa service.
Kind regards
Henru : )
kind regards
Feb 10, 2008 | ATI Mobility RADEON Graphic Card
Computers & Internet Logo
David Payne
David Payne
