Question about LG Washing Machines
No water on wash cylcle rinse works fine - LG Washing Machines
    New Friend:
Step 1:
Check the water when you start a cycle with a lot of water needed
Step 2:
Now you need to check the water is on
Step 3:
Now you will need to check the ghose is not got a hole in
Step 4:
Try the machine again with no items and no detergent hopefully it will have water in
Posted on Feb 25, 2013
SM 8525492A whirlpool washer rinse cycle no water comes out, just hums
when the washer goes into rinse cycle it only uses cold water so clothes don't rinkle,so most likey you have a problem with your cold water,do this,shut down the water to the washer,remove the water lines from the back of washer and mark them so you know how they came off,stick the hoses into the washer if they reach or a bucket,turn on the cold water to see if water is coming out of hose,if water does come out of hose good then stick the cold water hose back on the washer and run it only on cold,if it doesn't fill then you know you have a problem with the water valve on the washer and it's not the house water valve that's bad,and usually if you have a problem with the washer water valve it will just hum and no water will enter the washer so if you hear a humming sound it will be the water valve.tried looking up the model number you sent but it doesn't come up on the parts lookup
Apr 25, 2013 | Washing Machines
Ok so my washer runs fine until rinse or spin cylcle then it kind of works for a minute then does a weird thing where it clicks off and on after a couple minutes it stops completely after 5 or so more...
It really sounds like a timer issue. The electrical contacts inside the timer are worn and not sending voltage to the motor. It is what we call a "dead spot". If it really works well in other cycles that would be a tell tale sign.
Feb 17, 2010 | Whirlpool LSR9434PQ Top Load Washer
No cold water from washing machine. Hot water is fine.
You have to replace the cold water solenoid valve.
Oct 05, 2009 | Westinghouse Washing Machines
Cold water only works on rinse cylce not was
post model number in problem description
Apr 04, 2009 | Maytag Washing Machines
Hi i ahve an equator ez3600 washer dryer unit
It may have been leaking from the drain pump and you may want to check if it the drain pump by opening the back panel and checking if it leaks just when the drain pump starts to function.
Feb 27, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Kenmore HE2plus wont spin...F-21 error
Apparantly the F21 error means there is a drain problem...I removed the drain hose from the output in the wall and held it down at ground level and let it drain into a pot...I ran the rinse, drain and spin cycle while I did this but before I hit the start button I hit the 2nd rinse button to turn off the rinse portion of the cycle. It seems to be draining fine now.
Jul 01, 2008 | Washing Machines
Kenmore 700 series top load washer problem
Take the washer back. We just bought the same one and have the same problem
Feb 18, 2008 | Washing Machines
Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
May 10, 2007 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
49 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
