I have sony bravia kvl40u100 it has sound no picture what could be wrong
It does have white light coming out back of tv i think its the t con board is this right
  • 933 Answers
If there is white light coming out of the back of the set, it sounds like the inverters are firing and your backlights are working. Is the screen pitch black? Gray? White? Blue? It could be a defective T-Con, main board, faulty power supply rail, or in rare cases, a faulty LCD panel.
Posted on Jan 06, 2013
dsacco86
  • 1077 Answers
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 29, 2009
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
  • 28 Answers
SOURCE: Sony Bravia with really bad ghosting
The little board on top attached to panel.
Posted on Jul 05, 2010
  • 115 Answers
SOURCE: Left half of my TV screen is completely white
That is only available to Sony authorized servicers. See esupport.sony.com
Posted on Jul 31, 2010
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
Posted on Aug 05, 2010
No picture, no sound display though back light lamps are ON.
Contact the authorized service center for Sony. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 16, 2015 | Sony Bravia V-Series KDL-52V4100 LCD TV
No Pitcher
its the t-con board if the backlight is coming on and there is sound then the t-con board is faulty. this is the board on the back of the screen has a cable going to it from the main av board. replace with same part number only. this has to match the screen.
Jul 15, 2017 | Sony BRAVIA® KDL46SL140/91 46 in. HDTV LCD...
Phillips 52pfl5704d turns on screen blinks, no video
The replacement board could be defective. Your TV worked fine until there was a power loss so its time to troubleshoot to find out how the power loss affected the original board in theTV. There could have been a power surge.
Dec 12, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony 40 inch Bravia screen has sound, but picture have weird lines that go across screen
It could be caused by a bad T-Con board or defective LCD panel. The panel is more expensive than the TV, so hope that it is the T-Con board. Below is a parts list for your TV model.
http://www.tristatemodule.com/t-Search.aspx?q=KDL-40S2010
Nov 03, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Tv Bravia won't switch on for days, when on only white light and sound no pictures. Help
I think fault is in electrolyte capacitor.You should check the supply volt of cathode & all relative component of RGB input.
Jan 12, 2012 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Double and triple images on left side of tv what is wrong?
YHi this can be cause by two things. Either your screen is defective or your t-con board is defective. The t-con board would be the more economical to replace.
You can get parts for this tv at www.interliquidparts.com
Dec 16, 2011 | Sony BRAVIA KDL-52XBR4 LCD TV
My Sony Bravia KDL-52W3000 when turned on after being off for a while has a weird double/distorted picture for about 15min. then it clears up and has a perfect picture for the rest of the time you watch...
CHANGED Z SUSTAIN BOARD.PICTURE PERFECT.APART FROM WHITE DOTS..THINK IT COULD BE DUST OR FINGER PRINTS ON RIBBON JOINTS,,WILL RE CHECK AND WIPE F/PRINTS TO SEE IF ANY CHANGE
Take care.....
Aug 04, 2011 | Sony BRAVIA KDL-46V3000 Television
Tv turns on has sound
Have flashes of picture about 30 sec, or so?Than the 2 long LCD inverter boards are dead,have backlight make no difference.Tries to reset the tv back to factory setting by,unplug,replug the tv and cable box back about an hour later,let the tv Tuner board to reset it self,the cable box upgrade it softwares.After this,u still have the same problems,than the Tuner board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy the 2 long refurbishes LCD inverter boards or the Tuner board for the replacement.
Jun 24, 2010 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Tv picture is pink with vertical lines sony bravia 32 inch XBR
it sounds like a bad t-con board. this board my not be sold without geting the whole screen. the t-con borad is at the top of the screen and connects to your main board
Apr 15, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
