My dishwasher starts then after a few mins it beeps and when i open it the lights are flashing and its beeping,when i look at the manual it says the control unit failure what do you advise
I have a baumatic bdw5, when i put it on a program after 5 mins the program stops 4 lights start flashing and there is a beeping noise. I have checked the drainage and spray handles HELPI have a baumatic bdw5, when i put it on a program after 5 mins the program stops 4 lights start flashing and there is a beeping noise. I have checked the drainage and spray handles HELP
AnonymousMar 02, 2008
after 5 minutes machine starts bleeping. All 4 lights on the far right are flashing... it seems to happen once the tablet door opens, tablet also wasn't dispensing into machine.... I've checked filter etc and water is all draining away! I've also cleaned out and dryed the tablet holder! after 5 minutes machine starts bleeping. All 4 lights on the far right are flashing... it seems to happen once the tablet door opens, tablet also wasn't dispensing into machine.... I've checked filter etc and water is all draining away! I've also cleaned out and dryed the tablet holder!
After a few minutes of a start of a cycle.. machine starts bleeping and all 4 lights on the far right are flashing... Seems to happen when dishwasher tablet door opens and tablet isn't being dispensed into machine. I've checked filters and all water is draining away ok and I've cleaned and dried out tablet dispenser.After a few minutes of a start of a cycle.. machine starts bleeping and all 4 lights on the far right are flashing... Seems to happen when dishwasher tablet door opens and tablet isn't being dispensed into machine. I've checked filters and all water is draining away ok and I've cleaned and dried out tablet dispenser.
my dishwasher also starts then after a few mins it beeps and when i open it the lights are flashing and its beeping,when i look at the manual it also says a control unit failure. what do you advise?my dishwasher also starts then after a few mins it beeps and when i open it the lights are flashing and its beeping,when i look at the manual it also says a control unit failure. what do you advise?
You can't post conmments that contain an email address.
The dishwasher has too much water in it, this is a safety feature.
Underneath is a tray at the bottom, you need to empty this before it will start again. I've had this problem many times. My dishwasher had tiny holes in the bottom tray where the basket sits, went rusty due to not using it very often (holiday home). dried it out, applied silicon sealant to the edge where the metal sits, let it dry and the problem was solved.
I have used a sucking water vacuum to remove water, or tipped it forward. Hope this helps for maybe next time.
When this has happened to us, it has meant a new control panel being fitted. It has been nothing to do with the draining process, just the electronics. The control panel isn't too expensive, but if you call a Baumatic engineer he will come out, do nothing and come out again and it will prob take about a month. I suggest you find a fixed price engineer who will perhaps be able to mend it on his first visit if you suggest the control panel. We have so many problems, we tend to buy in spares in advance so that they are in the house for the engineer and he can't fob us off with a return visit two weeks later. The parts that go are doorstraps, the control panel, the thermostat and the element. We haven't mended the control panel ourselves, but all other problems are pretty easy to do yourself.
I've not changed a control unit before, so I don't know how easy it is. I would suggest you get a fixed price engineer to come out and tell him in advance what the problem seems to be. Or call a Baumatic engineer and have the control unit sent by the spares department to your address in advance of the engineer's call out. Otherwise it will become around a month long wait and will require 2 visits. If you already have the part - then pehaps the repair won't be stretched over 2 visits?
