Table of diagnostic beep codes compiled by AMI BIOS during power-on self test[8][9] Number of beeps
Meaning
1 - power-on self test successful
2 - Parity error in the first 64KiB of RAM
3 - Memory failure in the first 64KiB of RAM
4 - Same as 3, but also including a non-functional timer 1
5 - CPU error
6 - Error in the A20 line on the 8042 keyboard controller chip
7 - Generation of a CPU virtual mode exception signifying an error
8 - Read/write error when accessing system video RAM
9 - Mismatch between the calculated checksum of the ROM firmware and the expected value hardcoded into the firmware.
10 - Read/write error for the CMOS NVRAM shutdown register
11 - A fault in the L2 cache
This is caused by the intel chipset overheating. Your drive is usually ok, but the chip controlling the drive is too hot to function properly. Try blowing your CPU fan out with compressed air, then start using a laptop cooler to keep it cool and this problem should go away.
besides the beeps which indicate a motherboard timing issue. There should be LED blinking codes given on the front LEDs. I will include the blink codes below, but lets try to at least get the system up and running. First, I would like you to remove the RAM sticks from the laptop and just reseat one stick back in the machine. Try to boot with that one stick, if it does not, try the other alone. There have been issues when reseating the ram or re-installing it have temp. fixed the issue. If it does reboot, go to the HP support site, put in your model number of your laptop and download and install an updated BIOS. Below are the blink codes that may narrow down the problem.....
HP DV6000 LED Blink Codes
LED Component Error Condition Blinking battery power LED Battery Insufficient charge on the battery Blink: 1 - Caps Lock/Num Lock CPU CPU not functional Blink: 2 - Caps Lock/Num Lock BIOS BIOS corruption failure Blink: 3 - Caps Lock/Num Lock Memory Module error not functional Blink: 4 - Caps Lock/Num Lock Graphics Graphics controller not functional Blink: 5 - Caps Lock/Num Lock System board General system board failure Blink: 6 - Caps Lock/Num Lock BIOS BIOS authentication failure
does your machine make it to the windows login screen, or does it fail before.
I think you haven't installed you CPU correctly, or maybe did not put heat sink compund evenly on the heat sink, and that causes the CPU to overheat and freeze.
it depends on the bios chip maker Here's some other beep codes:
for Award and Phoenix BIOS:
1 short beep: Normal 2 short beeps: CMOS error 1 long and 1 short beep: DRAM error 1 long and 2 short beeps: Video card error 1 long and 3 short beeps: Keyboard error 1 long and 9 short beeps: ROM error Long continuous beeps: DRAM not installed correctly Short continuous beeps: Bad power supply
AMI BIOS:
1 short beep: DRAM flash error 2 short beeps: DRAM ECC check error 3 short beeps: DRAM detect error 5 short beeps: CPU error 6 short beeps: Keyboard error 8 short beeps: Video card error 9 short beeps: ROM error 1 long and 3 short beeps: Bad DRAM 1 long and 8 short beeps: Video card error
Invoking Beep Codes
If the computer is actually functioning and the computer beeps continuously, then there is a problem with a voltage on the power supply being incorrect or the CPU overheating. IMMEDIATELY go into the BIOS and check CPU temperature, fan speed and voltages
Annoying isn't it? You have built your computer you switch it on and then nothing happens except a few beeps from the PC speaker. Frustration sets in as you try to figure out what is wrong with it. If you didn't already know the computer has already told you the problem. It can't speak of course but it can direct you to the problem. Its all in the beeps. The BIOS can recognise when the problem occurs and sends a signal out to send a certain amount of beeps through the speaker. These beeps then tell you the location of the problem.
Unfortunately not all the BIOS' use the same codes as each other. Two of the main BIOS manufactures AMI and Award (now Phoenix) have different codes for there errors.
AMI BIOS
# of Beeps Error Description 1 Refresh Failure The memory refresh Circuitry is faulty 2 Parity Error Parity error in the Base (1st 64K) of memory 3 64K Base Memory Error Memory error in the base memory (1st 64K) 4 Timer Not Operational Timer 1 is not functioning (also caused by error in base memory) 5 Processor Error CPU error 6 8042 Gate A20 Failure Unable to switch to protected mode 7 Processor Exception Interrupt error The CPU on the CPU card generated an interrupt error 8 Display Memory Read/Write Error Video adapter is missing, incorrectly seated or has faulty memory 9 ROM checksum error The ROM checksum does not match that of the BIOS 10 Coms Shutdown Register Read/Write The shutdown register for coms RAM has failed 11 Cache Memory Bad The cache memory test has failed. Cache memory will be disabled. *** DO NOT enable it ***
With the first 3 beep codes, its well worth re-seating the memory just to make sure that it's in correctly. 8 Beeps is probably the most common in my experience. Can be caused by a badly seated Graphics card. If you have re-seated it then check with another Graphics card in the board.
Always check for loose components before sending the board back as this is the main cause of errors on the POST.
Award BIOS
Award states that they now only use one beep from there BIOS. This beep is one long beep and then two short beeps. This indicates a graphics card problem. Any other beeps should be treated as a RAM problem first and then the board sent in to be inspected.
The reason that the Award BIOS only uses the beep code for display problems is that it tries to display the error on-screen if at all possible. If the BIOS cannot initiate the display adapter then this causes the BIOS to make the beep code for a display error, which must be corrected before any other errors can be determined. Memory Test fails and hard disk failures etc will all be displayed on screen
IBM BIOS
The IBM BIOS works with Short and Long beeps as well as the Award BIOS. However the IBM one does still have codes to work from.
Beep Code Error 1 Short Beep Normal POST, System booted OK 2 Short Beeps POST Error - Code on Display No Beep Power supply or Motherboard error Continuous Beep Power supply or Motherboard error Repeating short beeps Power supply or Motherboard error 1 short, 1 long beep System board error 1 long, 2 short beeps Display adapter error (MDA/CGA) 1 long, 3 short beeps Display adapter error (EGA/VGA) 3 long beeps 3270 keyboard card Phoenix BIOS The Phoenix BIOS works on a slightly more complicated manor than the others. It does display an error code for you and produce a series of beeps. This BIOS produces its beeps according to the hexadecimal code the error produces. The Phoenix BIOS has many different codes for its possible errors and so many different beep codes. Rather than list the entire section here, I have provided a link to the official PDF file containing the codes and how they are derived.
Phoenix BIOS Post Codes
System board errors should be looked at by a specialist, Again always try to re-seat components to ensure they are in correctly. If necessary take all components out except for the RAM CPU and graphics card, then try the system. Re-seating components is the number one fix for getting past the POST screen. One badly seated components can cause the entire system not to function. so pick out your bios and follow the steps above to diagnose .hope this helps
