Question about HP Pavilion dv6426us Notebook
I need a recovery disk for my hp pavilion dv6426us
And when i press quick lunch buttons thay dont disapear on display which key ive pressed
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 34 Answers
Have you already tried shutting your PC down and turning it back on again? Else you could try to reinstall the software that came with it or the software from the website
Posted on Jan 05, 2013
  • araz Jan 05, 2013
    yes and where can i get a recovery disk
  •  Dion Maas
    Dion Maas Jan 05, 2013
    Usually you can get it via HP, maybe via their site or a retailer. I can also look one up if you're comfortable with Torrents
Hard disk error no recovery disc
@lizegim
HP laptops have a built-in recovery mode on the system wherein you don't need to use a disc to restore it to factory default. The hotkey for the recovery is the F10 key. After you press the power button, you need to simultaneously press the F10 key to start system recovery. If this one won't work and gave you like an "I/O Error" or "Error 0x000000E" or something similar then that means that the HDD is already defective and needs replacement and you need to order the recovery discs from HP at 1-800-474-6836. If you're still under warranty, they'll replace the HDD and give the Recovery Discs to you for free.
Good luck.
Sep 06, 2011 | HP Pavilion A250n (DF253A#ABA) PC Desktop
How do i restore my hp pavilion dv 5000 to factort setting?
There should have been a recovery disk created or included when you bought a laptop. Insert disk if you have it and restart your computer with the recovery disk in the CD drive. Make sure all your documents and personal data are backed up. When the computer restarts it should start restoring your computer to the factory default. There will be a wizard to guide you through the process.
If there is no disk or got lost,then follow this steps:
1.Save any files or folders on your computer with flash drives. Drag and drop files onto the icon of your flash drive.
2.Go to "Start" > "Restart" to reboot your netbook.
3.Hold down "Alt" and "F10" when you see the logo on the screen. The recovery menu will load.
4.Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your computer back to factory settings. Follow the instructions on the screen.
5.Choose your time zone and language when the customization menu appears. Reboot when you are prompted.
6.Restore your saved files from the flash drive.
hope this helps,Goodluck..pls response with your rate and testimonials below for further issues..thanks
Feb 23, 2011 | Computers & Internet
My HP Dv6-1030us will not boot up. It turns on, but then it stays on the screen that says "HP invent, with "press the esc key for startup menu" in the lower left corner of the screen. ...
Please Reinstall the OS from F11 Recovery Manager by continuously tapping the F11 Recovery Manager Key after pressing the Power Button to turn on the notebook and select advanced options and select system recovery and run the Back up up your data first and run the recovery to fix the issue
Feb 15, 2011 | HP Pavilion dv6-1030us Notebook
I can't get any display on the screen of my pc.The power is working very well and all the led indicators are on. No sound during POST, and I have tried connecting a screen through the external screen port....
  1. please follow the following instructions i hope this helps
  2. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  3. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  4. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning
Jul 12, 2010 | HP Pavilion TX1320US Tablet PC
Need a recovery disc for Pavilion dv-5 notebook
Hi:
You most likely have a bad hard drive, and a disk set is not going to help you, though you will need it too.
What you need is a new hard drive, a copy of all the drivers for your laptop, which you can download for free from HP. If HP won't send you a copy of the recovery disk, you can use any OEM copy of the same operating system that your laptop has a sticker for, but you won't have all of your programs.
Nov 23, 2009 | HP Pavilion dv5-1140us Notebook PC
Windows vista installation
If you purchased it new, you can probably get a recovery disk from HP.  HP usually puts a recovery partition on one part of the disk, but if your utility program wiped that out, then you will need help from HP directly.
