Question about Kitchen Ranges
Oven (665.5012101) wont preheat above 285 degrees.
textonor
  • 130 Answers
SOURCE: Oven takes up to 25 min. to preheat
I would suggest looking at how long before the bake burner ignites. If taking longer than 5 minutes before it ignites, then you are looking at a possible bad ignitor. The ignitors just don't last more than 5 yrs with regular use.
Posted on Jan 06, 2008
  • 148 Answers
SOURCE: Takes to long to Preheat
the burner element iside the oven(the rod that glow,s orange) is burned out,even though it glows and the oven is warm,the element is worn out and has to be replaced,unplug the oven,shutt off gas supply to oven,pull off back cover youll see the rod coming thru each end of the rod will have 1 wire unplug the wire off the clip,go back to the inside the oven follow the rod to the back youll see 2 screws holding the rod unscrew and pull rod thru,easy job and elements arent exspensive,but make sure to unplug oven,and shut off gas
Posted on Jul 09, 2008
MNTECH
  • 1543 Answers
SOURCE: Oven takes a long time to preheat
You don't list a full model number or how old this range is, or how long / how often you have this problem, but generally it sounds like the oven ignitor is not quite drawing enough amps to allow the gas valve to open regularly. It could be a low voltage related issue, but most likely is a failing oven ignitor. ( WB2X9154)
Posted on Sep 04, 2008
aborcass
  • 2651 Answers
SOURCE: low oven temp.
sounds like a bad oven/bake ignitor. very common problem on all gas ranges.
Posted on Oct 21, 2008
  • 219 Answers
SOURCE: oven temp maytag MER5770
check your element if thats fine u need to replace your erc and possibnly your oven sensor
Posted on Mar 25, 2009
My Maytag Gas Oven MGR5750ADW preheats on certain temperatures and not others. For example it wont preheat at 350 degrees but will preheat at 380 degrees. At 350 we smell gas.
What you have is an ignition problem get this corrected before you experience a delayed ignition, the hot surface ignitor pulls enough amps 3-3.4 to power up and open the gas valve but ignition did not take place reason you smell gas don't know how old unit is ignitor may be weak good on draws 3-3.5 amps burner ports may be dirty or the bracket that the ignitor mounts too may have bowed away from the burner
Jan 29, 2015 | Maytag MGR5750 Gas Kitchen Range
How do you reset the frigidaire wall oven?
Good Afternoon Friend,
I understand you are trying to reset your Frigidaire wall oven, model# FEB27S5A, due to it not heating above 100 degrees. I suggest resetting at your homes circuit breaker for 3-5 minutes. When you restore power, you will first need to set the clock. After setting the clock, preheat your oven. If you are still noticing that the temperatures are still not going above 100 degrees, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to not reach the desired temperatures. Hope this is helpful.
-Best regards-
WP
May 11, 2014 | Frigidaire FEB27S5A Electric Single Oven
How close should the temp control hold the temp
Generally the oven temperature will fluctuate as much as 30 degrees above or below the set temperature. The longer the oven is on, the less the temperature fluctuates. If you measure the highest and lowest temperatures readings with a thermometer after the oven has been preheated at least 20 minutes, you should come up with an average temperature somewhere within about 10 degrees of the set temperature. You can calibrate most ovens up to 35 degrees higher or lower if it is off. Any more than that requires replacing parts.
Apr 24, 2014 | GE Profile JTP18 Electric Single Oven
The oven will only preheat to about 285 degrees. We took the heating element in to get tested and it was fine. What else could it be?
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Feb 08, 2011 | LG LRE30451 Electric Kitchen Range
The oven will only heat to about 240 degrees. It's very slow to preheat and doesn't seem to get above 240 degrees in about 45 minutes.
The most likely cause is the bake element. The floor of the oven is removable exposing the element (74008693) It will likely be visibly broken.
Jan 13, 2011 | Maytag MER5775Q Electric Kitchen Range
My oven won't heat above 150 degrees. Is this is
this can be problem with the temp probe.and or the control board if your unit is equipped.
Jan 23, 2010 | Ovens
Brand new Frigidaire FGB24S5A Gas wall oven not registering corre
some units will need to be adjusted if you live in a high altitude above 3000ft.
Dec 10, 2008 | Frigidaire FGB24S5A Gas Single Oven
Kitchen Ranges Logo
66 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
