Question about Whirlpool Duet WFW9150WW 4.0 Cu. Ft. Front Load Washer - White
I have a Whirlpool Duet, all the 'programs' stopped functioning properly when the wash/soak cycle starts.
I have a Whirlpool Duet Front Loading WFW9150WW, all of a sudden the 'programs' stopped functioning properly. The water isn't coming out for the wash cycle, even though trying with a 'rinse+spin' only is fine. 'Soak' seems to be a problem too. Got an error F8E1, but that doesn't seem to say much. Any ideas? Basically, there's a small gush of water that goes through the detergent area at the beginning, and then nothing, it's spinning and the 'wash' light is on, then after a while it stops and beeps and blinks 8 - 1.
  • Thomas Jan 06, 2013
    So I decided to run it again a few days later. And now it works fine it seems. I did try a number of times over the course of two days and always the same problem, now magically gone. I remembered reading somewhere about water temperature being an issue sometimes, although it seemed far fetched in my case since they mentioned the water had to be below 5C to cause an issue. Anyway, we were having some pretty serious cold weather (-20something) at the time but now it's better so I decided to give it a shot just in case. Don't know if that was related at all, hopefuly yes so that would pretty much solve my problem.
aborcass
  • 2651 Answers
SOURCE: My whirlpool duet washer is making a funny noise
try removing the top cover to the unit, 3 screws across the back. after ermoving check to see exactly wehre noise is coming from. some times a solid "smack " witha screwdriver will quiet teh dispensor motor if needed
Posted on Mar 07, 2009
  • 240 Answers
SOURCE: water leaking from the soap dispenser during rinse and spin cycle
use liquid instead of powder and always use HE detergent
Posted on Apr 26, 2009
  • 327 Answers
SOURCE: Washer stopped during spin cycle
Hello, try to checked the pump filter, and the pump is actually working. then I would suspect a draining problem.
If filter clean and pump works fine then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Thanks
Posted on Jun 04, 2010
Macmarkus
  • 2605 Answers
SOURCE: Whirlpool Washer WTW57ESVW0 will fill
Hi, Welcome to FixYa. I would start by removing your water fill hoses and checking the screens/strainers at both ends for blockage. If the "hot" is blocked it won't work however, it will in rinse since it only fills with cold in rinse. It may also be a defective coil in the valve, but I would check for blockages first. Let me know what you find and if you require further assistance and I will reply asap. Regards. Macmarkus :)
Posted on Aug 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: Error Code F8E1 on Whirlpool Duet
f8 is shown when the heater circuit is on with no water in.. it doesnt do it when you unplug the pressure switch because your disabling the heat protect circuit
THE BOARD IS PROBABLY FAULTY
F08 indicates pressure switch stuck on full.
Unplug the appliance from the wall socket.
Take the top off the machine.
Locate the pressure switch, you can identify it by the thin tube attached to it.
Take the tube off, blow down this tube as hard as you can to shift any blockage or restriction in the pressure chamber. Give the pressure switch a couple of good taps with the screwdriver handle.
Refit the tube and try the machine again.
If still doing it, unplug again and follow the tube down.
This end will be attached to the pressure chamber.
Take this chamber off and thoroughly clean it out, clean out the port into the tub too.
Reassemble and try again.
If after this it's still faulty you'll need to start replacing parts.
I'd suggest trying a new pressure switch first.
Failing this, if all of the above fails to resolve the problem you're possibly looking at a faulty main control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
My whirlpool steam duet washer won't pour water in the wash cycle
There is no output from the control panel to switch on the inlet valve, so check the inlet valve at this time of the cycle. Also check the water level pressure sensor switch.
Choose another program to confirm if not the controller seems to be suspect.
Jan 24, 2013 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet after pressing start button nothin happens. goes thru add garmet and wash just beeps. no water rushing in
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle.
What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
If there is no water flow the inlet valve is a suspect.Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Sep 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a front load whirlpool Duet washer I stopped the wash cycle to put more clothes in now it just flashes the time left in the cycle but will not restart what can I do?
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Jul 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
How do you soak clothes in Whirlpool Duet
front loaders don't have a soak cycle because of the very little water that they use.
use the pre-wash setting to extend the time.
Nov 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet stuck on spin cycle
Press 'end of cycle' for over 3 seconds. Perhaps you have to check your filter, maybe clogged.
Feb 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet Front Loader
F2=Long Drain If the drain time exceeds 8 mins the water valves are turned off and F02 is displayed
Check drain hose
check pump filter for foreign objects
check pump motor for proper operation
Jul 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet WFW9150WW 4.0 Cu. Ft. Front Load Washer - White Logo
46 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