You can try HP's website by starting here: http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-001&h_query=pavilion+dv6000&submit=Go+%BB
The following discusses ordering a recovery disk: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00810334&lc=en&dlc=en&cc=us&product=1842155&rule=21883&lang=en
If the recovery parition is still intact, you might be able to recover based on this link: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&rule=21883&product=1842155&docname=c00809678#RecoverOS
Restore the PC to its original condition with the HP Recovery Manager if Windows Vista is not accessible If the PC cannot launch into Windows, it may still be possible to use the HP Recovery Manager on the hard drive to restore the computer to its original operating condition by first pressing the Power button to start the PC, and then pressing the F11 key to start the HP Recovery Manager. NOTE: Depending on the BIOS version, your computer may display multiple prompts during startup including F11 to start System Recovery. Pressing the F11 key on a computer with an HP factory image will start System Recovery even if the prompt is not displayed.
  • If the HP Recovery Manager can access the hard drive, a prompt is displayed to backup the user files before beginning the recovery. Follow any on-screen instructions.
  • If the HP Recovery Manager cannot access the hard drive to fix any system errors, use the set of recovery discs to recover the hard drive to its original condition.
Apr 25, 2009 | Microsoft Office Professional 2007 Full...
Hpdv4000 keeps restarting and cd drive isnt being detected
First are you following the instructions from HP. The reason whys is that the CD drive should be picked up while the computer is doing a self test in POST. You may have to look into the bios to see if its there, If its there then technically it should work with recovery disk. As far as I could see I this unit dose not have a recovery partation so you will have to reinstall it using a cd drive. Worse case will be using a USB drive if your BIOS supports it.
The following is HP's instructions to reinstall.
Follow the steps below to reinstall your operating system:
  1. Connect the AC adapter and turn on the notebook PC.
  2. Insert the OSD into the CD or DVD drive.
  3. Press and hold the Power button for five seconds to turn off the notebook.
  4. Press the Power button again to start the notebook.
  5. Press any key to boot from CD when prompted. The Welcome to Setup screen is displayed.
  6. Press the Enter key to continue. A Licensing Agreement screen is displayed.
  7. Press the F8 key to accept the agreement and continue. The Setup window is displayed.
  8. Press the Esc key to continue installing a fresh copy of the operating system without repairing.
  9. Press Enter to setup the operating system.
  10. Press C to continue using this partition.
  11. Select Format the partition using the NTFS file system (Quick) and press Enter . A caution is displayed that formatting this drive will delete all current files.
    • To cancel this procedure press the Esc key on the keyboard.
    • To continue with reformatting your hard drive press the F key on your keyboard.
  12. The reinstallation process begins and may take several minutes to complete. The notebook restarts into Windows after the process is complete.
    NOTE: When prompted for the product key, refer to the Microsoft Certificate of Authenticity located on the bottom of the notebook.
Apr 22, 2009 | HP Pavilion dv4000 Notebook
System reboot
1 Turn off the PC. If necessary, press and hold the On button until the PC turns off.
2 Disconnect all peripheral devices from the PC except the monitor, the keyboard,
and the mouse.
3 Press the On button to turn the PC on.
4 During the startup, do the following to enter the System Recovery program:
When the blue screen with the HP Invent logo appears, press the F10 key on
the keyboard. (You have only a few seconds to press the F10 key before the
normal startup process continues.)
5 The PC starts the recovery; wait for the onscreen instructions to display, and
then follow those instructions.Please select non destructive recovery which will make all your data safe.
6 Complete the PC startup, and finish the registration process. Then reconnect
all peripheral devices.
starting system recovery if the pc is not responding
Dec 30, 2008 | HP Pavilion A530n (DW234A#ABA) PC Desktop
How do I reboot my HP Pavilion Desktop and start new?
If you can't do a shutdown via the software, press and hold the power button in for about 5 seconds. It will turn off. Then press the power button to start booting.
Watch the monitor carefully for a message similiar to: For Setup Press F10. For Recovery Press F11. They can be any F keys, but you have to be quick. You only have a few seconds to make a choice. If you miss it, try again.
Once you press the correct F key, it should open the Recovery program on your computer. Do a full recovery.
You may also be able to initiate the recovery program inside Windows. Sometimes the program is in Start>All Programs>Accessories>System Tools>Recovery.
Nov 04, 2008 | HP Computers & Internet
HP Pavilion dv6426us Notebook Logo
60 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
