Question about Hotpoint Washing Machines
Hotpoint wd44d wash/dryer wont finish a wash nor wont pump out
I cleaned out the filter under the drum a few coins and curtains hooks in it tried it again still no joy the on/off light then flashes with the reduce creases and extra rinse button...
    Sergeant:
    Champion:
  • 223 Answers
It sounds like you still have a blockage either in the outlet hose itself or in he pump. If you know how to remove the outlet hose from the bottom of the machine but be aware a lot of water also might empty from the machine when you do this. If you use an object such as a pen and put it in the outlet hose no blockage it wll come out. Then gently feel around the pump opening for any objects. Finally gently spin the pump propellor to make sure it turns smoothly. Replace hose and test. Hope this helps.
Posted on Jan 20, 2009
Rinses light flashing fast and wont drain drum and finish wash
Try checking the filter for a blockage or pump being jammed with a button , disconnect drain hose at sink hold a few feet off ground over a bucket should pump/ flow quite freely if not then check filter and pump. good luck
Oct 13, 2014 | Miele Novotronic Premier 500 Front Load...
Where is the filter on my wf740 hotpoint
Maybe something jambed in pump, lint , coin or similar. Just fixed my LG machine coin in pump..Unsure of layout on Hotpoint but simply follow drain hose to pump.
Apr 17, 2013 | Washing Machines
Hotpoint WD 640. The machine is not fully draining after washing or drying. Any help?
The reason for this is almost certainly because the empty pump filter is partially blocked. Unfortunately, our loving friends at Hotpoint put the filter UNDER the drum and it can only be got to by drgging the machine out and attacking from the rear. The filter is the size of a large coffee mug, covered in rubber, directly below the cetre of the drum and held in place by a large jubilee clip. Remove the clip, pull off the rubber boot and inside is a white conical "pot" with a ping pong ball in it. You will probably find lint, coins and junk inside. Clean, replace the ball, reassemble. All should be ok
Jun 21, 2011 | Hotpoint Aquarius WD640 Front Load...
Keeps coming up with f5 wont pump out or spin
You need to chjeck and clean the pump filter.
Remove rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Reassemble and test.
Nov 29, 2010 | Hotpoint Aquarius WD640 Front Load...
It wont pump out does it have a drain filter ??
The filter is located at the rear of the washer.
Remove rear panel, and remoive large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Mar 22, 2010 | Hotpoint Aquarius WD640 Front Load...
My hotpoint aquarius washing machine wont pump out the water
HI.
You need to check the pump filter.
Remove lower rear panel of washer.
Remove large black hose fastehed to bottom of drum
Remove hose onto pump, and check for blockage or obstruction here as well.
Check drain out let hose is not blocked.
Please rate my solution/.
Thankyou.
Jan 28, 2010 | Hotpoint Aquarius WD640 Front Load...
Washing machine has f05 flashing on a hotpoint machine it wont pump out and cant get door open
The error F05 indicates that the pressure switch is jammed on full.
The only thing you can do your self is to check the filter is not blocked.
Remove lower rear panel of washer, locate and remove large black hose fatened to bottom of tub, watch out for water running out.
Refit filter and hose, test for leaks.
If problem still persists, then could be faulty pressure switch or blockage in the pressure system.
Good Luck!!
Thanks
Jul 19, 2009 | Hotpoint Ariston AS65VXSNA Electric Dryer
there may be something stuck in the pump itself. hairgrips and brawires are a common find.
Jan 19, 2009 | Hotpoint Ariston WD440G Front Load...
Hotpoint ultima washer dryer
ok lay the machine on its side the side with the soap draw under you will find the outlet pipe runing to the pump then another hose going from the pump to the bottom of the drum. if you disconnect the hose from the bottom of the drum you will find the filter remove this hose from the other end and clean the filter and hose with hot water once replaced check the hose in tight it may be tricky to replace stand up the machine and test using water only and an empty drum.
Nov 01, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Aquarius wd440
Find the pipe that comes out of the bottom of the drum, this may contain coin, muck, etc. Clean. This pipe leads to the small pump that draws the water out. If your clean of the pipe does not work the machine.......there could be a fault with your pump..........which you can/cannot clean.
Dec 29, 2006 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
151 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
