GE Spacemaker (Portable/Apartment NOT Stacker) will NOT Spin or Drain
Hi There, I just got a GE spacemaker Portable (apartment) washer. ALL digital functions work, washes fine, BUT it does NOT spin OR DRAIN!...NOW I am a lurker here & you group of experts helped us fix our last "old school" portable washer, the lid switch was broken. Hubby replaced (or bypassed, not sure) it & we were washing like never before thanks to you all here!! Now, we do NOT suspect this is the same & I will tell you why... The lid on this unit MUST close in order to not receive messages etc, and for the washer to even work the lid MUST be closed. SO.... Unless we are wrong, we are assuming it is something else since all of the lid sensor's functions work just fine! It does absolutely NOTHING, no water drains, no nada, so hubby, who is VERY mechanically inclined has asked me to request your knowledge!! An input would be appreciated!! Our best in 2013!! Christina & Juan
  • C Arroyo Jan 06, 2013
    Thanks all, It is NOT the hose, put it in a bucket & it drained...Ron, not Curdy here, but May I ask WHY/on what basis you believe it is the lid switch, as I stated we have had a lid switch problem before & THIS is NOTHING similar!?? Mohammed, Any idea where I can get a diagram/instruction/etc to see where these components are for Fuses/heating element/how to put in diagnostic mode etc...Any help is GREATLY appreciated!!
    OK, as my title says this is NOT The stacked model, it is the Portable/apartment WASHER NOT a washer/dryer duo, so thanks Maytag, but not the same model...MOhammed, you sound like you know what my next step is, PLEASE post back!!
2 Suggested Answers
mohammed387
  • 1952 Answers
SOURCE: washer will not drain water or go into rinse and spin cycle
First thin I would try is to check your thermal fuse for continuity. Its located on the tunnel that incases the heasting element.
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
You also want to check the drain hose, the end of the hose is tapperd and tends to collect lint. Run a coat hanger up the hose and see if you can fish something out also check that belt.
Posted on Oct 06, 2008
GE Spacemaker Washer Tan does not spin or drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | GE Spacemaker Washer and Dryer Electric...
My spacemaker will not drain or function in spin cycle
Hello & Welcome to FixYa
When the unit is unable to drain it will not even work in spin cycle, the problem is with blocked drain/drain pump filter which should be cleaned. If after cleaning the problem comes back then the drain pump needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 03, 2011 | GE Spacemaker Washer and Dryer Electric...
Washer won't spin and empty the water out of the
Shirley, it may be the drain pump is obstructed or possibly the lid switch is broken. If you washed bath mats or rubber backed rugs recently i would go for the pump. If you washed a semi bulky item with a tendency to float I would go for the switch.
Get me a model number and I can help you with dis-assembly if you'd like further help!
Jun 11, 2010 | GE Spacemaker Washer and Dryer Electric...
Water is not draining?
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | GE WSM2480DWW Unitized Spacemaker Washer...
My GE spacemaker top loader will not drain, makes buzzing noise
May 29, 2010 | GE Spacemaker Washer and Dryer Electric...
GE WSM2480TBAW Spacemaker Laundry, Won't Drain or Spin
you need to remove the slanted panel between the washer and the dryer. There will be 2 screws holding the top of the washer to the cabinet. Locate the screws on the back edge of the washer top along with the 2 brackets that hold the top.
Once the brackets have been removed, the washer top panel will pull toward you and lift off of the cabinet. You will be able to see the lid switch and test it. If you are testing the lid switch for continuity, remamber to activate the switch while testing. If the switch shows an open circuit, replace the switch.
Please let me know if this hhelps you at all or if I can assist you further.
Thanks
Vic
Jul 23, 2009 | GE Spacemaker Washer and Dryer Electric...
Washer does not "click" to drain and spin cycle
Hi, Check the lid switch. Most models will not drain or spin when the lid switch is bad.
If I can get the model#, I wil try and asist you further.
Vic
Jun 21, 2009 | GE Spacemaker Washer and Dryer Electric...
Spacemaker spin cycle problem
you may have something stuck in the drain pump......
first try using a wet/dry vacuum attach it to the drain hose and try to **** out what ever you have stuck in there... if that works you are good... if not you will have to get open the cabinet to get to the drain pump
Dec 23, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Ge spacemaker
check power at the receptacle make sure you have 240v
May 11, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Washer does not drain water
Make sure the drain hose is not kinked
Dec 27, 2007 | GE Spacemaker WSLP1100D Top Load Washer
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
