Question about Singer 7467S Confidence Stylist Electric Sewing Machine
Needle does not move, machine beeps on a straight line
  • Singer Master
  • 18,394 Answers
My jones sewing machine wont stitch straight just zig zag tried moving parts
Probably the zig-zag mechanism has seized from lack of oil/cleaning. Pick up fresh, good quality sewing machine oil or Tri-Flow Synthetic Lube and apply a couple drops every place where metal rubs against metal (including the zig-zag mechanism). Do NOT oil any rubber or leather parts (belts)!!!
Then apply heat from a handheld hairdryer. Repeat until it loosens.
Aug 15, 2016 | Sewing Machines
How do I change the needle position on my Bernina 1630?
Not sure, but if this is the one with the track ball, try pushing in on it to activate needle position.
Nov 18, 2014 | Sewing Machines
Our simple 3116 won't zigzag stitch,the needle is off to the right and will not do any other stitches. Help!!
It won't do straight stitch?
Take the needle out... see if it is moving the fabric when you press on the presser foot. If it is not, then you need to raise the feet (it's under the accessory box/table face. If it does move the fabric. Make sure your machine is set to Zig Zag. again without needle... sew. Does the needle bar move? change to straight stitch, does the needle bar move? If it does I think you have the wrong size needle. If it does not, I'm afraid your plastic machine has broken... take it in for repair.
Oct 04, 2014 | Singer 3116 Simple
Why does my Empisal sewing machine miss stitches , sew, miss, sew?
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
5. If the above suggestions don't help then the machine needs to be checked
For a timing problem,, the feeddogs may need to be checked to see why they are not moving the fabric thru the machine.
the
thettttt
the the
Aug 26, 2014 | Sewing Machines
Zigzag blocked, only straight lines
In the upper portion of the machine, there is usually a cam mechanism that moves the needle side/side during a zig-zag stitch. It's possible that a pin or something has fallen into the machine & is preventing the needle-arm from moving properly.
There are usually only a few screws that hold the upper housing cover in place. Open it up and check the needle arm movement from there. Chances are, the problem will reveal itself thru a close inspection of the moving parts involved.
May 04, 2014 | Necchi Sewing Machines
Needle alignment
it's possible that the needle bar is out of adjustment or bent
I would suggest to have the machine checked by a service
technican
Nov 22, 2012 | Sewing Machines
Zigzag stitch not catching
try these suggestions and see if they help
Skipped stitches
Oct 19, 2012 | Brother CS6000i Computerized Sewing...
I can not figure out how to set a straight stitch. I don't want a zig zag or a decorative stitch. How do i set my machine to do this?
First, make sure you select the straight stitch setting on the round dial. It is the one that has the dashed lines, looking like the stitch itself. Then, you may also want to be sure that the stitch WIDTH (dial with the picture that looks like a straight line gradually turning into a zig-zag) to the lowest setting, which is generally 0. With some machines, even after selecting a straight stitch setting, moving the stitch width can change needle position. Sometimes it will initiate the zig zag, other times it will move needle position left to right. Does that fix it?
Jun 24, 2011 | Simplicity Denim Star SW210
My CE 200 jammed and I cleaned it out now it won't pick up bobbin thread how do i reset the timing?
To reset the timing on your machine there are timing marks that show you where the machine must be set.
Remove the needle plate and bobbin case. Turn the hand wheel towards you until the needle bar is in the lowest position. You will see two marks on the needle bar with the top one being flush with the bottom of the bushing. If it is not, loosen the needle bar screw and move it up or down to set the marks. Make sure you keep the needle bar straight (needle clamp screw should be straight to the right).
Next turn the hand wheel until the lower timing mark is flush with the bushing. At this point, the hook tip should be just above the eye of the needle.
If the hook tip and needle do not line up, turn the machine on its back making sure the needle bar does not move. Loosen the two timing screws on the hook pulley (only loosen them 1/4 turn). Move the hook to line it up with the needle. Tighten the screws and recheck the timing. The feed dogs should be in the down position when timing the machine. If the feed dogs are up when the timing is done, the hook timing is out 180 degrees.
May 12, 2009 | Singer CE-200 Quantum Futura Computerized...
Just replaced my uppper looper on my white 1634....
Hi.
The upper looper goes just in front of the needles. I had issues with my machine when I got some fabric jammed and the looper moved so it wasn't catching the left needle and it was sewing a straight stitch on the left. The looper needs to be placed in front of the needles and very close to the needles without hitting them.
Hope this helps!
Cherie
Nov 01, 2008 | Singer White Speedylock 1634
Singer 7467S Confidence Stylist Electric Sewing Machine Logo
53 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
